How much water can I drive through?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ozark Man, Oct 5, 2015.
  1. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    Does anyone know how deep water has to be to damage a Prius II. We have some low water bridges that always have a constant, usually shallow, stream flowing over them. How deep can the water be without damaging the electrical components or anything else?
    52,896
    probably 3-4" would be safe, i would go slowly. if you don't know the depth, don't drive through, that's where people get into trouble. if it's up to the bottom of the car, it's probably not a good idea. iirc, there's a warning in the manual somewhere.
    BruceInOKC and CR94 like this.
  3. CR94
    CR94 Senior Member
    2,839
    1,245
    Northwestern S.C.
    Besides what Bisco says, you don't want water invading the exhaust system, wheel bearings, or anything electrical. (Water in the engine air intake or the transmission would be much worse, but is less likely.)
