How much gas does it use to warm up the ICE?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Dec 7, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I have wondered that before purchasing my PiP and I am sure there are many others in the same boat as me.
    I figured out a way to measure it. PiP provides a summary of the trip every time you turn off the car. It has the number of miles traveled and MPG for that trip. Pure EV trips will show 999 MPG.
    In order to measure gas consumption during my usual 2.0 miles trip, I forced the gas engine to start by turning on the heater. I immediately turned it off and let the ICE complete the warmup process. Once the engine coolant reaches about 130 deg F, ICE turned off. At the end of my 2 miles trip, I got 68 MPG.
    2 miles / 68 MPG = 0.0294 gallons = 111 ml
    Another data point is a 12.9 miles highway trip. I drove 12 EV miles before ICE kicked in. ICE was warming up for the last 0.9 miles and shutdown (reached 130 deg F) before I rolled into my garage. On that trip, I got 369 MPG. I also noticed the battery state of charge raised from 23% to 25%.
    12.9 miles / 369 MPG = 0.035 gallons = 132 ml
    To put the amount of gas used in perspective, I thought of using everyday household items to compare with. Inspired by the picture of the Power Split Device next to a soda can, I came up with this.
    Two jumbo eggs are ~140 ml.
    john1701a, mnml, lensovet and 4 others like this.
  2. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    There is a way to reduce the amount of gas used further, by entering the ECO mode. In that mode, ICE should shutdown at 110 deg F.
    mnml and lensovet like this.
    52,915
    i also have been wondering this. some have said 1/50 of a gallon per mile, but this doen't work on a cold ice. i'll have to give it a try. thanks usb!
  4. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    I assume the lower the external temperature, the longer to complete the warmup. The coolant requires more calories and more calories are simultaneously lost through the radiator (unless the thermostat totally blocks circulation). I suspect the real answer to your question will require an ambient temperature factor.
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yea, that's a great point. I parked my car in a warm garage so it starts out around 70 deg F. That 12.9 miles trip was driven in low 40's outside temp.
    If you guys have more data, please post. It'll be interesting.
  6. jmlarence
    jmlarence New Member
    27
    Rhode Island
    Great stuff usbseawolf2000. Logged in just to say "thanks!" Have been wondering about that consumption for the past week.
  7. lensovet
    2,615
    496
    Burlington, NJ
    Well, that completely removes any qualms i had about flooring the car in EV mode, i guess. lol.
  8. Adam Leibovitch
    498
    102
    The car is much more enjoyable to drive in floored EV Boost mode. Its worth every milliliter.
  9. bisco
    52,915
    i went out for a test drive tonite. fully charged battery, 45 degrees out, light rain/mist. headlites on, no heat, etc.
    drove 7.2 miles on ev, went into store for 10 minutes. came back on ev until the ice kicked at 12.4 miles. ice ran for 2 miles and shut off. got home at 14.4 miles. 326 mpg over 14.4 or 162 mpg over 7.2 on the return when the ice ran. using above calculation, 14.4/326 = .04417 7.2/162 = .0444 so it looks like the ev miles affect gas quantity equation?
  10. Adam Leibovitch
    498
    102
    Hi. So did you drive while the ICE was warming, or you waited until after the ICE was done warming before you started the trip?
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I drove while ICE was warming up for that 2 miles trip. The route has red lights and stop signs.
    Adam Leibovitch likes this.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Bisco, i wouldn't worry about 2 microliter difference.
    lensovet likes this.
  13. bisco
    52,915
    so, .045 is about 1/25th of a gallon or about 50 mpg?
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    :D
  15. Adam Leibovitch
    498
    102
    Thanks I was wondering if the driving could be what accounted for the differences. But I should have measured my coolant temperature, thats an important input it seems. Probably why I was 0.035 and bisco was 0.044, my car had been parked outside in high 50 to low 60 degree temperature.
  16. bisco
    52,915
    my ice comes on for 2 miles on my commute, if i don't charge at work. that would be one gallon every 5 weeks!
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Bisco, 2 miles / 0.0442 gallons = 45 MPG. Do you know the battery SOC betore you shut it down? EV mode ends at 23% so extra energy might have went into the battery.
  18. bisco
    52,915
    the hv portion was about half full or 5/8. the ice was off when i pulled into my garage.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Ok, so you used some of the HV portion.:)
  20. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Bob Wilson figured out the warm-up fuel consumption by the ICE in his G3 Prius; I imagine the same for the PiP. I have always thought the tricky part is taking into account that fraction of ICE energy that ends up in the battery, but I trust that Bob took that into account.
    I suspect USB would end up with a more accurate result if he:
    1. Started a drive from a full charge;
    2. Forced an ICE warm-up after a couple of miles of EV driving (so that there is room);
    3. Drove until EV was depleted and the Prius decides to turn on the ICE
    3a. Stop the car at (3) and calculate.
