How much should the 100k service cost?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brad K, Jun 26, 2019.
  1. Brad K
    Brad K Member
    173
    53
  2. Mendel Leisk
    42,355
    I'm gonna play Dutch uncle:
    How about, for an exercise: list what's involved, per the US Warranty and Maintenance Guide. There's a fair bit of fluff, so just list what you think is crucial. Maybe at the end of that exercise you'll have a ballpark number.
    roadrunner, Raytheeagle and bisco like this.
  3. Brad K
    Brad K Member
    173
    53
    Check installation of driver's floor mat
    Inspect and adjust all fluid levels
    Replace engine oil and oil filter (0W-20)
    Replace engine/inverter coolant
    Rotate tires
    Visually inspect brake linings/drums and brake pads/discs
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    There's a lot of wiggle room on that list.
    By now you should understand that dealers have figured out that you want the convenience of asking for "the (rounded off odometer) service" and they have put together packages that include everything the car actually needs plus 7 or 8 very simple, ultra-high-mark-up services that would sound good anytime.
    If you just ask for the actual service listed in the book as a la carte items, you'll save.
    If you take the time to inspect (and have the experience to judge results) for the fluids & brakes, you'll save even more.
    Walk in blind and ask for that "100k service" and you're probably looking at $800+. They'll do extra stuff, some of which will be nice, but none truly necessary.
    • Check installation of driver's floor mat
      • Free- safety related.
    • Inspect and adjust all fluid levels
      • You're alreading going to pay them to change the coolant and motor oil. Washer fluid, Brake fluid and ATF are the only others in the whole car. This is an opener to get you thinking about brake fluid flush- which might be legit for age and usage.
    • Replace engine oil and oil filter (0W-20)
      • Same as any other oil change you've paid them for. Should include the tire rotation.
    • Replace engine/inverter coolant
      • I don't know what they're charging for these two simple and related services but $200 wouldn't shock me.
    • Rotate tires
      • Under $20 if a la carte, but probably included in oil service.
    • Visually inspect brake linings/drums and brake pads/discs
      • Does your state require this for an inspection sticker? Many do. It's possible you already paid somebody else for this same inspection recently. It's trivial to do once the wheels are off, and they're already coming off for the tire rotation. Mostly an opener for brake service. Probably not needed this early but it is possible, and I'd expect around $300 per axle if you hired the dealer to do it.
    roadrunner and mikey_t like this.
  5. bisco
    52,863
    $200.
  6. Mendel Leisk
    42,355
    I''ve crossed out the fluff. A full brake inspection, is not fluff. But the "visual" inspection (every 5K), that's fluff:
    There's a footnote "3" beside that item, which leads to this:
    So essentially, an engine oil and filter change, tire rotation, and engine coolant change.
  7. Brad K
    Brad K Member
    173
    53
    they charge $20 for tire rotation, $69 for oil change and tire rotation, so its really the coolant replacement, how much should the dealer charge?
  8. Mendel Leisk
    42,355
  9. bisco
    52,863
    why does coolant drop to 50k changes after the initial 100k?
  10. Brad K
    Brad K Member
    173
    53
    good question
  11. Mendel Leisk
    42,355
    Honda's like that too. I guess as the system ages, crud builds up faster? It gets them both in sync, anyway.
  12. Brad K
    Brad K Member
    173
    53
    they quoted me at $419, so $350 for the coolant replacement
  13. bisco
    52,863
    yeah, dealers can be tough like that. any others you can shop? i would just tell them what specific services you want, don't mention 100k.
    Brad K likes this.
  14. bisco
    52,863
    otoh, their prices for oil and tires seems very reasonable
    Brad K likes this.
  15. Mendel Leisk
    42,355
    Ask them if they were planning to do the inverter too? It's pretty deceptive: if you read everything but the footnote, you figure you have you're marching orders. It's poorly worded.
    Up here, there's no mention of a longer inverter interval in the documentation; both are supposed to be changed at 120 mo / 160000 km, thereafter every 60 months / 80000 km. Except: there's a sticker on the inverter reservoir, that says this, lol:
    Brad K likes this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    There’s only one Dutch uncle around here and he usually resides in te c forums:cool:.
    But I have seen some “ignored” posts in other forums recently:oops:.
    None on this thread yet(y).
  17. onabuc
    onabuc Junior Member
    loa angeles
    Oil change....coolant flush...transmition oil change....spark plugs...
    Thats the more important at 100k
  18. onabuc
    loa angeles
  19. Mendel Leisk
    42,355
    Spark plugs, at least according to the schedule, are later. Maybe 120k miles??
    Transaxle fluid change is at owner's discretion; Toyo says nothing about it.
  20. egn83b
    egn83b Junior Member
    59
    Rarford nc
    I did my own 100k service myself saved time and didnt have to deal with dealer fluff. I changed my plugs, drained my coolant and cleaned my egr passages and changed the oil and did a very low fuel tank can of sea foam. Also changed out transmission oil too. At 115k i changed out my front struts and changed those junk control links and now my car runs super better then oem at least it feels that way driving. Next is change out my thermostat for added piece of mind.
