How often are you allchanging your spark plugs??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ToyotaGal, Nov 8, 2022.
  1. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    I have been getting about 53 avg. I started to go down and the car engine was not as quiet an normal. It has been about 65k since I changed the plugs and Pvc valve.
    I pulled plugs and they were fouled.
    I changed the plugs valve and coil plugs.
    As per dr prius the battery temp went down 6 degrees on all three zones. The engine is quiet again.
    Is anyone changing plugs less often?
    Tomorrow morning the mechanic is going to drain the fluids.
    52,854
    most do it at the recommended 120k. are you burning much oil?
    ToyotaGal likes this.
  3. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    I only seemed to burn oil last year when I did a long road trip. Highway driving. It wasn't much. I've been driving locally and I never have to add any. I do change the oil at 3 k most of the time.
    52,854
    do you have any pics of old plugs? i can't imagine what else might be fowling them. even at 120k, many say they look almost new.
    how many miles on the car?
    are you using plugs from a dealer?
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    979
    Monument, Colorado USA
    For our vehicles with Iridium plugs, it's every 10-years or 100,000 miles. Non-iridium are every 5-years, 50,000 miles. I, also, replace the PCV valve when I replace the plugs.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Whats a plug valve?
    How were the plugs fouled was there oil on the tip or oil around the base? If oil on the tips the rings are shot.
    Hope you used factory coil on plugs after markets are worthless. After markets are half the price of a factory cop for a reason.
    ToyotaGal and ColoradoBoo like this.
  7. ToyotaGal
    ToyotaGal Member
    212
    Millis, ma
    Unfortunately I didn't take any pictures. Plugs came from the dealership. There was oil on the white part and the tips were dry and whitish. I have 227,000 on the car. The next day I took the car to another mechanic and he drained the brake fluid and transmission fluid. He said not to worry about plugs because of high mileage and to just change them sooner. The car is driving like a dream.
    Interesting you say after market coils are useless. My friend uses after market on his gen 2. It has 230k on it and has stupid codes. One is 1126. I can't remember what the other one is.
  8. ColoradoBoo
    1,349
    979
    The PCV valve routes air and fuel from the crankcase back through the intake manifold to the cylinders. It's actually prettty easy to check them...you just unscrew and then shake them...if you hear a sound like a ball bearing is hitting then it's working. If no sound or muffled or very hard to get the sound then it's clogged and need replacing.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Ok oil on porcelain is a leaky valve cover gasket
    Very common in all 4 cylinder cars.
    the fact that you see oil up that high on the plug means the gasket is shot. That high means the coil can get fouled too
    happened to my g2 but caught it before it got bad.
    to all lurkers before u take the plugs out remove the coil then take a picture of the spark plug well to see if you have oil in the well.
    very common.
    ToyotaGal and bisco like this.
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    PCV valve relieves pressure from the engine crankcase which includes heated oil vapor and combustion byproducts. If you use crappy cheap oil or dealer oil change there will be significant oil vapor byproducts which tend to clog the throttle body becasue cheap oil breaks down with highly heated.
    PCV valve feeds the throttle body via a small rubber hose. It is fed below the throttle butterfly. There is also a larger companion hose from the valve cover that also goes to the throttle body. It feeds above the butterfly.
    Its important if you change the pcv valve that you also inspect the hose ends for cracking which i found on my car and also hose out the tube on the TB that the pcv valve hose feeds with cab cleaner as that TB hose connection tends to get clogged with gunk which you can see in my picture. This is not unique to a Prius all cars are like this with the gunk.
    FYI: the hose that goes from the PCV valve to the TB is a special hose with a tight right angle. Its hard to substitute that hose given how crowded the pcv valve area is. A after market hose cannot make the turn with out kinking. I know I tried a few. That hose was $35 at the dealer and they stocked it so its a maintenance item also.
    See my picture.
    If your running DINO oil it will be very badly clogged negating the pcv effect.
    Please see the pictures of my throttle body. See the 2 hose connections. See the smaller hose connection filled with gunk.
    And as far as oil leaking past the valve cover gasket into the spark plug well I included a pic of that on my car also as that was just starting to leak oil into the well.
    #10 edthefox5, Nov 11, 2022
    ToyotaGal and xliderider like this.
  11. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    PCV valve likely and hopefully it wasn’t for too long.
