How much driving to fully charge the 12V?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Mar 5, 2021.
  1. Albert Barbuto
    Albert Barbuto Active Member
    118
    108
    Northeast USA
    Here is an 8 month old AGM, sitting after a 100ma trickle charge. IMG_2005.JPG
    alftoy likes this.
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Fact: OEM battery is not made by Toyota. Try Yuasa. Fact: Toyota service bulletin is not fact? Toyota dealer approved battery charger manual is not fact?
    So I’m to ignore my vehicle battery manufacturer recommendations for charging, and follow your recommendations.
    Maybe take your own advice. What? You didn’t like being corrected?
    #42 alftoy, Mar 16, 2021
  3. Mendel Leisk
    42,330
    Are the Owners Manual recommendations to be ignored then?
    fuzzy1 likes this.
  4. alftoy
    1,132
    519
    Looks like Toyota has suggested otherwise to the dealers, so why is the battery dealer service bulletin specific to Prius to be ignored, or the dealer recommended battery charger manual for the Prius battery?
    #44 alftoy, Mar 16, 2021
  5. pasadena_commut
    pasadena_commut Senior Member
    3,050
    950
    Southern California
    Is that a smart charger or one that forces 100mA no matter what? I ask because 100% SOC is generally shown as 13.0V in tables. Or maybe the extra .2V is surface charge?
  6. Stevewoods
    Stevewoods Senior Member
    665
    1,264
    where I am
    Just some random thoughts, as those who have been here awhile know, I am no expert, but I think I may have a valid point or two (or not).
    I believe, depending on your region, the 12v battery I buy in Seattle from a Toyota dealer well might be a different battery than someone who buys a battery from a dealer in Akron. I have only replaced my 12v once and I received a YUASA from the Toyota dealership near me. Seems people in other parts of the country had received different batteries from their local Toyota dealer.
    Makes sense. Batteries are heavy, bulky and considered hazardous material. I would assume they like to keep the supply route as short as possible.
    The whole four amps thing:
    Is it not possible that originally, the four amps charge was needed and necessary, but is it possible that battery technology has changed in the past decade and the "new replacement" batteries bought from Toyota don't have that restriction, while the batteries shipped with the original new car could not handle more than four amps?
    Meh, I am going to stick with Sam and the four amps -- not risking frying a $200 battery. But, then, I have never had to charge my battery. IIRC, when I bought the replacement from the Toy dealer about five years ago, it tested 12.4v on the bench before I brought it home.
    #46 Stevewoods, Mar 16, 2021
  7. Mendel Leisk
    42,330
    For the record, 4 amp is the 3rd gen and up OM recommendation, and for 2nd gen, OM I believe says 3.5.
    FWIW, it does NOT take tediously long, charging with a smart charger in the 3.5~4.0 amp range, anywhere between 4 and 10 hours, depending on battery condition. And it’s maybe easier on the battery.
    Stevewoods likes this.
  8. Stevewoods
    665
    1,264
    where I am
    Thanks for the correction to 3.5 amps. My memory is hazy, but since you mentioned it you may have shaken loose some brain cells and NOW, I seem to remember someone saying not to worry about the difference between 3.5 or 4 amps.....but ....I am not going to contradict Toyota.
  9. alftoy
    1,132
    519
    Manual also says only charge in an open area, not in a closed garage. Then the next page says if you are charging battery in the car, remove ground cable.
    Manual also says don’t spill water in floor or battery compartment. No recall for leaking hatch welds.
  10. Mendel Leisk
    42,330
    Yeah thanks for that check. I’m hammering away on an iPhone, and downloading the OM’s is nigh impossible. I had a vague recollection that 4th gen might have revised the max charging amps once again; but figured I’d just bluff my way through...
    To recap:
    2nd gen: 3.5
    3rd gen: 4.2
    4th gen: 5.0
    #50 Mendel Leisk, Mar 16, 2021
  11. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    My 2010 Owner's Manual says 4.2 amps
  12. Mendel Leisk
    42,330
    Thanks, revd my earlier entry. I’m currently hobbled by limited access, mostly just iPhone.
  13. alftoy
    1,132
    519
    Haha, iPhone in northern Sask as well.
  14. ChapmanF
    19,009
    I can imagine a couple things going on here. One, maybe specs getting upgraded, updates published in TSBs and tech literature, not getting updated in owners' manuals. Two, maybe audience considerations: "give those owners the 4 amp figure, keep them way out of any trouble." Or some combination of the two.
    If the roughly 45 amp-hour battery could be recharged with no losses, that would be about 11 hours at a 4 amp rate, 13 hours at 3.5, to recharge from a full discharge. But it can't be; the time required can be pushing 50% higher, so 16 to 19 or so. (That 50% higher comes from very old experience of mine; possibly newer batteries have brought that down some.)
    Also, the car itself is not very fastidious about the charging current. They may be more careful starting with Gen 4, which has a much richer collection of sensors at the battery clamp, but a Gen 3, for example, may just supply constant 14.6 or 14.7 volts for a significant time, and the current going into the battery then is whatever it accepts at 14.7 volts.
  15. pasadena_commut
    3,050
    950
    Southern California
    The "Hybrid Battery Control" manual says "9-14V" on HB-16 for that voltage over all states, car on and off. So far I have not been able to find anything in the manual about how it controls the inverter to avoid overcharging the auxiliary battery. Assuming the car actually does limit the inverter voltage to 14.0 according to battery university:
    Absorbent Glass Mat (AGM) Battery Information - Battery University
    So 2.4*6 = 14.4V and fine, but 2.25*6 = 13.5V and 2.3*6= 13.8V, so maybe borderline fine when driving in high temperatures. Somewhere or other I recall seeing that 13.8V number in Toyota documentation, but right now I cannot recall where. On Toyota's with alternators, and conventional batteries, they do take the temperature into account when setting the "12V' voltage:
    Toyota Charging System Diagnostics -
    Perhaps the Prius does as well.
  16. ChapmanF
    19,009
    Gen 3 (but not Gen 2 or Gen 1) has a temperature sensor mounted on the hold-down bracket above the battery. It doesn't seem like a good position to try to charge according to the battery's own temperature, but it is taking the temperature of the area around the battery, and there are some mentions in the manual about the Power Management Control ECU using that information to send output voltage requests to the DC/DC converter.
    Gen 4 has a whole all-singing, all-dancing battery state sensor assembly.
  17. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    While driving, I have seen all of those voltages regularly on my in-car permanently wired voltmeter, as well as 13.2V and a very rare 12.9V, and if I recall, that was a few hours into a long trip.
    #57 dolj, Mar 16, 2021
  18. fuzzy1
    10,705
    It's messier than that, it looks like it changed mid-generation. From my 2010 Prius OM:
    From my 2012 Prius OM:
  19. Mendel Leisk
    42,330
    Guess you can take 5 amp to the bank. (y)
  20. pasadena_commut
    3,050
    950
    Southern California
    Wait, you have seen 14.4V? That doesn't exactly agree with the service manual which lists the top of the normal range as "14V". The lower voltages I can well imagine as resulting from big current draws, like for the A/C compressor.
    Now I wonder how hot the 12V battery actually gets on a sunny SoCal day. There is no ventilation to speak of to its little walled off compartment. The traction battery blows out through a duct right over it, and probably with quite hot air in some instances, but the AC isn't going to do squat to cool the 12V. Even if I cut a vent above it so that it could get some air from the passenger compartment the privacy screen is usually closed in the "trunk" area, so there would be precious little cooling from the AC. Not so hard to picture driving in one direction for a couple of hours, with the sun beating steadily on that side of the car, the inverter keeping the battery voltage at close to 14V, and the battery being overcharged by up to 0.5V as a result.
