How much did you pay for head gasket repair?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Paul Anderegg, May 12, 2021.
  1. Mendel Leisk
    41,484
    Maybe related to all that’s been done, something not connected? It’s a bit of coincidence to have it crop up right on the heels of head gasket replacement.
    Tim Jones and Samuel Williams Jr like this.
  2. Saeval
    Saeval New Member
    torrance
    2013 Prius v wagon
    Right. Shop I took it to is willing to look at replacing basically everything but the transaxle free of charge. As in they want to replace AC and inverter (again) hoping that's a solution. cause the code came up while they were working with it and not before. But yeah, they don't wanna eat the transaxle. Toyota dealership guy has been silent all day. Been trying to get ahold of him.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,161
    6,316
    Texas Hill Country
    They are looking for a high voltage leakage fault. A fault they probably caused when they were disconnecting cables.
    gggGary likes this.
  4. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    That's why I tell people Not to purchase a used Gen 3........ even though I get lots of hate comments...
    Sorry to hear this.
    Saeval and Samuel Williams Jr like this.
  5. Saeval
    Saeval New Member
    torrance
    2013 Prius v wagon
    So, took it to the Toyota dealership and they are pegging the AC compressor, which is odd, but ok. The code (I thought) pointed to potentially the transaxle. (P0AA6, subcodes 562 and 613) The Hybrid shop I took it to had replaced the AC compressor as part of trying to solve the problem and it didn't take. AC works, Toyota service guy says don't use it till its fixed. Says it'll be 3k to fix, and that I should try to talk to toyota about a goodwill service to get the price down.
    Hybrid shop says the dealership has it wrong... so basically each set of experts is pointing the finger the other way. x_o but this happened at the hybrid shop, while I was getting preventative care. I would think the Toyota dealership would've let me know of the sorry state of my hybrid system when they fulfilled the IPM warranty. (maybe that is a bit of wishful thinking)
    This could be from when the hybrid shop were swapping the engine? changing connections from the engine to the hybrid system? I'm unclear on if they would even need to touch any of this as part of swapping the engine.
    Or is it more likely the dealership messed it up when they swapped the IPM?
    #25 Saeval, May 23, 2021
    Tim Jones likes this.
  6. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    How is your engine now? Everything good with the new head gasket?
  7. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    Are you thinking what I am thinking? 2017 should have tournament style EGR passages... so HG blowing between Cylinders 3+4 instead of 1+2?
    Tim Jones and mjoo like this.
  8. Calirrm
    Calirrm New Member
    LA
    Do you have any idea how much they charge for a head gasket replacement in a 2014 Prius 4?
  9. rjparker
    10,161
    6,316
    Texas Hill Country
    Call them. Fun fact - you get better recommendations if you include info like you just bought it and the seller already changed the hg AND you include your location in Cali.
  10. Calirrm
    Calirrm New Member
    LA
    You have no need to answer anything
  11. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    your so bad............... : )
