How many miles on your Gen 3 and what Repairs / Maintenance have you done?
Discussion in 'Gen 3 Prius Main Forum' started by Michael Wood, Oct 22, 2020.
  1. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    You shouldn't have any problems at 66k. and 100,000 to that and big troubles
  2. crooner
    crooner Member
    107
    Yucca Valley, California
    2015 Prius two with 112K miles. Bought used in 2019 with 59K miles. Oil changes done religiously every 5K. Oil consumption is pretty much non-existent. Cleaned EGR, replaced spark plugs, installed oil catch can & changed engine coolant at 91K. Tires were replaced at 75K. The Yokohama Avid Ascends currently on it are excellent with great durability and gas mileage. Too bad they are now discontinued. I will need to replace them next year, so I'm looking for alternatives.
    I haven't inspected the brakes, so I will do that next. I drive to the high desert every weekend, so I am racking up the miles. Excellent car overall. I'm very happy with it!
    #82 crooner, Sep 14, 2022
    Michael Wood likes this.
  3. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    How did your EGR system look when you cleaned it? My 2015 doesn't consume any oil either. 2019 was a good year to buy your car!
    crooner likes this.
  4. AFFriedl
    AFFriedl Junior Member
    After selling my '07 Prius with 300K miles I'm back in the Prius world having just purchased at 2010 with 181K miles. I don't have any record of maintenance performed other than the motor oil wasn't black. I'm wondering what to start checking.
  5. Mendel Leisk
    41,479
    Start with the EGR system; more info in first link in my signature. If you're on a phone, turning it to landscape orientation will allow you to see signatures.
    AFFriedl likes this.
  6. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Your bank account..................
  7. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  8. crooner
    crooner Member
    107
    It was starting to clog up, but not severely. It was a great time to do it according to the folks a Hybrid Pit. Glad I did!
    And yes, the timing was perfect when I bought it. Gas prices were low and so were used cars at the time, specially hybrids. I bought it for around $12K, cash. I wouldn't be able to afford it at todays inflated prices!
    …and mine is a late 2015 model built in September of 2015, one of the last built. I think by then they had pretty much ironed out all the bugs.
    #88 crooner, Sep 16, 2022
    Michael Wood and ASRDogman like this.
  9. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Those of you who've changed the plugs on your Gen 3, did you replace the coils at the same time? Wondering what the service life of a coil is. No symptoms.
  10. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    If you've had no problems, no need to replace them.
    Michael Wood and crooner like this.
  11. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    Will your Prius let you know if there is a problem via dashboard lights? Basically, is this car smart enough to tell me it's sick no matter how small the problem may be?
  12. Radiospank
    Radiospank Member
    166
    77
    150k miles, 2010,
    Cleaned egr, transmission fluid change, oil catch can install, new PCR valve, changed brake accumulator and actuator, changed suspension to koni fsd, trd springs, trd rear sway, inverter fluid change, brake fluid flush and change, changed front sway bar links oem, new plugs.
    car will need new hv battery, and head gasket probably at some point, it has some cold start rattle but it’s minor enough for now.
  13. Mendel Leisk
    41,479
    At what miles did you clean the EGR?
  14. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Did you do the accumulator / actuator job yourself? That looks like an expensive PITA.
  15. Radiospank
    Radiospank Member
    166
    77
    change oil on 131000
    changed transmission fluid 130,000
    changed pcv valve
    02/2021
    cleaned EGR Pipe and cooler
    drained refill engine coolant
    installed trd rear sway bar
    131k mileage
    03/2021
    132k mileage
    cleaned Intake Manifold and egr valve
    installed new IM gasket
    oil changed
    engine filter
    Spark plugs changed(real ones from autozone ngk)
    11/11/2021
    140k miles
    c1391 code abs accumlator
    11/22/2021
    140k miles
    strut konis $600
    bearing,boots, bump stop $154.13
    brake booster $214
    Changed shocks, struts with koni fsd
    Changed brake booster and ABS accumulator
  16. Radiospank
    Radiospank Member
    166
    77
    yes see above i bought it used on ebay for 214, watched some youtube vid that explained how to do it, but even after you install it, you need to bleed the brakes and use tech stream, use a good obd2 dongle like tactrix. yea i guess its a pita, but not too bad?
  17. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    How's Homer?
  18. ChapmanF
    18,222
    No. It does monitor a whole lot of things, so it can tell you about a whole lot of problems, and that's a huge advance over older cars that couldn't tell you such things. But it can only monitor the things it has sensors for, and it can only detect problems if the engineers thought of those problems and thought of ways to catch them based on sensor readings, and only if it was deemed cost-effective to include a sensor for that and the necessary computer code to catch the problem.
    So, you can have various different kinds of problem:
    • Things the car notices and tells you about before you notice anything
    • Things you notice before the car notices anything
    • Things you notice, and the car has noticed something, and the something doesn't directly tell you what the problem is, but might give you useful clues when you look in the repair manual to see how that code is detected.
    #98 ChapmanF, Sep 22, 2022
    CR94 and Mendel Leisk like this.
  19. Freeze Time
    Freeze Time Member
    150
    49
    Huntington Beach
    So the car has sensors for all the major things that can leave me stranded? Since it has less moving parts, it's less likely to have the same issues as other cars so I am hoping if the car is sick, it will flash the appropriate lights to let me know it needs help. Is there a general consensus as to well you should have the car checked for any stuff the car can't detect itself? Like at 100,000 miles, do I have to check like a certain fluid that isn't checked during an oil change? I basically want to make sure something wrong with the car doesn't go ignored.
  20. ChapmanF
    18,222
    I wouldn't say I've seen any reason to assume that.
    The car is instrumented in ways that can, often, when a problem crops up, save a lot of time in diagnosing it.
    To assume that means the instrumentation will be able to warn you of any potentially serious problem seems like a stretch, though.
