How much energy is actually regenerated?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by GregP507, Jun 24, 2014.
  1. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    2013 model here. I recently drove a 400 mile trip where I 'saved' most of my EV miles for the end of the trip where I expected to hit traffic. This meant I had about 8 miles rated EV displayed for most of the trip. With much of the trip rolling hills, I was able to regularly regen to 10 miles or so. If I switched to EV while at 10 miles, then back to HV, it did not use 10 miles as the new set point. It always used up those miles in HV mode and I arrived in the destination city with about 8 miles of EV.
    Was this above the 75% magic number or something?
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    This is how I "trick" the PiP into getting over 100 mpg on a 45 mile commute with only one charge (and why my estimated EV range when starting is at 21.4 miles). I always switch to EV mode when going downhill or braking. I accumulate the EV range and use it on parts of the commute where there's slow, but steady traffic. I can build up an extra 5 - 7 miles of range this way. If I just drive it without thinking about anything I can only get about 80 mpg on the same commute.
    markabele and Tracksyde like this.
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    And I did check. Going downhill at 50 mph, the regen area of the HSI 80% full, there was no friction braking but lots of nice regen.
    Astolat likes this.
  4. GregP507
    GregP507 Senior Member
    3,002
    481
    That sounds like 80% as far as the battery. After that, there are still more conversion losses to get it to the wheels.
  5. CaliforniaBear
    1,180
    289
    Northern California
    The 80% is about the HSI display not anything to do with efficiency. The "experiment" was to see if the friction brakes came on which they didn't. They only seem to be engaged in a near panic stop, like the gas guzzlers use most of the time.
  6. CharlesH
    2,798
    1,166
    Roseville, CA
    And the regeneration on the PiP can absorb more power than the standard Prius, due to higher capacity components and the LiIon battery chemistry.
  7. GregP507
    3,002
    481
    Unfortunately, when the battery is full, the excess doesn't get converted to gasoline. o_O
    CaliforniaBear likes this.
  8. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    But it could be converted to mirowave to powerup the photon torpedoes.
    A few weeks ago I noticed while going across a millon year old dried up river bed that is about a mile wide I guess, that in ev, coasting down one side I gain 1/10 mi ev range. Getting up the other side I loose 1 mi ev range
    Not sure if that helps or complicates things more.
