How much does it cost per month to charge the PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priusenvious1, Jan 31, 2013.
  1. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    We redid the kitchen lighting with LEDs - they are awesome. Traded 4 75W bulbs for 7 15W bulbs - more light and less electricity
  2. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    While this is a good rule of thumb, it's not strictly true. Charging at 240V is more efficient. The losses at 120V is anywhere from 16% to 30%, whereas at 240V it's only 8% to 16%. If it's 3 kWh to fully recharge the battery on 120V, it might only be 2.5 kWh at 240V.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The # of kWh coming out of the wall into the car will be different depending on whether it's charged at 120 volts or 240, due to greater charging losses at 120.
  4. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    We are charging at 7 cent / kWh here. 21 cent for a full charge of renewable hydro power is next to nothing IMO.
    Gas price is 1.46$/Liter this week so it's equivalent to about 5.526$ a gallon.
    PiP makes a lot of sense for us with cheap electricity and expensive gas. :)
    I'm happy to give more money to Toyota and support better technology instead of wasting this money on foreign gas. And even if I do not save money in the long run, I know my money is in better hands. ;)
    Rebound likes this.
  5. RBooker
    RBooker Member
    154
    56
    Gas in our area is $3.95 we pay 12 cents per kWh. Given the recent cold snap 68:32 EV:HV ratio. While my EV range is down to 8.8 miles I am looking at a range of ~1000 miles per tank of gas.
  6. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    I wasn't aiming for the nitty-gritty. Even if 240V saves you 10% (it doesn't), that's 108 kWh/year, or about $10 ~ $15/year. Guess I'll run out to Home Depot and drop $999 on a Leviton.
    The savings of a 240V charger is that you charge in half the time, so if you re-charge in the middle of the day, you'll get more EV miles. Which is nice.
  7. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Your don't really get half the time...I see about 1.5 hrs with 240v and 2.5 hrs with 120v.
    Mike
  8. lensovet
    2,615
    496
    Burlington, NJ
    Of course, if your charging is throwing you into tier 3, 4, or even higher in CA, that savings might turn into $45-60/yr, but even then, you're right, it makes no sense.
    Though it looks like if you buy the charger through amazon, it's only $750…so your charger payback will be about on par with your pip payback…lol.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    For vehicles w/greater battery capacity (namely pure BEVs), not charging at 120 volts can make sense, from a payback POV, as has been pointed out me by a Leafer.
    lensovet likes this.
  10. El Dobro
    El Dobro A Member
    7,079
    3,259
    Home Depot sells them too.
    Electric Car Chargers - Alternative Energy Solutions - Electrical at The Home Depot
  11. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    I thought you guys up there are swimming in domestic oil and want to even export to us.:)
    So, how come it is so expensive? ;)
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think it's high taxes.
  13. RBooker
    RBooker Member
    154
    56
    Oil is a global commodity, oil independence does not equal cheap gas. The only way around that is government price controls or new large oil reserves.
  14. Zythryn
    Zythryn Senior Member
    6,408
    4,406
    Studies removing taxes from the pump price of gasoline in Canada put the cost/gallon about the same as the cost in the US.
    Oil is a worldwide commodity, the base price of it is the same worldwide. The only differences come in taxes and subsidies.
    World oil prices hasn't dropped much as North America starts producing more oil as OPEC has been cutting their production.
  15. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    There are two reasons for this price.
    First, retired4999 is right. It's expensive mostly because of very high taxes.
    Also, oil prices in Canada are not the same everywhere. While western provinces use WCS price index (Which is even lower than the WTI oil price index used in US), most of the eastern Canada oil come from Algeria and United Kingdom.
    Why price discounts for Canadian crude are here to stay | Alberta Oil – Energy Sector Insight
    http://alberta.ca/albertacode/images/Benchmark-Crude-Prices.pdf
    These countries use the European "Brent" price index. And while the WTI oil is going down, the Brent keep increasing. That's why our gas price is so high.
    There are plans to reverse some existing pipelines so we can refine western oil instead of the expensive Brent but there are big environmental opposition. (I'm not sure how pipeline transport could be dirtier than using a lot of big oil tankers from Algeria and UK but I am not an expert on the subject.)
    On the other side, expensive gas make EV and plugins cars look like very good choices considering government subsidies and cheap hydropower. It's a carrot and stick approach.
    retired4999 likes this.
  16. lensovet
    2,615
    496
    Burlington, NJ
    The reason enviros are opposed is because cheaper oil will spur greater demand. It's not clear whether the net result is a benefit or a detriment to the environment, but that's the thinking.
    It's the same reason we are opposed to the Keystone pipeline.
  17. RBooker
    RBooker Member
    154
    56
    On average tax on gas is ~50 cents per gallon of gas. In the U.S. the revenue raised is used to build and maintain roads.
    The Eason WTI price is dropping is the lack of infrastructure. The oil is stuck in the middle of the country where ther are no refineries.
    By the way the reason for Keystone was to get the oil to ports for shipment to overseas markets whch are willing to pay a premium price for refined oil. Since it looks like keystone will not be approved some are suggesting sending the oil to California. Not sure California has sufficient refinery capacity.
  18. lensovet
    2,615
    496
    Burlington, NJ
    Lol because California, a state that banned offshore drilling near its shores, is going to approve a massive oil pipeline? Yeah.
    The argument still stands. People were against it because of a) spillage risks and b) desire to reduce, rather than expand, availability of oil.
  19. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    I was not talking about the keystone pipeline but another already built Enbridge pipeline. Instead of transporting imported oil into Canada, the pipeline flow would be reversed to send domestic oil from Western Canada to consumers in Central Canada.
    Quebec ‘Non’ looms over west-to-east pipeline gambit | Toronto Star
    But I suppose it's the same kind of concerns as for the keystone project. I think it will be blocked here too. No matter where the oil comes from, it will always be dirty. But until technology evolve and everyone drive a EV, we have to choose the least worse option. If only Tesla could succeed to produce that 30K$ EV :)
  20. lensovet
    2,615
    496
    Burlington, NJ
    Right, that was my point. I brought up the Keystone project just as an example.
    Drake likes this.
