How much of a hit can I expect to get from ultra high performance summer tires?
Discussion in 'Gen 2 Prius Fuel Economy' started by sabbosab3354, Jul 10, 2011.
  1. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    That is the idea of the coolant being stored in the thermos, is it not? Hal
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    It is but I have read that the car still goes through its warming stages regardless. I could be wrong on this though.
  3. aginzu
    aginzu New Member
    Aptos, CA
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yeah. It still seems to, although maybe not for the full 56 seconds after ICE ignition. I think the engine already being warm and the thermos helps.
    Today, IIRC, FWT was above 180 F, I had to stop and power down. I came back out a few minutes later to power back up and go. FWT was still up there but I saw it going thru stage 1a (negative IGN values).
  5. Hal W
    Hal W New Member
    872
    53
    Oh, that is interesting! So I guess there is a bit of a hit.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    It's probably a minor hit but do it enough times and it could add up to a big hit. It's worth checking out. :)
  7. sabbosab3354
    sabbosab3354 Junior Member
    m
    Well, it looks like I'm not getting much of a hit from the tires as I thought. When I started making my commute, and altering my driving style to better take advantage if the drivetrain, MPG jumped into the 50's.
    Thanks for all of the help :)
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Now imagine what you would have got with LRR tires of the appropriate size. :)
  9. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Here is what 101Tires.com shows for the size difference.
