How much electric distance are the Primes getting?
Discussion in 'Prime Fuel Economy & EV Range' started by Eric Maple, Nov 17, 2016.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Is this ICE firing due to low miles left on the estimate plus higher power demand?
    52,828
    is the steering wheel heater worthwhile? do you need to remove your gloves to appreciate it?
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    DO remember, as per the owners manual, to put in at least 20 litres (5 1/4 US gallons) per 6 months. So letting the car consume some fuel is probably a "good thing (tm)". ;)
    bshef and Andyprius1 like this.
  4. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Doubt it, I still had 10 miles available last time. I think it is the hill and power requirements at the time. I have yet to get all the way up the hill without the ICE coming on.
  5. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Too hot for me.
    I have to pulse and glide with the heat button.
    EV-ish, ruby and bisco like this.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    My charge is up to 30.5 miles now.
    JacksonMs and bisco like this.
  7. Andyprius1
    2,327
    859
    Cool CA
    Turn the engine on in the beginning then.
  8. bisco
    52,828
    isn't this counter to what most are saying? are you sure you're not in ev auto?
  9. Andyprius1
    2,327
    859
    Cool CA
    In ref to your last sentence. The engine has a specified warm-up time, therefore warm the engine up at the best terrain and time of the trip, allow you and your passengers to be comfortable the whole trip. Possibly when you arrive home and tackle that hill you would now have enough charge to make it all the way.
  10. bisco
    52,828
    i thought ev mode stayed in ev, even at full throttle?
    JacksonMs and bodgm like this.
  11. Captmiddy
    225
    204
    Massachusetts
    I think it does, I am not sure what is triggering my car to turn on the ICE. Today (EV Mode not EV Auto) I was going down hill again slowing down. It is a big hill and from top to bottom I went from 65 to 0MPH, about 3/4 the way down, the engine came on. No idea why or what triggered it. Had EV range of 13 miles left. Once I got to 0MPH, I turned the car off, turned it back on, EV mode was active, ICE didn't turn on again the rest of the way in. Absolutely no idea why it would do this. Car hadn't gone 200 miles since last time ICE was on so it wasn't a random turn on to cycle the engine. It hasn't been a big enough issue for me to decide it needs to be looked at yet but it doesn't seem to make sense.
    I can confirm that at full throttle the ICE will come on eventually if it detects you are looking for more power than the motor can achieve. So if you are trying to accelerate up a steep hill and you have used all the power the motors can provide, it will kick in the ICE even if you are in EV mode. At least this is what has happened to me repeatedly, not sure it should happen this way. I know that the ICE doesn't provide a ton of extra horses, but there is definitely a benefit in higher speeds where electric motors don't have as much torque.
    Once the car becomes more common and dealers have them in stock, I may go by my service dealership and ask to test drive another charged Prime down that same road just to see if what I am seeing is consistent with another vehicle. What is funny is last time I had to use HV to go over this hill (because I hadn't charged the night before due to my circuit popping), it went into EV mode going down the hill on its own which is what you would want it to do.
  12. bisco
    52,828
    i wonder if it was charging faster than the battery could accept it?
    when you're going up the hill, does it come on if you don't quite floor it?
  13. Captmiddy
    225
    204
    Massachusetts
    Yes it does, about 3/4 the way up. If I really punch it the engine comes on about 1/2 way up.
  14. KyLien
    KyLien Junior Member
    27
    35
    Whittier, CA
    Getting around 37 in hilly city driving.
  15. bisco
    52,828
    wow, that's fabulous!(y)
  16. bisco
    52,828
    baffling. are you seeing anyone else posting similar?
  17. Swauger
    Swauger Member
    37
    35
    PA
    That's impressive. My wife's Prime is only getting 22. Hopefully, once it warms up around here in north east PA the range will increase.
  18. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    Interesting......Gas does have a shelf-life?
    Does the car's computer recognize and have any counter-measure's for this?
  19. Tideland Prius
    16,678
    Yes. The owner's manual recommends refuelling at least half a tank every 12 months. The car will remind you to refuel if you haven't done so in a while.
  20. Captmiddy
    225
    204
    Massachusetts
    I have not seen anyone else post about this, and thus I am hoping to eventually try another Prime on the same loop and see if it behaves the same way or if it is really my car that is doing this. It is at least consistent so it would seem that it is expected behavior from the car rather than a true anomaly but that doesn't mean that it isn't wrong expected behavior.
