How many quarts oil change WITHOUT filter change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Sep 9, 2015.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    Sorry but I lost my owner's manual, but about how many quarts of oil would our Prius need without replacing the oil filter? I know its best to replace the filter also, but I do my oil change every 5000mi and not the 10,000mi Toyota recommends, due to my severe driving and long distance travel.
    Also, don't want to sound too demanding but if you could post a screenshot of the Oil change page in the owner's manual that says how many quarts and stuff.
    Thank you Priusians! :)
  2. JC91006
    16,933
    8,643
    Put in 4 quarts and take a look. It should be enough. Add if needed.
    4.4 quarts with filter
  3. Mendel Leisk
    42,266
    You can download a pdf of the manual. Google:
    Toyota tech info
    And look in the manual tab
    It's 4.1 U.S. qts or 3.9 liter
  4. Mendel Leisk
    42,266
    Kinda forgot: there is next to nothing in the Owners Manual regarding the oil change. This excerpt from Repair Manual has the instruction. The main data besides oil qty/grade is the torque values.
    For the oil filter, there's a lot of explanation about a little retention clip on the oil filter housing. It actually does nothing, at least doesn't get in the way, hinder anything. As long as you've got a decent low-to-medium torque wrench you're ok.
    For the filter housing removal a 14 point socket with around 64.5 mm inside face-to-face dimension is needed. You can get the kosher one from Toyota, Honda has a similar one, and there's a lot more on the web.
    #4 Mendel Leisk, Sep 10, 2015
    ftl likes this.
  5. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Just got mine Saturday so I haven't looked up anything yet but are oil filters expensive enough it's not worth replacing with every oil change? Since oil does not wear out wouldn't it almost be better to change oil at 10k and filters at 5k?
  6. Mendel Leisk
    42,266
    That's a confusing posting, lol. Anyway:
    If I was going to double the change interval on anything, it'd be the oil filter. My cost for filters, at a local Canadian dealership, is $8.53.
    Still, with the American 10,000 mile (or 12 months) interval, I'd stick to changing both the oil and filter. Up here it's 8000 km (roughly 5000 miles) or 6 months for oil and filter change.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    3rd here, change the filter frequently, and while yer under the car, change the oil also;)
  8. LDB
    LDB Member
    279
    71
    Sorry, maybe I can be clearer. When I ran my Chevy van it called for oil/filter every 5k miles. That was for 100% dino oil. For synthetic I expected to get 10k before changing the oil. My dad, and my Texaco engineer friend, told me oil does not wear out, it just gets dirty and the additives either wear out or are consumed. So after X miles the actual oil is still perfectly fine but the other stuff needs replacing.
    Anyway, I went to synthetic in my van and although many people said 10k was fine for oil/filter for the synthetic I changed the filter every 5k anyway. I believed the few extra dollars was a good investment. So, if I read it correctly, I was suggesting 5k oil and 10k filter seems backwards and was questioning why not spend the few extra dollars for a filter with every oil change rather than leave some old, partially dirty and partially additives worn/consumed oil to be mixed with the new.
    That should be clear as mud now, hopefully. :D
  9. Mendel Leisk
    42,266
    Thanks for the tour, that makes sense. The only edict I've heard from a manufacturer is Honda, who say to change filter with every second oil change, at least with our previous civic hybrid.
  10. LDB
    LDB Member
    279
    71
    That is interesting. It seems counterintuitive to me, leaving a partially dirty/used filter with new oil. I'd likely disobey and change the filter every time just for peace of mind.
  11. Mendel Leisk
    42,266
    Oh yeah, that's what I've been doing with Prius, basically following the schedule. With the Civic, having the guidance to leave the filter at alternate changes, I would remove, pour out and reinstall it.
  12. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Why not carefully examine one of those filters you take off after 5000 miles to see what it has captured? I'd bet you'll find very little of anything, nowhere near enough to clog it, if your engine is healthy. That's what I found when I looked at filters from my previous car after much higher mileages on conventional oil. These new cartridge filters make filter dissection a lot easier than it used to be when I did it.
  13. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Unless the oil filter is on top of the engine, changing the filter every 5K means your changing the oil every 5K as well.
  14. Mendel Leisk
    42,266
    I was thinking that, but not so sure: think the oil level in the sump is low enough it'll stay put when you remove the filter.
    Still more frequent oil filter replacement seem expensive, time intensive and unneeded.
    CR94 likes this.
  15. RRxing
    2,562
    1,839
    NEPA
    As the saying goes - "Pics or it didn't happen."
    Anybody try it yet?
  16. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Right and right.
  17. frodoz737
    frodoz737 Top Wrench
    4,791
    2,559
    33
    Do what will, but I do not know one mechanic that changes the oil and not the filter in their own vehicles.
    E Risch likes this.
