How much electric distance are the Primes getting?
Discussion in 'Prime Fuel Economy & EV Range' started by Eric Maple, Nov 17, 2016.
  1. benagi
    benagi Active Member
    525
    280
    Utah
    My best this month so far has been 37 miles on EV.
    HPrimeAdvanced, heiwa and markabele like this.
  2. Cpu888
    Cpu888 Junior Member
    New york
    2020 Prius Prime
    I'm in NYC. Got prime premium for 5 months now. 95% jamed expressway at 15mph daily commute. Full charge for 30 miles in winter. Now at 70 degree I got around 39 or 40 miles per charge. Only used gas when travel outside new York. The displayed mile per kwh is now 4.8
    breakfast, heiwa and markabele like this.
  3. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    I hit 39.4 Actual EV miles yesterday, with 38.5 showing up on the Guess-O-Meter this morning. Getting oh so close to the 40 mile EV club :)
    HPrimeAdvanced and heiwa like this.
  4. Rikku
    Rikku New Member
    Atlanta
    2018 Prius Prime
    Started with 25 miles. Now I am consistently getting 30+ miles.
    It's about 5 mile/KWh = About 2 cents per mile (@ 12 cents / KWh)
    On HV mode I get 65 MPG = About 4 cents per mile (@ $2.76/gallon)
    Both are impressive numbers.
    breakfast and HPrimeAdvanced like this.
  5. markabele
    5,084
    1,782
    Nebraska
    I didn't realize the Prime had a mile per kWh readout. What are most people seeing for their average?
    HPrimeAdvanced likes this.
  6. ElectricSpike
    ElectricSpike Member
    98
    74
    SouthOfBoston
    I'm getting about 30 around town. Yesterday I was stuck in the 93 Ted Williams tunnel on the way to the airport to pick up our daughter - this is in Boston - I was in that $%^& tunnel for over an hour. It should take 5 minutes. It took me about 2.5 hours during rush hour to drive 21 miles (and drove 4 miles in the morning). With lights on, slight cooling, radio on to try and figure out what was going on/calling daughter, I made it all in EV mode. Most likely because I was going 0 mph much of the time, with my foot on the brake. THAT is the good news from that trip. If it had been an ICE engine, that would NOT have been the case.
  7. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    The past several daily mi/kWh readout have been between 5.0 and 5.2. If I keep that screen on the display, it starts off low like around 4, but after 4-5 miles it seems to stabilize around 5ish.
    I expect the number to be a bit higher in warmer weather, or if my trips were over my average of 9 miles when the battery is up to temperature (my morning outside temperatures are still usually in the low 50s).
  8. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Dynamic cruise control works well in situations like this. You don't have to hold down the brake pedal and go forward by hitting accelerator or hit resume.
  9. CraftyCoder
    CraftyCoder Member
    48
    65
    Washougal, WA
    2018 Prius Prime
    I am seeing a pretty consistent 3.9 mi/kwh. My commute has almost constant up/down hills both ways.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I have taken a lot of flack over the years from some when pointing out how not all EV is equal. There are a few plug-in vehicles that guzzle electricity in comparison.
    This is proof of that... and confirmation of how efficient of a system Toyota delivered.
    breakfast, HPrimeAdvanced and heiwa like this.
  11. ElectricSpike
    98
    74
    SouthOfBoston
    I thought you need to be going over 25 mpg in order to activate it?
    The traffic stopped suddenly on the ramp, then it was stop...go 1 mph. Stop..........go 1 mph.....stop....swear.....repeat. I just figured out that it wasn't quite the Ted Williams Tunnel - It was on the feeder tunnel/road to 90 "East" - under Fort Point Channel, then you are fed into the Ted Williams Tunnel. There were two lanes in this feeder tunnel; the lane on the right goes into Boston; the lane on the left towards the airport.
    For those of you more visual people, the following YouTube video:
    I was in sitting traffic from about 1:00 to 1:19 - that part took me well over an hour. Then onto the Ted Williams Tunnel and the airport.
    Dynamic cruise control won't work in this type of traffic, will it?
    The main point being that my full electric charge lasted the 2.5 hours it took me to make the 19 mile or so trip, plus the 4 miles to get to work in the morning. I was impressed. I thought it would deplete the charge considering all the electrics, some climate use, etc.
  12. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    >Examples of the 'flak'?
    >>Examples of the vehicles?
    Of course a 5000 lb. Tesla is going to require more electrons to roll down the road. Nature of the beast.
    But what about other PHEV's and BEV's.
    Can you point to the "Guzzlers"?
    Is there a list of average kWh/mile for EV vehicles?
    (Average is a strange thing since everyone drives differently and lives in different climates.
    These numbers swing with the seasons.)
    Also some PHEV and BEV vehicles have full featured TMS to keep the battery temp happy.
    And some have just a fan to waft cabin air over the cells. And some don't even have that (Leaf).
    So at the sake of battery pack life, some EV's use more 'Wall to Wheel' power for TMS (when required).
    However, 'Battery to Wheel' numbers may be very similar.
    It probably comes down to weight and aero of the different EV cars.
  13. Tideland Prius
    16,683
    It should but just be aware of the merge point at 1:19...It may cancel or act differently.
    ElectricSpike likes this.
  14. DavidA
    2,349
    1,825
    Chicago western burbs
    Near 4.0 in winter, and up to 4.8 in better weather. Not too shabby, compared with Teslas, but then Teslas weigh a couple thousand pounds more.
  15. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    My wife and I are usually in the range between 5.2 to 6.2 depending heavily on traffic, destination and wind direction.
  16. john1701a
    12,840
    5,312
    58
    These are among the more efficient, since the minivan & SUV choices are larger & heavier:
    31 kWh/100 mi = 2018 Chevy Volt
    30 kWh/100 mi = 2018 Nissan Leaf
    28 kWh/100 mi = 2018 Chevy Bolt
    28 kWh/100 mi = 2018 VW e-Golf EV
    28 kWh/100 mi = 2018 Hyundai Ioniq PHEV
    26 kWh/100 mi = 2017 Toyota Prius Prime
    25 kWh/100 mi = 2018 Hyundai Ioniq EV
    heiwa likes this.
  17. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks. That's very good data to have for a potential PHEV or BEV buyer.
    This shows a max of $0.75 difference best to worst for a 100 Mile trip, ($0.125/kWh)
    Although as said, these numbers change seasonally. (Where did this "average" come from?)
    I assume this is 'Battery to Wheel' measurements.
    If it's 'Wall to Wheel', that's even better!
    This is info needed to calculate TCO.
    Keep in mind some of these PHEV's may run the engine if you are not gentle on the GO pedal.
    Some still require 10k oil changes, regardless, and don't consume power with a proper TMS for a long-life pack.
    And then there are EV performance factors, like fun !!
    There are many aspects that can't be factored into a TCO calculation.
  18. Yankee3
    Yankee3 Junior Member
    17
    Bartlett TN
    It's full fledged summer in Memphis. I live in the suburbs with temps around 90 and the car is showing about 33 miles on full charge and real miles of 30 miles in eco mode driving city miles, no highway speeds. Enjoying my 8.5 cents/kwh cost which translates to about 53 cents to charge and translates to 141 mpg. gas equivalent at gasoline prices of 2.50/gal. Enjoying my ride with few exceptions except for not being able to monitor my tire pressures.
    EazyPeazy and bisco like this.
  19. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I monitor tire pressure with my scan gauge II.
  20. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    I’ve been getting 32 miles on last couple charges. Real world of 30 non highway miles. Pretty consistent. Mixed temps of 50’s-60’s in the mornings. Just finished my second full tank of gas. Combined mileage:
    14EFCD7F-DAC8-444B-B6AD-CB144EB3E78C.jpeg 4F858006-A766-4468-AD3E-82749959A0A4.jpeg
    I didn’t wait for low on fuel indicator. Wonder if filling up sooner is better. But gas has gotten more expensive here in NY. Now at $2.97/gal.
