How many watts is MG1 in G3
Discussion in 'Gen 3 Prius Technical Discussion' started by smilyme, Nov 6, 2019.
  1. smilyme
    smilyme Member
    112
    42
    How many watts is MG1 in a G3?
    and a reference link if possible
    Thank You
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Looking forward to your question being answered... You can see the amps that are generated across the whole system on a phone app, but you can't break down amps and watts of parts of the system. But maybe in techstream?
  3. smilyme
    smilyme Member
    112
    42
    I have these specs for MG1 in a G3
    42 KW / 650ac , max 10000 RPM
    does anyone have a link to a toyota specification ?
    and published hp rating?
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    42kW = 56.3229277314 hp, 57.1041079268 hp(M) = 10,031.5276584 cal/s, 143,309.948591 BTU/h ;)
    Pluggo and smilyme like this.
  5. ChapmanF
    19,025
    What spec do you have for MG2? That's the larger motor, I expect MG1 to be less.
    At least in the earlier gens' New Car Features manuals, figures were published for MG2 but not for MG1, as I recall.
  6. smilyme
    smilyme Member
    112
    42
    Hi ChapmanF my in progress chart:
    Prius Motor/Generator Specifications
    Classic
    MG2 44 hp 33 KW/273ac max 5600 RPM xx nm
    MG1 20 hp 15 KW/273ac max 6500 RPM xx nm
    g2 MG2 67 hp 50 KW/500ac max 6700 RPM xx nm
    MG1 41 hp 30 KW/500ac max 10000 RPM xx nm
    g3 MG2 80 hp 60 KW/650ac max 13500 RPM xx nm
    MG1 57 hp 42 KW/650ac max 10000 RPM xx nm
    g4 MG2 72 hp 53 KW/650ac max xxxx RPM xx nm
    MG1 31 hp 23 KW/650ac max xxxx RPM 40 nm
  7. smilyme
    smilyme Member
    112
    42
    Thanks
    PriusCamper
    I've got to play with techstream soon enough
    hey " restored ev-mode," i wondering what it is
