How many miles can 1 tank go?
Discussion in 'Gen 4 Prius Main Forum' started by krmcg, Jan 19, 2016.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    As you can see I have driven 454 miles in my new 2016 Prius Four. Excellent gas mileage of 63.3 so far. My DTE readout tells me that I can go 256 more miles on this tank of gas. For a total of 710 miles. The arithmetic works, for a 11.3 gallon tank - but a would leave a reserve of about a tenth of a gallon.
  2. Mendel Leisk
    41,880
    Maybe refill with a comfortable buffer, see how much it takes, then extrapolate to the full tank.
    Testing the limits is never my cup of tea, I fill up when it's below half and passing by my preferred gas station brand.
    yayprius, red07gen2 and krmcg like this.
  3. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I would like to know how much gas you can get in it when light starts blinking, although this may not suit everyone, we need to know
    52,369
    i would refill at 700 miles. let us know when the last bar starts flashing. or what the gen4 does to notify you that you're low.
    is 11.3 the same as gen3? i thought they held 12.
    GaryD1 likes this.
  5. krmcg
    2,592
    2,392
    Whittier, CA
    The DTE value has fallen as I drive. Was originally well over 800 miles for the tank. I do not plan on getting into trouble chasing a number. But at the same time I do expect to go until the light blinks. At this point I'm guessing 650 miles.
  6. bisco
    52,369
    the light blinks with about 2 gallons left in the tank. unless gen 4 is different. what does the manual say?
    krmcg likes this.
  7. akhare
    akhare Member
    47
    53
    There are those like me who had the ~100 miles after the beep rule of thumb on the Gen2 (which never failed me BTW, and I would be disappointed if I didn't fill in at least 9 gallons -- Gen2 bladder problems notwithstanding :p). The latest one is a full bladder less 12 gallons as per the manual IIRC.
  8. krmcg
    2,592
    2,392
    Whittier, CA
    123,000 miles in my Gen 2. 267 fillups averaged 9.1 gallons and 460 miles.
    yayprius likes this.
  9. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Nice. That's amazing!
    Was wondering where the regen display is on that display screen since you posted a nice clear pic.? Thx.
    Edit: it's part of the battery mid screen like the v ain't it? But does it also have a linear regen display like the Gen 3 liftback? I find Gen 3 liftback do much easier to P&G and regen light to light compared to the v..
  10. krmcg
    2,592
    2,392
    Whittier, CA
    The regen curve is in the HUD and in the MFD (can be if you desire)
  11. bwilson4web
    16,353
    This is not the kind of testing for the faint of heart but I've run our 2010 Prius out of gas about 6-7 times on purpose:
    [WARNING] Running out of gas (Gen III) | PriusChat
    The earlier model cars, Gen-1 and Gen-2, do the right thing by giving an abundance of alerts and alarms when the last of the gas is burned. In contrast, the Gen-3 silently switches to traction battery and gives no alarm.
    IMHO, the lack of a driver alarm makes it difficult to use the remaining traction battery energy to reach a safe parking place. There are many reports of Gen-1 and Gen-2 drivers who used their traction battery energy to get out of traffic and in some cases, reach a gas station. There is a very subtle clue with the Gen-3.
    With a spare, 1 gallon can of gas, I found that the energy flow arrows disappear when the last of the gas is gone. Use the display showing power flow between the engine, motor, and battery. In one case, I used the traction battery energy to go just under 1/2 mile to a residential street where I added the spare gallon.
    The reason for multiple tests were to confirm the amount of gas remaining after 'flash', 2.1 gallons, and the absolute amount of fuel in the tank, 12.1-12.2 gallons.
    eric1234 and GaryD1 like this.
  12. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Take Caution and carry a 3-5 gallon gas can. You newer Gen cars will need a minimum of 3 gallons to start the car after going dry. A PC member had to jump on the car with 3 gallons to reset the sensor in order to start the car.
    My friend with a 2014 ran out of gas, she only put a gallon, it would not start and had to get it towed to the dealer, they added 2 more gallons and it started right up. She was not happy. So be warned.
    krmcg likes this.
  13. krmcg
    2,592
    2,392
    Whittier, CA
    I'm impressed!
  14. bwilson4web
    16,353
    Thank you but there is something you could do to help us:
    Preliminary 2010 mph vs MPG | PriusChat
    The key is to measure MPG over a 10 mile distance, either a loop or two runs in opposite directions, at a fixed speed. With the 2016 you can get more accuracy especially at the lower speeds. The normal low-speed limit for our Gen-3 is 23 mph but that is not reliable due to bumps. Getting the MPG from 25 mph up would help us understand how much improved the Gen-4 is over the Gen-3:
    As background, we often have people coming to PriusChat complaining their particular car has an MPG problem. We ask them to repeat this benchmark and usually everyone learns something . . . and the benchmark chart remains. For example: Latest Software Update Safety Recall Resulting in 8mpg less... | Page 19 | PriusChat
    #14 bwilson4web, Jan 19, 2016
  15. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Toyota Ebrochure says 11.3 gal. for fuel tank. Based on last 4 days mystery math says 610 for the blink 680 max.
    or you could test the max range like this guy. West coast to West Texas working vacation with 3 little ones in Grandma's borrowed Prius. 113f to frost. About 5 minutes for clip in nowhere West Texas.
  16. Mendel Leisk
    41,880
    If that turns out to be the case, the 680 miles and 11.3 US gallons, that works out to 60 mpg, 3.9 liters per 100 km.
    That would be astounding; all things considered. I'm somewhat incredulous, but it'll be interesting to see how it works out, with some time, Fuelly establishing a 2016 Prius category and more reports.
  17. bisco
    52,369
    i'm sure people will find a way to get 39 mpg.:p
    usnavystgc and krmcg like this.
  18. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ..We may need F8L to start a new 1000 mile club contest for Gen4...this is getting interesting
    krmcg likes this.
  19. fuzzy1
    10,602
    A new Gen4 owner ought to start that. Having moved on to a longer range plug-in, F8L is an irregular here now and hasn't visited in five months.
    bwilson4web likes this.
  20. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Reminds of 2010 when a journalist was at a driving event. He wrote his report stating that he was going to do everything he could to get the worst possible mileage. He ran the A/C at Max with the windows down; gunned it off starts, slammed to stops, did everything wrong. He finished in the high-40s, IIRC. In the end, his report was funny but ended with reverence for the Prius' mileage.
    I just spent a few minutes trying to find that report but couldn't.
