How much time do you spend at the gas station?
Discussion in 'Gen 2 Prius Main Forum' started by TheForce, Sep 19, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    once again, Costco fillup. now i have a disclaimer. they have changed their pump procedures which cause a "longer" fillup time.
    previously, i pull up. scan CC which doubles as membership card. select pay by same CC, receipt requested. start pumping. when done, i replace pump, go back and put on gas cap. by then the receipt is done.
    well, i immediately noticed they did not ask whether i wanted a receipt, so figured ok , i get one by default. so same process, i finish up, put pump away, go back (i always park with pump on right. this stretches out the hose i can assure i get all the drops i pay for... ya me cheap... plus the lines for those pumps are always much shorter and nearly always available without waiting as it was this trip.) and no receipt...but a prompt on the screen asking if i want one. i said yes and it was a nearly 7=8 seconds additional wait for it.
    but time was 6 minutes and 41 seconds and i had to run pump slowly because it shut off in the first gallon. after it repeated the shutoff 4 more times, i restarted it at the lowest speed i could manage. but still got more than 10 gallons.
    will say this way a much more enjoyable trip despite the un cooperative pump... gas was 28 cents per gallon cheaper this trip!
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Just filled up - 5 min 50 sec. for 19 litres. I fill at around 1/2 tank. Pay at pump (credit car swipe). I filled one pip early as I'm doing a trip out of town tomorrow. Looking at my fuel book, it appears I fill about once every three weeks. Usually around 24 litres. As I recall, the tank is 45 litres. I get more in because I fill it more. Probably around 48-50 litres.
    It takes me a little longer as I -fill- the tank (until I can sense the fuel at the bottom of the fill tube by how long it takes to back up in the tube). This way I get about 150 km on average more per fill. I also don't get overfills this way as I am actually controlling the situation, not relying on junk auto-shutoffs that vary all over the place. In fact, I can't get a proper fill if I let the auto-shutoff work. At any fill rate. Sometimes it overfilled, sometimes I got 1/2 tank. So I do it myself, and get reliable and repeatable fills. I -never- get to see fuel in the filler tube after I'm done. There is -always- expansion room.
    Yup, -some- fuel vapour does escape (we don't have vapour recovery here anyway). Nope, no fuel on ground!
  3. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok did SPM on thursday. despites its boo-boo, i filled it in 4 mins 23 seconds. once again, no waiting (there were probably 10 cars waiting for right side pumps. as always, i use left side pumps since the hoses are more than long enough
  4. traffic101
    traffic101 New Member
    charlotte
    Had 2 bars, took me 4:49 from entering the property to leaving. It was not busy there.
