How many miles on your Gen 3 and what Repairs / Maintenance have you done?
Discussion in 'Gen 3 Prius Main Forum' started by Michael Wood, Oct 22, 2020.
  1. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    I did mine many many years ago, and I paid a garage. They probably used junk parts.
    My Prius has 163k miles and it doesn't bounce at all when I push down on the front and back. It's still very stiff.
    Those KYB Excel G's are $82 each on Rockauto if I keep my springs. Even with the cost of the compressor I could probably stay under $400 in part to do the whole job, front and back. It looks like the original struts are Bilstein.
    #141 Michael Wood, Oct 21, 2022
  2. karl.d
    karl.d Junior Member
    31
    22
    san francisco, ca
    I wouldn't know what kind. It was done at the Les Schwab and whatever they offered.
  3. karl.d
    31
    22
    san francisco, ca
    The one thing I have noticed is that after every Transmission Drain / Refill, the "B" mode / Engine Braking seems to lose its efficacy. I got the Drain / Refill done earlier in the week and "B" mode does not seem to do much anymore.
  4. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    I'm sorry if they did that to you
  5. Mendel Leisk
    41,462
    Just editorial: it’s B gear?
    I’ve not noticed a change, not sure why that would be. You refilled the transaxle with Toyota ATF WS, on level ground, till it started overflowing?
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,153
    6,312
    Texas Hill Country
    Given the transaxle oil has no hydraulic or clutch purpose, it is doubtful B mode can be effected one way or the other. B mode simply tells the hybrid control to use engine braking in addition to regenerative, useful on extremely long downhills to save the friction brakes. The fact the system is burning energy to rotate the engine makes B mode less efficient.
  7. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
    2015 Toyota Prius 5
    Headgasket @140k
    Water pump @110-120k
    Pads were replaced when I got my EBC slotted rotors around 130k
  8. Mendel Leisk
    41,462
    Was EGR cleaned prior? At what miles?
  9. karl.d
    31
    22
    san francisco, ca
    I've only had the refill done at the dealership or the local shop. So I trust they know what they are doing.
  10. karl.d
    31
    22
    san francisco, ca
    Wish I knew the source of the cause as both Dealership and Local shop have told me that its unheard of. But I know what I am experiencing.
  11. rjparker
    10,153
    6,312
    Texas Hill Country
    The question is why are you using B mode? It is less effective for capturing regen energy than D and normal braking.
    douglasjre likes this.
  12. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Doubtful the drain and refill would affect the way the "B" transmission selection changes behavior. The effect of "B" is different when the battery is near fully charged than it is when it isn't.
  13. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    My 2010 is at 206,000 I got the Prius about a year ago.
    Head gasket was done in 2019 with 249,000 miles by dealer under emission warranty.
    I cleaned the EGR 95 % blocked. I don’t think the dealer did it when they did the head gasket.
    Replaced engine water pump at 200k for preventative maintenance.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    They should have said its life time fluid and doesn’t need changing. You were probably charged for it and it wasn’t performed.
  15. spudnut
    spudnut Active Member
    145
    159
    Idaho Falls/Pocatello, ID
    2013 PIP, 106 K, bought it at 38 K, done nothing except change the oil every 10K, and a couple air filters, zero issues. I log every fillup, with my commute, I average mid '60's MPG
    CR94 likes this.
  16. Mendel Leisk
    41,462
    Just editorial: was head gasket done at 149k?
  17. 2010moneypit?
    314
    122
    Beaumont ca
    I missed that sorry. Yes head gasket done at 149xxx
    #157 2010moneypit?, Oct 23, 2022
  18. ChapmanF
    18,212
    What was your method of measuring blockage to two significant figures?
    Did you happen to note the car's measurement of flow before and after that cleaning?
  19. 2010moneypit?
    314
    122
    Beaumont ca
    I didn’t use a scan tool to check for blockage. I held the EGR up to light to see how much was blocked.
  20. ChapmanF
    18,212
    Did you have a way of measuring the light passing through, compared to a clean one, out to two significant figures?
    CR94 likes this.
