How obtain Techstream for brake fluid flush?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by manza, Nov 17, 2012.
  1. manza
    manza Junior Member
    I own a 2010 Prius with 41,000 miles and have decided to do a brake fluid flush. My Alldata DIY account directs me to use Techstream. The archives show that The Critic performed a flush with Techstream earlier this year. How do I obtain Techstream? I've seen a slew of "Mini VCIs" being sold as Techstream cables & software which connect my Prius computers with my laptop. Would one of these VCIs be all I need? Thanks.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,838
    Clearwater, Florida
    Why are you doing that at 41K and 2 years old?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    You can buy an official subscription, but there are not-so-legal versions floating around online. :p
    As for the interface, you can buy the Chinese knock-off "Mangoose" interface or pay the $480 for the official one from Mongoose.
    There is a way to do a brake flush without Techstream per the FSM, but the procedure must be followed to the letter and if anything goes wrong, the brakes may not work - so I would not bother doing a brake flush without Techstream.
    Note: I am not sure why (perhaps the Toyota techs can chime in on this one), but after a brake flush, I've found that I need to do a linear valve offset relearn in order for the brake pedal to feel normal again.
    And ed, a brake flush every 30,000 miles is a good preventative maintenance procedure.
  4. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    You'd think so, but it's quite unnecessary (if you actually test your fluid first). My brake fluid was in excellent condition after 4+ years, I tested it using the brake dip strips.
    edthefox5 likes this.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Even if that's the case, practicing good preventive maintenance can never hurt.
    I'll give u a good example:
    Toyota says the CVT fluid shouldn't be changed or at least not before 100k.
    I don't know about u but I'm not going to wait that long. I'll be changing mine every 30k.
  6. Mendel Leisk
    42,354
    To the OP (or anyone): have you asked a dealership what they'd charge for this? Also, you might feel them out as to how often they recommend, what experience they have doing brake fluid change on Prius, the complexity, and so on.
    I'm more-and-more subscribing to the school of thought that you can co-exist with the pros, that some services are relatively easy DIY, and others might be within reach, but considering the outlay in equipment, and/or complexity, and/or consequences of a screw up, and it being a once-in-a-blue-moon item, I'll enlist a (competent) pro.
    Brake fluid change on the Prius, for me at least, would fall into the latter category. I know others relish a challenge, and more power to them.
    Since it's not on required maintenance, it might take several dealerships before you get positive responses. With questions like this I've found emailing every dealership within practical distance is a good idea. The difference in responses can be suprising.
  7. 13Plug
    581
    105
    2013 Prius Plug-in
    I know what you're saying, however the difference is that fluid *testing* has shown that the CVT fluid should be changed much earlier than Toyota recommends.
    I'm saying the same thing about the brake fluid. Test it to see if it needs to be changed. I can tell you from my experience that I tested mine with 4+ years and nearly 50K miles and it was in almost-new condition.
    I agree that preventative maintenance is good, but not if it's wasteful. Changing brake fluid at 30K is like changing your oil at 3K miles, it's unnecessary IMHO.
    These are what I use --> Fascar Brake Fluid Test Strips
  8. manza
    manza Junior Member
    A local car guru in the D.C. area, Pat Goss, who is the techie on PBS' Motorweek, recommends a yearly brake flush. Since it's cheap if I can access Techstream with a $30 mini VCI, I figure it's worth the insurance.
  9. manza
    manza Junior Member
    I found a Tundra owner who had success with one of the mini VCIs, so I'll give it a try if I can find a way to run the 32-bit driver on my W7 64-bit computer. I'll probably try a dual boot. I'll let you know. Thanks for your advice.
  10. manza
    manza Junior Member
    It's hard to find a pro you trust for advice and service. Two dealer quotes are about $160. A mini V CI is about $40. A flush every 30k makes the risk of DIY worth it, particularly since my son has the training and tools to bail me out.
  11. Mendel Leisk
    42,354
    FWIW: Honda recommends tri-yearly, regardless of mileage. At least with our last car, an '06 Civic Hybrid. I think the idea is that the stuff deteriorates over time, regardless of mileage. Also FWIW, the charge (with Honda dealership) was $65.
  12. edthefox5
    10,096
    4,838
    Clearwater, Florida
    Unlike trans fluid brake fluid last a really long time. And unlike trans fluid even if brake fluid gets a little old it won't really harm anything. A flush and your good to go unlike Prius trans fluid and its bearing intensive transmission.
    And not having to brake service a Prius for a long long time is one of its best features. The brakes are hardly used.
  13. edthefox5
    10,096
    4,838
    Clearwater, Florida
    I bet he's not a Prius techie. And its not cheap to access TIS or Techstream lite.
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    Suck the fluid out of the reservoir with a turkey baster and fill it with fresh fluid.
  15. The Critic
    3,193
    2,333
    CA
    This is the one I have. It mostly works....I cannot change the reverse beep for some reason, though.
    Wholesale Mangoose toyota diagnosing and reprogramming interface
    Sure, the fluid may test "OK," but the test is being done on the cleanest fluid - the fluid in the reservoir. Most of the nasty gunk is in the calipers itself. Plus, a lot of rubber debris usually comes out when you flush the fluid - which is also another what causes problems sometimes by plugging up passages in ABS components.
    I feel that those test strips are ways for shops to "justify" the brake fluid flushes on the worst offenders...so that the consumer advocacy watchdog groups don't go after them. ;)
    Glee217 likes this.
  16. edthefox5
    10,096
    4,838
    Clearwater, Florida
    I've done countless brake jobs on my cars over the years including some real high mileage mutts and have never seen "rubber" debris in the fluid. Which must be coming from the caliper diaphragm which means your talking high mileage ridiculous wear cars. Which does not even come close to applying to the OP post.
    And those strips work great for testing the fluid.
  17. manza
    manza Junior Member
  18. manza
    manza Junior Member
    To The Critic: Thanks for the referral to the Mangoose. My problem is that only W XP supports the drivers for Mangoose and Xhorse VCIs. I'll see about buying an XP download.
  19. The Critic
    3,193
    2,333
    CA
    IIRC it works fine on 7.
  20. The Critic
    3,193
    2,333
    CA
    I've seen some amount of debris from every brake fluid flush that I've done. In fact, I'm doing one tomorrow on my mother's 2010 Altima V6 with 17,000 miles - I'll see if I can get a picture of the debris.
    Regardless, I still stand by what I said - the nastiest fluid will always be in the calipers. The fluid test strips will be used to test the fluid in the reservoir, which is often the cleanest fluid anyway.
    Glee217 likes this.
