How much driving to maintain 12v?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by srellim234, Aug 18, 2016.
  1. bisco
    52,871
    sure, but it won't cure your slice.
    srellim234 likes this.
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    How did you know? I prefer to call it a power fade.
    52,871
    nothing that doesn't plague the common man. if you can control it, you're one up on me.:cool:
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The Battery Tender line has a HUGE following in the motorcycle world because, for many, riding like boating is a seasonal activity in many parts of the country. WalMart carries them. I have two and even the junior model will work on the Prius; just make sure it's a 12V model. They come with both permanent and alligator style connectors. Chargers
    I run the lead down the vent tube hole out the back for an easy, peasy connection.
    #24 fotomoto, Aug 21, 2016
    edthefox5 and bisco like this.
  5. srellim234
    1,201
    1,694
    Laughlin, Nevada
    As a follow-up, I didn't buy the charger last month since my wife added taking the Prius instead of her Yaris on her once a week commute to work in Los Angeles, 45 miles each way in rush hour traffic. Now I realize that's not going to be a long term solution since she hasn't needed it for a couple of weeks and our schedules haven't allowed the long weekend drives to see family either.
    I'm off to buy a charger.
  6. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    This is the CTEK MUS 4.3 you want. It has an AGM 12V battery setting. Amazon link, $76.
    Here's a Schumacher smart charger that is also good for wet/Gel/AGM batteries like the CTEK. Amazon link, $47. It lacks the convenient battery post connector that can be left attached at the posts.
  7. exstudent
    2,214
    906
    Torrance, CA
    Double post.
    #26 exstudent, Oct 2, 2016
