how mount gps on dash
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Baldbubba, May 4, 2014.
  1. Baldbubba
    Baldbubba Member
    142
    26
    in PRIUS down by the river
    i am wanting to mount my gps on my dash just to the left of the mfd ther is a smooth spot, i have used the suction cup, it will not stay! i have cleaned both surfaces, i just cant it stay. any ideas? i have considered using velcro, i am not oppsed to using super glue i can remove the unit an leave the post in place. i am going to keep this car so permanet doesnt bother me. i am so tired trying to catch the unit as it high dives off the dash!
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Get a "nav mat" and put the base of the nav unit on the mat. Then lay the mat on the dash. The gps will stay put. When you are through with it, unplug the power cord. Life the mat off the dash and take gps off of it's stand. Put GPS in console and mat in rear seat floor board under passenger seat.
    Did that all the time with the Gen II. Doing the same with the new Gen III, but only using my Garmin to get coordinates as the built in gps will NOT save coordinate locations. Go Figure. Garmin Nuvi does it all day long, but Gen III gps won't save the coordinates...
    Edit, I'll include a link: Scosche GPSDM GPS Dash Mat: GPS & Navigation : Walmart.com
  3. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I recommend AGAINST gluing anything to the dash, both because it might not come off when it's time to sell the vehicle and because it might come off on it's own, leaving an UGLY mark.
    There are "bean bag" mounts as well and the "nav mats" available.
    They work remarkably good, despite what you might think.
  5. xliderider
    8,140
    3,274
    Honolulu, HI
    The OP stated they were ok with a semi permanent mounting option like glue or adhesive.
    Mats and bean bags, as well as the devices they are "holding", become projectiles during accidents. That half pound device can do some serious damage to an occupant if it becomes a projectile from crash forces.
    mtbiker53, dorunron and Epiphany2000 like this.
  6. Easy Rider
    982
    210
    N. Central Florida
    The mounts typically are flimsy and the device "snaps" out of it rather easily.
    I see no reason to believe that they would be any more or less dangerous than one suction-cupped to the window......or suction-cupped to the dash.
    The projectile problem is most dangerous when sudden deceleration is involved AND the object in question flies directly AT an occupant. Side impacts or low speeds or objects on the dash that fly toward the windshield are generally not a serious problem.
  7. JPTuck
    JPTuck Member
    110
    29
    South Deerfield, Mass
    I use the windshield mount that came with my Garmin - I have used permanent dash mounts in the past but lately folks have taken to viewing an empty mount as an invitation for a quick smash and check of the glove box or center console even if you don't leave yours in the car. With the quick release suction cup mount removed and put away no one even knows I have or use a gps and the mount quickly sticks back on when I'm ready to go again.
    CatsAreGods and dorunron like this.
  8. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    1) Make sure it is warm. 2)Try one of the shorter, gooey type suction cup mounts. The cheapest ones didn't work on that spot for me either till I bought a different brand that says "sticks to painted walls".
    dorunron likes this.
  9. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    what about the small window in front of the door the little triangle.
    yes you'd have to run the cord and hide it, and you're passenger would never be able to operate it... but its not a bad spot..
  10. ursle
    ursle Gas miser
    1,049
    192
    NH
    Bean bag, next to the small(tiny) window in front of the passenger, a small wire tru the vents near the window holding it in place... easy to read, stop to adjust input, it's a nuvi
