How Many Miles Are On Your Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Ryan M, May 12, 2008.
  1. priusincc
    priusincc Member
    332
    16
    NV
    9009 miles
    Needed front end alignment(warranty), noisy brake actuator valve at cooler temps; haven't had it fixed yet.
  2. animalcontrol
    animalcontrol If my mouth moves, ignore me!
    68
    Greenwood, IN
    2008 Touring (delivery 18 Jan 2008)
    9125
    No problems and don't expect any
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    2007 (delivered Apr 25 '07)
    18,007 miles
    no problems at all [​IMG]
  4. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    2005, purchased September 2005
    41,300 miles
    No problems
  5. gman11377
    gman11377 New Member
    66
    South Georgia
    2008-March delivery
    16,789-We drive alot;) (as of this morning)
    Absolutely no problems (lifetime mileage currently at 46.2)
  6. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    2006 (Jan 06)
    59,500 miles (original tires still OK)
    ZERO problems or dealer visits.
  7. CEO Alex
    CEO Alex Done
    Chicago
    WOW! I thought I drove a lot!...
    08 (bought in Nov 07)
    25,000 miles
    Never had any problems.
  8. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Year: April 20, 2007
    Miles: 36,317 miles
    Maintenance:
    7 oil changes
    rotated tires 7 times
    replaced both air filters once each
    82 tanks of gas
    Warantee work:
    TSB2810
    Other repairs:
    None needed
  9. oxnardprof
    oxnardprof Member
    249
    17
    Oxnard, CA
    Year Of Your Prius: 2004 (April, 2004)
    Miles On Your Prius: 71200
    Any Problems So Far? If So, What?: No problems. Oil changes every 5000 miles; tires replaced at about 45,000 miles.
  10. Devil's Advocate
    922
    Las Vegas, Nevada
    2005 - Fenruary 2
    Salsa Red Pkg#9
    143,000 miles
    41-42 mpg lifetime
    oil change every 35,000 miles (Amsoil w/ filter at 17,5000 miles)
    18,000 miles O2 sensor bad (fixed under warranty)
    110,000 left front wheel bearing replaced ($150.00)
  11. SDP40F501
    SDP40F501 Junior Member
    81
    Milwaukee, WI
    Year Of Your Prius: 2008
    Miles On Your Prius: 3,380 (I know, it's a short commute)
    Sometimes the glove compartment squeaks a bit, although I haven't checked for mice yet. :rolleyes:
    She goes in for oil change #1 next week.
    Jim
  12. geeky teacher
    geeky teacher New Member
    393
    West Suburban Chicago
    2007 with 23000 miles. Replaced brake actuator assembly under warranty. Worked fine but sounded like squeaky metal bedsprings when brakes fully depressed. Didn't like the sound so had the dealer replace it. Put scotch tape under both side mirrors when car wash took off the tiny plastic membrane over the recessed screw. The holes made high pitched whistles at higher speeds. Again, harmless, but I didn't like the noise. No other problems.
  13. JRMurray
    JRMurray Magnetic Gray is the only way!
    Surrey, BC, Canada
    Year: 2008 (received on April 8)
    Miles: 1865 (Kilometers: 3000)
    Problems: None
  14. uvm1969
    uvm1969 New Member
    39
    2005 with 65,400 miles. No problems. I use 0w 20 Penzoil Platinum synthetic , and change oil every 6,000-7,000 miles.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    93000 miles.
    I need to get some work done on the car. It's been good so far. Nothing too significant. I need a new 12v battery.
  16. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    08 model 2. 3500 miles since march 7th or so.
    No real issues. I think my alignment could be pulling left a tad. wheel cocks slightly to the right. weather seal on drivers door is loose at the curve.
    other than that the car has been stellar. Wifes car (also a pkg 2) has 1500 miles since march 31, no issues at all. super cars!
  17. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    2007 black prius
    11,700 miles
    no real problems, except alignment was fixed a month ago. Was out of spec from the boat. Typical moan's and groans from coolant pump and slight break noise when backing out..i think this is normal though
    otherwise 95% perfect.
  18. Gadgetdad
    Gadgetdad New Member
    462
    53
    Modesto, California
    2007 Super white Touring delivered 10/29/06 (just in time for the FULL tax credit-EYHO!)
    Just crossed 30K
    Only an alignment on complaint and regular service so far.
  19. ystasino
    ystasino Active Member
    793
    49
    Tucson, Arizona
    Package 2 for $20,940 in MD
    ~16,100 miles
    ~50 MPG per MFD
    No incidents, but will check alignment soon
    @ 1kMi the dealer overfilled the oil and never saw me again. Using Penzoil Synthetic 5W-30 and 44/44 psi
    Love how quiet this car is.
  20. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    Model 2008 package #2
    10,065 miles today - average about 49mpg
    No problems - service at Toyota every 5K miles
    John
