How much power Prius EVSE takes when idle?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Apr 22, 2013.
  1. Francos
    Francos Member
    118
    Nissan's EVSE takes 3W when idle. Any one know the number for Prius EVSE? Do you unplug your EVSE?
  2. mrbigh
    3,686
    699
    Long Island, NY
    The power consumption while at rest it's negligible, why to bother?
    In order to make a real difference, you should disconnect ALL Pwr Transformers from the wall( phone chargers as an example) to start seeing a difference in the electrical meter in a months time.
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    Add to that cable boxes, TVs, video recorders, stereos, microwaves and anything else not used all the time and watch how fast the consumption drops. I put a lot of stuff on power strips to offset the PIP charging and my electric bill dropped $5-$6 a month, even with the car charge. :D
    mrbigh likes this.
  4. mrbigh
    3,686
    699
    Long Island, NY
    As recently stated, you should commit yourself to some sort of inconveniences in order to see a savings:censored:
  5. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    The killawatt meter we use isn't really accurate at low figures, but it indicates about 1-2 watts when not charging the PIP. If I'm taking a short trip and will return in under an hour- I don't unplug the EVSE.
  6. 3PriusMike
    3,101
    2,421
    Silicon Valley
    It is 1.4 watts for the EVSE in standby mode.
    If you charge for 3 hours then leave the EVSE plugged in the other 21 hours of the day (instead of uplugging it), then you will be consuming ~3 kw-hrs for the car and about 30 watt-hrs for the EVSE or about 1% extra. Of the 3kw-hrs about 300 watt-hours is lost to waste heat when charging the battery.
    Mike
