How much should I be paying for a 30k service?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jmaliakal, Mar 31, 2014.
  1. jmaliakal
    jmaliakal Junior Member
    Massachusetts
    I called my dealership to schedule the recall service for my 2010 and an oil change. The service rep said I was at ~30k miles and recommended a $225 service package ($205 after a coupon). This seems pricey, but I'm still used to not seeing the bill after having two years of ToyotaCare, so I might not know what to expect.
    I got new tires ~6mo ago, and a wheel alignment was part of the installation package. It seems like cabin and engine air filter replacements are reasonably easy.
    Is it worth getting the service package at the dealership?
    edit: If not, where's the best place to get the necessary parts? Online or in-store? And any recommendations for filters/windshield wipers would be great!
  2. chronart
    chronart Junior Member
    During the recession they all started raising prices for service since they were selling so few cars, but now they sell more cars and continue the high labor rate and parts markups. So there are a lot of lower cost options in most towns. It is sort of like Starbucks Coffee. I just go to my local gas station for a shot of hazelnut, a shot of chocolate and fill up 24 oz cup that I refill for $1.09.
    Then there is my friend who phoned two days ago in a panic that all his warning lights for his 2005 Prius just came on. He went to a cheapy service place who had installed a belt wrong two days before and the new belt was in shreds. Total incompetence! So try to find someone who was trained at Toyota, but now has his own business. Good luck.
  3. frodoz737
    frodoz737 Top Wrench
    4,812
    2,564
    33
    They likely just quoted you a high dollar oil/filter change, washer fluid top off with quick inspection to profit while you are there for the recall, which Corporate Toyota compensates very little for.
    Now if you were getting an oil/filter change (Toyota 0w-20), transmission fluid change (Toyota WS ATF), antifreeze/coolant change (Toyota SLLC) and brake flush (Toyota DOT 3), it would be a good price. But that usually goes for $350 plus.
  4. jmaliakal
    Massachusetts
    For what it's worth,
    they charge ~$110 for the 5k service:
    • Check installation of driver's floor mat
    • Inspect/adjust fluids
    • Inspect battery and terminals
    • Inspect cabin air filter
    • Inspect engine air filter
    • Replace engine oil/filter
    • Rotate and fill tires
    • Clean A/C drains
    and the 30k service adds an additional inspection for a total of $225 (including the above):
    • Fuel lines and connections
    • Fuel tank band and fuel tank
    • Fuel tank cap gasket
    • Radiator and condensor
    • Steering gear box
    • Steering linkage and boots
    • Transmission fluid
    • Ball joints and dust covers
    • Brake lines and hoses
    • Brake linings and drums
    • Brake pads and discs
    • Drive shaft boots
    • Engine coolant
    • Exhaust pipes and mounts
    • Front differential oil
  5. JC91006
    16,939
    8,647
    If I were in your shoes, I would personally just get the oil change. You can ask them what services are provided for the $225 they are charging. I would suspect they would only be changing out the air filters for you in addition to the oil change. The air filters you can get yourself for about $15 each. (cabin and engine).
    At 35,000 miles, I would bring it into the dealership once more for another oil change. I know the car has 10,000 mile Oil change intervals, however your bumper to bumper warranty ends at 36,000 miles and I would bring it in for an early oil change to get a final inspection before warranty runs out. At 35,000, I would have them do an inspection on everything on the car, make sure everything is in order (shocks, suspension). If anything is not up to par, have them replace it under warranty.
  6. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Did they tell you what they are offering in the "service package"? (If the words are capitalized it would no doubt cost more.)
    Okay, I see it was explained.
  7. JC91006
    16,939
    8,647
    Wow, no air filter changes for $225. That's a shocker!!!
  8. jmaliakal
    Massachusetts
    To clarify, you get everything in both lists for $225. The top list is the 5k (10k for synthetic) service, the bottom list is an additional inspection for the 30k service
    The car is almost 4 years old, so it's out of warranty
  9. jmaliakal
    Massachusetts
    I checked another Toyota dealership in the area and they're charging about the same amount ($10 less)
    So I'm not sure whether or not it's reasonable
  10. JC91006
    16,939
    8,647
    I read both lists and there isn't a listing for engine or cabin air filter change. Only an oil filter change and a bunch of inspections.
    My experience with dealers, even if I went in for just an "oil change" only, they would charge me the oil change price and still do the inspections for me. The inspections is where they point out problems and will advise for you to fix them for more money. That service they have provided even if you don't ask for it.
  11. JC91006
    16,939
    8,647
  12. jmaliakal
    Massachusetts
    lol that's where I have my service booked tomorrow afternoon. I think I'll just have my oil changed then. Thanks!
  13. JC91006
    16,939
    8,647
    The dealer has coupons on the website, next time you go, just print out a coupon. The $79 oil change comes with a tire rotation too.
  14. frodoz737
    4,812
    2,564
    33
    Forgot the tire rotation, but like I said, "overpriced" oil change, washer top off and inspection. I dropped a hint, take it leave it. Happy motoring. ;)
  15. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I recently was told by toyota that our camry hybrid 30K service would be a minimum of 350. I looked at the service reccomended in the owners manuel. It seems that it is just a oil change with check of the air filter and cabin air filter. So I took the car to Oil Can Henrys and changed oil for 40 and went to local parts store to get engine and cabin air filters another 50 or so. I went to youtube and watched a video that showes how to change these filters. they are very simple and it takes only a couple of miniutes to do. I think I saved my self $300+. having service done at the stealership is a waste of money IMO
  16. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    The 30K service is on your wallet, not the car.
    csp1971 likes this.
  17. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    The 30k service is only this:
    Oil change
    engine and cabin air filter replace
    and tire rotation
    The rest are just inspections, which you don't really need or you can do it yourself.
    My vehicle has 45k miles and I recently took my vehicle to the dealership for that Safety recall, that's it. Everything else, I just do my own oil change every 10k miles, change my engine filter every 30k, cabin air filter every 15k, changed my transmission oil at 30k. Nothing special.
    Its better to save that money and do it yourself.
    jmaliakal likes this.
  18. jmaliakal
    Massachusetts
    I've been watching your videos on Youtube, and they're very informative! Thank you!
    I'd love to do my own oil changes, but I don't have the space at the moment to store the jack/jack stands. I do plan on changing my engine and cabin filters myself (thanks to your videos)
    edit: any filter recommendations?
  19. NutzAboutBolts
    1,756
    1,789
    Bay Area
    I don't have any filter recommendation since I've been using the Toyota filters. I have tried Auto Zone engine and cabin air filter as well, they weren't that bad.
    thanks for watching our videos! :D
  20. PosauneGuy
    PosauneGuy Member
    124
    91
    California, here I come...
    2025 Prius
    I just took my 2011 Prius in for 3 year/30k service. The local dealer gave me two options: $90 for the traditional 5k service (oil change, rotate tires, multipoint inspection) or $270 for the 30k service. I opted for the $90 service, figuring the multipoint inspection is fine for me.
    I just also want to say that yesterday my car turned 3 years old; warranty now officially expired. This is the first car I've ever owned that did not have a single warranty issue! (y) (Now that I said that, it will probably break down tomorrow!)
  21. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I've been doing my own oil and {oil, cabin, engine} filter changes, etc. The nearby dealers are happy to do a free inspection, with the hope that they'll find something to bill me for. So far, they haven't...
