How many miles can 1 tank go?
Discussion in 'Gen 4 Prius Main Forum' started by krmcg, Jan 19, 2016.
  1. krmcg
    2,592
    2,393
    Whittier, CA
    I wore my winter coat this morning...
  2. bwilson4web
    16,549
    The long sleeve T-shirt?
    52,880
    hey, your blood gets thin in those climes.
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    On our 2010 Prius after the first click you can still fill to the brim with nearly 2 extra gallons. I know this is not good but
    if you want to perhaps make 800 miles on a tank you could probably do it with 2 extra gallons on board....
    krmcg likes this.
  5. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I've found this true depending on the pump I used, seem some pumps faster cause a faster back up in tank neck causing first click. The only was I can see finding true filling is fill all the way up to neck and the next time use the same pump with car sitting in same position. Maybe someone else has a better way to get true fill up.
    Merged
    I have also found that the same pump will pump faster at times.
    #45 GaryD1, Jan 23, 2016
  6. 48mpg
    48mpg Member
    193
    47
    florida
    I
    I never go over 350 miles, I give myself a 40 buffer to find the next gas station, no I don't trust the float in the tank on a 10 year old car, I fill up the same way every time at the same pump and some weeks I go 140 miles on the first section of the gauge other weeks I go about 80
  7. Mendel Leisk
    42,365
    Well, cat's out of the bag, guess I might as well release this:
    #47 Mendel Leisk, Jan 23, 2016
  8. bwilson4web
    16,549
    Sometimes called the vapor capture canister.
  9. 48mpg
    48mpg Member
    193
    47
    florida
    I
    that's fancy I just use the spare tire well as a axillary gas tank, I keep 12 gallons in a trash bag back there and add as needed, 1000 miles per "tank"
    bwilson4web and bisco like this.
  10. bisco
    52,880
    i do the same, but use dry gas, so it doesn't slosh around.
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Why?
    3 weeks ago, I drove over 700 miles in one day... from Wyoming, clear across South Dakota, to the metro of Minnesota. There was no desire whatsoever of not stopping for a break. Taking time to get gas was welcomed. You need to refresh after so much travel.
    For the situations when you don't drive that far in a single day, what's the big deal stopping for gas from time to time? 700 miles is quite a bit of local travel.
  12. richiro
    richiro New Member
    24
    San Francisco, CA USA
    Just got my 2016 yesterday. Most of the reviews i saw that did distance drives reported the same, that they were actually hitting more towards the 60mpg mark.
    My Prius was showing 52.x with 12 miles on it when i test drove it. 100 miles later it was at 57.5. Another 100 miles it was showing 58.2. since filling up it's showing 60 (mostly freeway driving at 65-75 with an occasional 80mph).
    That mpg is out performing epa estimates seems VERY consistent with everything i've read and all the reviews I researched. The magic number seems to be in the 58-62 level. Will report more with manual math after a few tanks...
    oh forgot to mention.. after my fill-up - the computer reported my "fuel range" as 828 miles (72.4mpg avg)... LMAO... i couldn't stop smiling! :)
    NOTE: my manual says the fuel capacity is 11.4 gal.
  13. vince22
    vince22 Active Member
    205
    249
    califorinia
    which model do you have? thanks
  14. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Look left grasshopper. A model four. ;)
  15. vince22
    205
    249
    califorinia
    Oops, thanks Dave.
  16. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Hey! It was 53F minimum. Time to get out the parka!
  17. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    Toyota has been known to under state their EPA numbers. Unlike some other manufacturers, yeah,, I'm looking at you Hyundai and Ford!
  18. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Even Road and Track averaged in real world driving 56 mpg with a 2016 Prius 4. See Road and Track Magazine March 2016...
  19. kitkit201
    kitkit201 Member
    136
    88
    Bay Area, CA
    This is from todays freeway driving. About 62mph average, no traffic and a few hills. I probably would of got near 70mpg without the hill
    Sergiospl, GaryD1 and krmcg like this.
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Even a motor scooter would have used more gas....
    kitkit201 likes this.
