How many Prius Keys included?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by David C., Jan 15, 2013.
  1. David C.
    David C. Junior Member
    16
    San Jose, California
    I purchased a Toyota PIP and received two keys. Is there a 3rd key ? My window sticker shows 3 keys.
    52,849
    :) i got 2 with my first 2 pri and my pip, never heard of 3. that's interesting, can you take a pic? congrats on thepip purchase, welcome to the club! i didn't notice anything on my sticker, i'll try to remember to look at it tonight.
  3. Rainking
    Rainking Member
    164
    New York
    I also only got 2 keys.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Are you sure the window sticker is showing 3 keys? 2 keys is standard.
    Could it be saying 3-door SKS ? That would mean the two front doors and the liftback door operate with the SKS touch sensors.
    lensovet likes this.
  5. David C.
    16
    I will check the sticker later, I only got two keys and was wondering about it when I looked over the paperwork. I had my PIP since mid Oct 2012. I've been enjoying the solo driver in hov/carpool lane for a short time. Only regrets about this PIP is the Chevy Volt seems superior in ev miles. Tesla burned me so I decided to get PIP.
  6. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    2 keys is what I got. Pretty much every car I've bought in the last 15 years has come with 2 keys standard.
  7. Rainking
    Rainking Member
    164
    New York
    My wifes' 2012 Elantra came with 3 keys. Two fobs with hidden key and a valet key. I doubt the Prius has a valet key though.
  8. devprius
    devprius /dev/geek
    979
    291
    I'd forgotten about the valet keys we got with the minivans. But in terms of keyfobs, only 2 per car.
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I think what you may be reading on the sticker is "3 Door Smrt Key Sys, Rmte Keyless Entry" which actually means the remote keyless entry system (smart keys) works on only the front doors and the rear hatch.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Yup, PiP has Smartkey system for 3 doors, as a standard feature. That means, you can open the driver door, passenger door and rear hatch with the key fob in your pocket.
    The regular Prius lower trim has only one Smartkey door (driver).
  11. Phausto
    Phausto Junior Member
    75
    16
    Pacific NW
    I realize this is a little off-topic, but can you expand on the Tesla bit?
  12. rogerv
    1,639
    317
    My guess is he was on the list for the Tesla S ;)
  13. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    That's what I think.
    2010+ Priuses can come w/1-door or 3-door smart key. Per 2013 Toyota Prius Plug-in Hybrid Models "Smart Key System [15] on three doors with Push Button Start and remote illuminated entry" is standard on the PiP.
    I've never heard of new Priuses coming w/3 keys. They come with 2.
  14. David C.
    16
    It's called the phantom waiting list and failed promises time after time of inquiry.
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Huh?
    Do you understand the difference between 3-door SKS and 1-door (driver's door only) SKS?
    edit: Oh... nevermind, I guess you're referring to your Tesla Model S order.
    Which battery capacity did you have on order? Did you also select air suspension?
  16. BUlm
    BUlm New Member
    Monrovia, California
    Mine only came with 2 as did my 2008 Prius so I believe that is the standard?
    pichner likes this.
  17. bisco
    52,849
    glad you nailed that one cwerdna, i was like, what?:LOL:
  18. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The third key is usually the valet key so that you can lock valuables in the trunk that you don't want the valet to get access to. The valet key won't unlock the trunk on notchbacks. It's not applicable to the Prius because you can access the trunk without opening the hatch. Hence, only 2 keys.
    I get Volt envy every once in awhile too because of the higher EV range. But keep in mind the Prius can carry 5 passengers versus the Volt's 4. Plus the Prius has superior cargo capacity with seats folded up or down. Pretty good trade off either way in my opinion. If I wasn't a family fan... I could afford a used Tesla roadster and forget this gasoline stuff.
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    I recently bought a used Highlander Hybrid, and it came with only one SKS key. So I bought a second one, and the dealer charged me $500. This includes about $70 for the mechanical key, and around $140 to pair the SKS key with the car control unit. :( The dealer explained that with the Gen I Prius, if you lost all the keys, that they had to replace the ECU in the car with a new one plus its key, but Toyota caught so much flack for this, that they eventually just started to replace the ECU for free in this situation. Gen II and above allow the SKS settings in the ECU to be reset using some super-secret process.
