How much time between oil changes?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mr. Man, Jul 20, 2022.
  1. bisco
    52,855
    that's what makes it such a great car, lifetime fluids
  2. Merkey
    Merkey Active Member
    330
    306
    Birmingham, Michigan
    Wonder what Toyota's def. of "lifetime" is.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    979
    Monument, Colorado USA
    Heck I remember my POS American made cars in the late 70's and 80's that could barely make it to 100,000 miles before throwing a rod or burning a LOT of oil. I remember checking the oil that only had 2,000 miles on it and it being as black as night! Yet the Honda's and Toyota's (rice burners) I saw seemed to last forever!!
    Doug McC likes this.
  4. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    For my 2022 Prius Nightshade the only fluid that comes close to "Lifetime" is the transmission fluid, PROVIDED you don't drive while towing (which it is not approved for anyway) OR drive using a car top carrier OR (AND THIS ONE IS A GOTCHA!!) driving with heavy vehicle loading.
    Ignoring the first two, the third one is where any hope of calling it "lifetime" will pretty much go out the window for the "average family" in the United States. Using CDC, Census, and airline figures, here are some calculations.
    Average family size 3
    Average adult male weight 199.80 pounds;
    Average adult female weight 170.80 pounds
    Average weight of child (11-16 years old) 155.80
    22 pounds for carryon luggage (lowest limit I was able to find); 22 X 3 = 66 pounds (think of brief cases, purses, book bags).
    From the label inside the drivers door of my Prius: "Combined weight of passengers and cargo should never exceed 825 pounds".
    So a family of 3 could very easily weigh 592.4 pounds for even short trips. That comes to 71.80% of the vehicles cargo capacity.
    Based on rule of thumb for RV use, that would be considered at least approaching "heavy vehicle loading".
    Add in a couple of bottles of water, the family dog, etc. etc. etc..... much less any camping gear or luggage for that weekend trip, or any groceries (a gallon of water weighs 8.3 pounds and milk is heavier), and we can pretty much throw out the "at least approaching" idea.
    All of this boils down to the average family should be changing the transmission fluid every 60,000 miles or 6 years. AND BTW, also should be changing the oil and filter EVERY 5000 mile or 6 months (based the same requirement of "heavy loading"). At least that's what the maintenance schedule calls for.
    FWIW, a stroll through any Walmart will convince you those "average weights" are EXTREMELY optimistic, ;)
    mikey_t likes this.
  5. Pete44
    Pete44 Junior Member
    48
    Quick drain plug is worth it. No having to find a new crush washer, no wrench needed, no splatter. Just plug a fitting in and twist (hose connected to fitting goes into any collection container, though flat drain pan works best). Seriously glad I did this. And the quick-drain plug has a screw on metal cap, so if it were to leak, for some reason, the cap seals the system and you still won't lose any oil.
  6. ColoradoBoo
    1,349
    979
    What brand of quick drain plug do you have? I've always been scared of those things but our cars have covers over the engine so don't have to worry about anything rubbing against the plugs, opening them up.
  7. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
