How many prime owners have invested in a L2 Charging station at home?
Discussion in 'Prime Main Forum (2017-2022)' started by coach81, Oct 3, 2018.
  1. alexcue
    alexcue Active Member
    346
    311
    So Cal
    In my case the local utility paid for my charger, and the installation was relatively cheap, knew a guy who knew a guy... So it was a no brainer for the convenience. After getting the Bolt though, it's much more convenient. I also ended up with an L2 being installed at my office by my boss. They got the M-B plug-in ( a big 14 miles of range! but more important for them was the HOV stickers).
    HPrimeAdvanced likes this.
  2. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Or
    - You have a Prime and run out of battery mid-day and need it charged in 2 hours instead of 5 to go out again - rare example
    This is not cost efficient but it's nice when you can do this.
    HPrimeAdvanced and alexcue like this.
  3. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Are you with Edison? How much is the installation?
  4. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Even our pretty decent L2 charger incentive (half of the install, half off the charger) I've just been charging my car L1 overnight.
    Even though someone pointed out its futureproofing my house, by the time I get my next prob full elec car they will have newer cars chargers I know I will want ;)
    coach81 likes this.
  5. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    A6D7C41B-CFBF-4209-AC35-B692A25402F7.jpeg I use my Tesla charger.
    EyePrime likes this.
  6. coach81
    coach81 Active Member
    758
    116
    Louisiana
    I am still undecided, I’d like the convenience of an L2, I may just start with L1, and see how that goes to start. If / when I take the Prius plunge
  7. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    I have a L2 charger and solar and charge multiple times a day. If I didn't have solar, I would only charge once a day and the L1 charger would have been fine. I'm not sure the L2 charger and electrical outlet (total cost about $800) will ever pay for itself though. Wishing the Prime had more EV range.
  8. Rmay635703
    Rmay635703 Senior Member
    2,667
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    Just be happy you don’t have a PIP, EV range is partly why I have a Volt but I’ve
    Always hoped the diy community would finish the 2000 Honda Insight PHEV lithium and one way clutch conversion.
    My guess (from Insight EV conversions) is that a plug in Honda would hover around 160wt/hr a mile which would give 44 miles range at 65mph on an 8kwhr battery.
    Too bad no one will buy a small efficient vehicle.
  9. mczouav
    mczouav Member
    BE
    Got a L2 openevse kit i assembled myself. It works great with wifi, timer, amp control and it sends info to emoncms website ... Can follow everything. Some days we charge several times so it s very usefull to have the 240v option.
  10. alexcue
    346
    311
    So Cal
    DWP, Like i said, not a fair comparison in my case. I was quoted about $650, mine came in way under that. To be honest, I thought that was a rip! the run was only about 3 ft from the Panel, and I had plenty of open spots for the breaker. Once the actual installer came he was done in about an hour, I basically paid for his hourly rate, since parts were not that much for such a short run. Think the breaker was the most expensive thing.
  11. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    A possible advantage of L2 is preconditioning the cars heater / aircon . L1 probably doesn’t provide enough power to both charge and precondition at the same time.
    HPrimeAdvanced and coach81 like this.
  12. coach81
    758
    116
    Louisiana
    Agree Craig.. that could be really helpful on cold/hot mornings....
  13. coach81
    758
    116
    Louisiana
    Anyone using an L2 to preheat with cold weather these days?
  14. Curlyone
    Curlyone Member
    50
    60
    Arkansas
    I've found preheating to be helpful, seems to make a difference between not making it home at the end of the day without using gas and a total EV commute (20 mile daily commute). I didnt expect cabin heating to use much power but it's been noticeable even though the temps have been fairly mild, high 30's in the morning.
  15. coach81
    758
    116
    Louisiana
    Thanks Curly.
  16. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    It will use a lot of you have temperature set high. For us here in Minnesota, 65 is plenty most of the time. That's a light load on the battery. (Use the heated seat to supplement too.)
  17. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    I have a few question. How much is your time worth per hour? Would you wait for your car to charge before you go somewhere?
    My current value of my time is $150 plus an hour since that is what i change my clients.
    We have about $300 ( From Costco ) in the JuiceBox 40. Normally $500
    - $125 in wiring and breakers ( 50 AMP )
    - $100 for an electrician to assist me on the install
    So $525.00 for a L2 charger installed.
    So less than 3.5 times my $150 per hour rate.
    BTW: I have a large solar array. Cost of power is fixed for the next 30 years for me.
    instead of generating large credits with the power company I use what I need and have
    But your costs may vary.
    Blue
  18. Salamander_King
    Salamander_King Senior Member
    11,016
    8,946
    New England
    Well, I don't get paid when I am sleep at night. Nightly charge on L1 works for me. ;)
  19. coach81
    758
    116
    Louisiana
    So you don't think I should install then for a prime Lee?
  20. El Dobro
    El Dobro A Member
    7,086
    3,263
    When I had the PiP, I bought an L2 charger to keep up as much EV driving as I could, with its limited range. Since I already had a 220 outlet in the garage, adding it was no problem.
