How Much Damage from Parking in the Sun?
Discussion in 'Prime Technical Discussion' started by DC Prime, Jun 7, 2020.
  1. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    I detail cars as a hobby. Headlights degrade due to UV damage. If you keep them protected they will never degrade. All of our vehicles get spray waxed with a reputable brand almost every weekend which is severe overkill. Any decent wax has chemical UV inhibiters.
    Here is a patent from Optimum Polymer Technologies describing spray wax with ultraviolet absorbers - US6685765B1 - Water based protectant containing UV absorbers - Google Patents
    Here is an article describing various chemicals used for UV absorption.
    Ultraviolet absorbent
    There are many, the three mentioned in the article happen to be Chinese. UV absorbers are used everywhere including the clearcoat in the paint on your car.
    Raytheeagle likes this.
  2. Mendel Leisk
    42,271
    What's at odds with that though: IIRC Owner's Manual has a caution, to never apply anything, wax or whatever, to the headlights. Maybe they're concerned about polish might have abrasive? Not sure.
    Moot point for us, garage stored, but still I'm interested.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    To avoid high heat/possible degradation issues:
    Avoid charging outside in the heat of the day (especially level II 240v).
    Avoid driving on EV immediately afterwards.
    Avoid letting a fully charged battery sit in the sun.
    Use a liquid cooled pack with an active BMS.
    Use HV instead of EV mode when the pack is hot.
    Use additional battery monitoring software/hardware to closely monitor pack temps/behavior.
    Sadly, me too. :LOL:
    Hmm, you got me to thinking about 303 protectant. Have you used it? I learned about it on a car forum a few years ago and it's awesome in my book.(y) So much so, I now buy it by the gallon to use on all our vehicles. Since 303 is all about UV protection, I will now add headlights to the full treatment instead of just wiping off the occasional overspray they would unintentionally receive during a detail.
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Do you have any suggestions for super low effort detailing? Going to an automatic carwash is about as much time as I want to spend, but if there's an easy way to add a little protection and help the car stay cleaner for longer I'd do it. I just don't have time to do a thorough hand wash and wax.
  5. Mendel Leisk
    42,271
    FWIW, page 406 of North American 3rd Gen Owner's Manual:
    Again, I'm not sure of the logic behind this caution. Might be Toyota's concerned about cleaner waxes??
    I tried this for a google search, not finding much:
    Why do car manufacturers caution to not wax headlights
  6. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Cleaner waxes are not very useful. Spray waxes for the non-detailer are pretty good these days. Meguiars makes one for consumers and should be available at Wal-Mart and other places.
    Here is where my opinion gets into the mix.
    Chemical Guys is competent but not very durable. If you're going to go the "name brand" route I would recommend Griots Garage first and Meguiars second. Most people want something that is easy to remove. Both of these are easy to remove.
    If you search "spray wax" on Amazon you will be overwhelmed. Narrow your choices to "Meguiars" "Griots Garage" and "Optimum" and you will be less overwhelmed.
    Meguiars has so many but stick to the Xpress Spray Wax. Griots has two and either of them (Best of Show and Spray-on wax) and both are competent. Optimum Car Wax is the best in my opinion and is the one I use. I buy it by the gallon. All of these will protect your headlights from UV, too.
    Back to headlights, if you don't have time to wash your paint, at least hit your headlights as often as every week with any of these spray waxes and you will never have yellowing problem. My last Prius spent its entire life in the NorCal sun for almost seven years and the headlights looked as clear as factory and they only thing I did to them was weekly spray wax. I had more problems with the water leakage around the seals (a different issue) during heavy rain. It doesn't take much to protect your headlights (in terms of protection thickness which is only a few molecules deep) but those chemical absorbers do an amazing job.
  7. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Sorry, I did not answer the original question. You are right, they don't want to using any wax that has abrasives in it which will remove the factory UV coating. The spray waxes I cited don't have any abrasives in them.
  8. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Low effort is what I get. I mentioned the spray wax route in a prior post. If you wash and spray wax regularly this will be as low effort as it gets. The trick is to keep it up before the paint starts causing water to sheet. Once that happens you will increase your effort. As long as water is beading you still have protection which makes the washing and spray wax easier to apply and remove.
  9. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Hmmm. I'm going to have to pull out my IR gun and do a comparison. I would think that the lighter colors would reflect more sunlight and be LESS susceptible to heat, not more.
  10. Mendel Leisk
    42,271
    Just a lot of reports of blizzard pearl peeling. Like crazy. Not so much the reflectivity as the make-up of the paint I think. Sun (and a lack of polishing?) probably makes the issue worse.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Much Ado About Nothing..or nearly nothing IMO.
    I agree with this statement:
    When I owned my Gen 3 Prius, I did not have a garage, and had to park it most of the summer exposed.
    I bought a good quality, custom fit sunshade for the front window, and I usually cracked the window a bit.
    Of course it didn't make the vehicle any cooler than the outside, but it did keep the vehicle within a pretty close range of being whatever the temperature was outside. As opposed to no windows being sunshades, and the entirely closed up vehicle heating up like a solar oven.
    So I would venture to say, Sunshade, crack the windows, and heat degradation to your HV battery is going to be minimal.
    As far as insects, spiders, paranormal entities...
    Hey, life come with some risk. Mosquito can bite you on the way to the car, or fly in when you open the door.
    Spiders are brilliant. They can hideout in your door jam, or put on disguises and pose as family members. So you just live with the risk.
    I would say I followed the above protocal, and still do, and I don't really notice the insect population within my vehicle being abnormal.
    jerrymildred and Mendel Leisk like this.
  12. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    I've already done this on multiple cars. White and silver run the coolest regardless of the angle of the sun in the sky. Black gets the hottest, dark blue/red/green/charcoal are not far behind. I've seen 40F-60F higher temps on the same day in the same area on black paint vs white paint. You can put your hand on the surface and do a touch test, too.
    Heat is much different from UV in terms of damaging clearcoat. Modern clearcoats can handle a lot of heat, they just don't handle continuous UV without being protected.
  13. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Most likely a lack of protection and overall care. It also depends on the sun exposure. Peeling is the clearcoat failing, either losing its bond to the paint or wearing too thin from over-polishing or lack of UV protection. The pigmented paint (sans clearcoat) can be seen in door jams, under the hood and trunk and inside the gas and charging doors. It is dull and will disintegrate quickly if exposed to UV for too long.
  14. Mendel Leisk
    42,271
    Toyota has already admitted the Blizzard Pearl colour was problematic, on certain cars. Sadly so far, they haven't include Prius model. This is wholesale peeling, a paint fail.
  15. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Is this happening with Prius? Japanese made cars (all Toyota hybrids, I believe) don't have the "low VOC politically correct" paint restrictions that we have in most of the US now. If it is happening with J- VINs then it is of concern but if it is with North American made Toyota when so be it.
    See: The Low VOC Lowdown: The DIYer's Guide to Low VOC Automotive Paint - OnAllCylinders
  16. DC Prime
    DC Prime New Member
    Washington, DC
    2020 Prius Prime
    Looping back to the original question to add some info. I didn't get many responses about the extent to which high heat will degrade the battery. Based on some anecdotes, it doesn't appear to be significantly noticeable in the short term.
    We decided to purchase a shade sail (fancy tarp hung from fence posts to shade the car). As a temporary covering, we don't run afoul of DC regs, which is great. I did some temperature tests to try a couple different heat reducing strategies (all on mostly sunny days with temps in the 90s). If the interior got much over 120, I usually opened the windows to cool it off.
    Max interior temp of the car in peak sun:
    With sun shades only (front and rear): 120+°
    With sun shades and cracked windows: ~115°
    With a shade sail only: ~105°
    Both sun shades and shade sail: ~97°
    I'm a bit nervous about wind with the shade sail. But, otherwise, for $40, it seems a great investment. Far cheaper than tinting windows and not sure I could get peak temps much lower with ambient temps in the 90s.
    In case my nerdy tests are useful to others.
    davecook89t likes this.
  17. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Although it is a bit pricey one of the most effective ways is to get all windows tinted (including windshield) with a high quality anti-IR heat-rejecting tint like 3M Crystaline or IR Ceramic. I just took delivery 3 weeks ago and the first thing I did driving the car home from the dealer was stop at the tint shop and make an appt. I paid about $700 for the whole car but it keeps it noticeably cooler under direct sunlight here in NorCal. The windshield is probably the most important and I tinted it with 70% so it is hardly noticeable.
    With tints you usually get what you pay for. I know I overpaid compared to other areas but I'm in the most expensive cost-of-living metropolitan area of the country due to Google, Facebook, Apple, Twitter being here. Rents and home prices are crazy and labor rates follow.
  18. DC Prime
    DC Prime New Member
    Washington, DC
    2020 Prius Prime
    Curious if you have data on this to compare with the results I've gotten with other methods? On a mostly sunny day in the 90s, about how hot is the interior of the car after sitting in the sun all day with just the tinted windows (no sun shades or other devices)?
    With our sun sail and the sun screens, the interior is only slightly above ambient temperature. So, also tinting the windows wouldn't really help. But curious to compare what we've set up with just tinting the windows. If it gives comparable results and we don't need to mess with putting in the screens after every drive, etc, maybe worth it?
    I'm a data nerd, so looking for data to support my decision making. Thanks in advance!
    m8547 likes this.
  19. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Unfortunately, I don't have data and I haven't seen any in publications which have data. I can tell you for one thing, the paint color you choose is also a significant contributor because most cars have woeful insulation. All of our vehicles are white which has good heat rejection properties. If your car is already covered by a screen or roof then obviously the IR rejection is going to be insignificant. I was referring to when I have to park in direct sunlight only. It is also relevant when driving in sunlight where it (IR tint) anecdotally keeps the cabin temperature cooler and therefore requires less A/C meaning less drain on the traction battery. My car sits in direct sunlight all year so the IR tint contribution, while being unknown quantitatively, is significant. Sorry about not having data to back up my opinion.
  20. digitalundertaker
    digitalundertaker Junior Member
    17
    Sacramento, CA
    2020 Prius Prime
    I own a 2006 Highlander Hybrid and in Puerto Rico and the traction battery lasted 10 years about 135k miles. I think that average life time for them. But is hot and humid all time and I never noticed any change on battery performance until it died. I placed a dessicant near the battery per recommendation from a mechanic because of the high humidity and never placed anything covering the battery fans. Battery replacement costed $2700, moved to California and Highlander keeps going strong.
