How many miles on your Gen 3 and what Repairs / Maintenance have you done?
Discussion in 'Gen 3 Prius Main Forum' started by Michael Wood, Oct 22, 2020.
  1. qdllc
    qdllc Senior Member
    1,377
    400
    Coming up on 105K. Nothing but usual maintenance items.
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Check mendels sugnatire if you want to go another 105K with regular maint
  3. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    I did, screwdriver cleaned 95% of it off. Oven cleaner and jet wash for EGR cooler.
  4. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    @Bill Norton
    You would be surprised and no ethanol doesn't evaporate all that quickly. I suspect gm is cheap and lazy and greedy and they also don't want vehicles clogging their parking lots. They actually lost the class action law suit on one of the oil burner law suits they had last year
    TSB:
    https://static.nhtsa.gov/odi/tsbs/2014/SB-10065822-9133.pdf
    Top Engine Cleaner: piston soak liquid that people actually use:
    https://seattleautomotive.com/files/SDS/10-3007%20acd%20top%20engine%20cleaner.pdf
    Chemical Name CAS No weight-%
    Solvent naphtha, petroleum, heavy aromatic 64742-94-5 10 - 25
    Diethylene glycol monobutyl ether 112-34-5 10 - 25
    2-Methylnaphthalene 91-57-6 10 - 25
    Naphthalene 91-20-3 5 - 10
    1-Methylnaphthalene 90-12-0 5 - 10
    Distillates, petroleum, hydrotreated heavy naphthenic 64742-52-5 3 - 5
    Upper Engine and Fuel Injector Cleaner: for some reason they also sometimes use this but its really a fuel injector cleaner
    https://www.kwparts.com/media/3547/88861803_20060731_eng.pdf
    TS CAS NUMBER AMOUNT
    Glycol ethers Trade secret 60 %weight
    Aryl alcohol Trade secret 20 %weight
    I'm good with using e85 though. Relatively low risk, a bit slower, and cheap and easy. Some of those cleaners are expensive and nasty. As far as I can see the car doesn't even burn a measurable amount of oil on the dip stick anymore. We will see at 5k when i can drain it and record it to the ounce.
    *A guy at O'Reillys I was telling about the e85 piston soak when i was doing it told me about the top engine cleaner they used when he was at GM as a mechanic. He said that it would smoke when they would pour it in and one time he looked at it up close and when he breathed in it kinda burned him. I was like damn... lol
    #264 Paladain55, Feb 5, 2023
    Bill Norton likes this.
  5. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    We and our friends have more than a dozen. They all get an engine and rear brakes at 190K. Then they get a hybrid battery at 220k. Most get an EGR cleaning and oftentimes if the oil burning was bad they need a catalytic converter. The 2010s and 2011s and the 2013 Prius v get a brake booster accumulator and master cylinder. Radios get replaced somewhere around the same time. Shock struts and sway bar links and straight sway bar bushings also get replaced around 200K which is probably too late it should always be done sooner. Seems like the whole car is pretty much due for replacement at 200k. The good time to sell one would be at 160K. A bad time to buy one would be at the same time
  6. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    BAM!
    That’s what service writers recommends right before youre about to make an engine oil change payment!
  7. webbkr
    webbkr Junior Member
    Central Florida
    2014 Base Hatchback (117k miles) here. Bought new, changed oil 5k intervals. Changed 12v battery 3 years ago. Changed out transmission lube at around 75k (yes, a little late). Just swapped in new EGR cooler and EGR valve. Also replaced spark plugs, engine and inverter coolant. Looking at replacing water pump, just to be proactive. Still on original brakes. Traction battery is at about 70 percent. Car is hopefully good for another 117K miles! Best car I've ever owned!
    ASRDogman likes this.
  8. FMC-Irl
    FMC-Irl Junior Member
    Ireland
    Excel
    2012 Gen 3 coming up on 250k Kms now. Oil consumption is gathering pace and a possible small coolant leak. Just did 1500kms in a week of touring over in England/Wales and it was faultless. Owes me nothing so I'll run it until it dies
    Michael Wood likes this.
  9. Bill Norton
    Bill Norton Senior Member
    2,154
    734
    MONW, Ks.
    Did you totally clean out the small passages in the intake manifold?
    Some think that is where the problem lies. Uneven distribution of the EGR gases plays hayl with the head gasket,,,, or so the theory goes.
    Having the EGR cooler choked down should just limit the total flow, but evenly.
    Just like unplugging the EGR valve will stop all the EGR flow, which should not play hayl with the HG, is another theory...
  10. douglasjre
    2,180
    718
    Null, NL
    Where's the coolant leak And what are your oil change intervals and what oil and filter are you using
  11. FMC-Irl
    Ireland
    Excel
    No leak visible but have had to add 1 litre in 8 months. No fouling of oil visible either. Oil is 0W 30 but not sure of brand of oil or filter. 16k km change interval.
  12. Mendel Leisk
    41,463
    Any cold start shakes?
    Ever cleaned the EGR circuit, including intake?
  13. FMC-Irl
    Ireland
    Excel
    Cold shake starts on very rare occasions. EGR never cleaned
  14. taxidriver50005
    204
    170
    GB
    Excel
    It's worth doing a piston soak and enging oil flush, has worked wonders with mine and wife's prius...at 250,000 and 360.000 miles and neither is using oil.
  15. Paladain55
    404
    164
    The South
    No kidding. Piston soak is magic. My old high mileage fleet burns so much less oil I think i have reduced my household emissions ironically. lol
    taxidriver50005 and Bill Norton like this.
  16. taxidriver50005
    204
    170
    GB
    Excel
    Can't believe this isn't on a sticky on front page.... This has to be the cheapest and easyest way to make your car last longer with less problems.
  17. Ares
    Ares New Member
    Nc
    2010 prius 280k
    Got at 214k
    Water pump alerts at 220k or so. Cleared code didn’t replace. Eventually replaced when it came back. Probably caused head gasket to fail.
    did head gasket, paid machinist to clean head and put in new valve seals.
    Used total seal felpro head gasket with felpro studs.
    Ultra sonic Cleaned injectors, egr system, intake manifold, pcv replaced and added catch can.
    did inverter pump. Ordered wrong pump when I ordered water. Did trans fluid.
    replaced sway bar bushings and end links up front.
    did struts up front. Got cheap eBay set clunking like old ones in 1k miles stiffer springs are nice though.
    rear wheel bearings twice. Bca makes trash bearings do timken.
    Bigger friend over extended and ruined a rear seat belt are these covered by Toyota?
    great car daily beater for me. No oil consumption that I can see. Walmart 5w30 synthetic oil changes.
    CR94 and douglasjre like this.
  18. FMC-Irl
    Ireland
    Excel
    261000kms. It just passed its NCT, which is the Irish roadworthiness test, with flying colours. Not a single issue. Amazing engineering
