How much to expect to put in a used transmission?
Discussion in 'Gen 2 Prius Technical Discussion' started by aprius, Jan 26, 2019.
  1. aprius
    aprius Junior Member
    26
    I
    Hello. Just curious as to how much to expect to have a used transmission put in a 2008 Prius (yes I know it does not have ttransmission per say) by a mechanic - just a ball park figure so know what to expect and if even worth the effort.
    This car has been great and you won't believe the mileage on it.......365K + with all original parts except for brakes, converters (just replaced a few months ago). Hard to say "bye" to this car and don't want to.
    Thanks
    48,995
    i'm guessing around a grand for labor, depending on where you live
  3. JC91006
    16,470
    8,383
    I sourced a used one for $200 and had my mechanic install for $500 plus a tip to the mechanic. You'll need to add in costs for transaxle fluid and seals
    Skibob likes this.
  4. aprius
    26
    I
    Just replaced the 12V couple days ago as it died. Then the trans started acting up. However - it is not giving any codes - is that normal?
  5. bisco
    48,995
    not sure. there is a code for a high voltage short. what makes you think it is the tranny?
    what are you reading codes with?
    SFO likes this.
  6. aprius
    26
    I
    OK, thanks. I could live with that. I was thinking 500-800.
  7. aprius
    26
    I
    It runs fine till you hit 45-50 then like hits a wall and just whines. Battery not charging fully either - I was thinking maybe invert pump but it is giving no error codes at this time.
  8. bisco
    48,995
    you might want to start a new thread with that description
  9. aprius
    26
    I
    Ok, thanks. Will do.
  10. bisco
    48,995
    it is worth checking the inverter fluid reservoir for movement in the fluid with the car made ready.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    What are “converters”?
    Skibob likes this.
  12. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    They are used with the dilithium crystals of course. ;)
