How much electric distance are the Primes getting?
Discussion in 'Prime Fuel Economy & EV Range' started by Eric Maple, Nov 17, 2016.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    100A at 12V is 1200W. A 1000W inverter that's 80% efficient will draw (1000W/.8)/12=104.2A at 12V. And since there will likely be draw-down at such high currents, it will probably be more than that.
  2. Analogkid1958
    Analogkid1958 Member
    123
    61
    Yorktown, IN
    2024 Prius
    Definitely should be its own thread...
    dalcon95 likes this.
  3. markabele
    5,084
    1,782
    Nebraska
    I agree guys...let's keep this on topic. Please.
    Son of Gloin and dalcon95 like this.
  4. Toyotaisme
    Toyotaisme Junior Member
    24
    67
    Glendora
  5. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    Nice to see SOMEBODY getting back on-topic! THANK YOU, Toyotaisme...
    ...AND thanks to those who earlier suggested we do just that!
    Prius from Dad likes this.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I give up, I would never draw 100 Amps. i don't argue with your math, it's correct. I assume that the 100 A fuse is still in the Pos Post on the 12V Battery. why would I want to blow that? The car would then be inop.
  7. markabele
    5,084
    1,782
    Nebraska
    Dude, your comprehension skills don't seem to be working. Everyone here wants to be on topic besides you and maybe one other. Please don't be selfish.
  8. Andyprius1
    2,327
    859
    Cool CA
    At 100 Amps, you blow the fuse. that would be insane of anybody to put such a load on the inverter. 110 volts times 100 Amps = 11000 Watts 11KW ! Your concept is absurd. Again discussing a ONE KILO WATT
    INVERTER.
  9. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Still only getting 36 EV mile range. It is hard with hills in the area and rain makes it hard because I need to run the eco defrost to defog my windshield because of the humidity. Then the puddles in the road slow down the car too. 36 EV mile range isn't bad. I wish I could achieve 42 EV mile range in order to get a one charge trip! I'll keep trying!
    #1 in Easley,SC
  10. Lee Jay
    5,850
    4,036
    There's no fuse. If there were, you couldn't jump-start anyone's car. But you can, and I have.
  11. Andyprius1
    2,327
    859
    Cool CA
    Dude ! I apologize, but am sure the moderators will move it to its own thread.
  12. dalcon95
    512
    653
    Has anyone achieved a 42 EV mile range? Are any dudes getting near this distance? I know using the car as a generator isn't going to get you anywhere near that being parked. Lol
    #1 in Easley,SC
    #212 dalcon95, May 20, 2017
  13. Andyprius1
    2,327
    859
    Cool CA
    Thank You for this vital piece of information, please inform Toyota that thier 12 V Battery is unprotected.
  14. Lee Jay
    5,850
    4,036
    There's no need to protect the battery from over-current.
    Jump-starting a car can easily draw 400A.
    What has to be protected is the wires between the power supply and the battery, and the power supply itself. It is likely current-limited and fused. But that doesn't mean you can't draw a lot more from the battery terminals than the power supply can provide, it just means that the battery is being drained at a rate equal to the draw on the battery minus what the power supply is providing.
  15. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Thread=Hijacked.
  16. Lee Jay
    5,850
    4,036
    I'm not going to allow someone to put out false information without answering it. If I did, someone later could stumble upon it and (for example) incorrectly determine that you can't jump-start another car from a Prius - something I've done several times.
  17. Andyprius1
    2,327
    859
    Cool CA
    The Prius battery is rated at about 35 amps, you can tell this from its smaller size. Attempt any kind of draw for any reason and you will burn the battery up! This is why Toyota does not recommend jump starting a larger ICE vehicle. If you want to attempt a 400 ampere draw, be my guest.
  18. Lee Jay
    5,850
    4,036
    You really should stop talking about things you know nothing about, which appears to be about everything when it comes to electricity.
    "CCA 295A". That's cold ("Cold Cranking Amps") and it will do about double that when warm.
  19. markabele
    5,084
    1,782
    Nebraska
    Wow...selfish and lazy. Can't even take the initiative to start their own thread.
  20. Andyprius1
    2,327
    859
    Cool CA
    Thank You Page 697 of the owners manual confirms your specs. I was still using information from my 2005.
    I did not realize that the warning Not to jumpstart a ICE vehicle was no longer included. I still will not do it.
