How often should I be changing the oil of my Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusowner28270, Sep 15, 2021.
  1. priusowner28270
    priusowner28270 New Member
    I have a Prius 2011 model. How often should I be changing the oil of my Prius?
    And is synthetic oil the only option?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    4000 conventional oil 6000 synthetic
    priusowner28270 likes this.
  3. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    I change with Mobil 1 every 5,000, but I’ve owned the car a long time and I’ve let it go 9,000 miles before a change.
  4. Mendel Leisk
    40,555
    With 3rd gen Toyota USA says 10k miles or 12 months, whichever comes first. Toyota Canada says 8k kms (~5k miles) or 6 months, whichever comes first.
    Both recommend 0W20, which likely is only available as synthetic. But they don’t come right out and insist on synthetic. I think in particular with the CDN interval either synth or conventional would be fine.
    Steph1972 and priusowner28270 like this.
  5. Rebound
    3,972
    2,626
    Portland, OR
    Yes, 10K mi is the interval for standard use.
    But I aim to change every 5K mi, which is also the interval for heavy use (they have some term for it).
    With my car at 160,000 mi, I’ve switched from the 0w20 to 5w30. Toyota definitely specs 5w30 for the engine, in addition to 0w20. I think they specify the super low viscosity oil because it improves mileage. That’s important, but engine life is important too.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,345
    Taylors, SC
    Here's why I do 3-5 thousand mile oil changes.
    Grit, priusowner28270 and Rebound like this.
  7. Rebound
    3,972
    2,626
    Portland, OR
    That settles it! 5K oil changes!
  8. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    OEM recommends 10k miles, and that is being conservative (and CYA) with 0W20.
  9. nicoj36
    nicoj36 Active Member
    518
    162
    Try this additive for your oil consumption.
  10. Georgina Rudkus
    3,352
    2,345
    Taylors, SC
    Oil and filters are a lot cheaper than a full engine rebuild. Toyota only warrant the engine for 5 years or 60k miles, whichever come first. I also believe that they only considers loss beyond a quart for a thousand miles abnormal.
    Grit and priusowner28270 like this.
  11. Mendel Leisk
    40,555
    The test in the attached TSB sets eligibility for block rebuild sets excessive oil consumption parameters as under 60K miles and more than one quart in 1100~1300 miles.
    I appreciate for high mileage owners it's not a factor, but: while everybody's talking just miles, the official Toyota schedules are miles or months, whichever comes first. For our Canadian 2010 the official edict is 6 months or 8K kms. We're doing maybe 4K kms yearly. I'm changing the oil and filter every 6 months.
    Grit likes this.
  12. Grit
    Grit Senior Member
    6,444
    4,185
    Wilkes Land
    Since it’s a 2011, change oil & filter every 5,000 mi or 6 months, which ever of the 2 (miles driven or time duration) comes first.
    Stick to synthetic and don’t use “high mileage” spec, it’s printed right on the label.
  13. priusowner28270
    Thank you Mendel!
  14. priusowner28270
    Makes sense, thank you!
  15. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    Here they put Castrol Magnatec Stop-Start professional 0W-20. That is some 17Eur per liter. Pricey, eh;-). Especially if car consumes some. Mine consumes about half a liter per 1000km. If i change oils every 6months i’ll be sending quite a lot of money to Castrol. I think i need to find some lower cost option.
  16. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    A Gen 3 car should only be running synthetic.
    Missing from the equation is how fast are you piling the mileage on? If you're driving a ton, longer intervals, even past 10K are fine. If you're always short tripping the car, shorter intervals are required.
  17. Mendel Leisk
    40,555
    Who is "they", a dealership? That's robbery.
    I don't think Toyota says that.
  18. OptimusPriustus
    328
    137
    Finland
    Yes official Dealership. It sure is robbery. And that stuff is hard to find from other sources perhaps because of price (nobody want it).
  19. Rebound
    3,972
    2,626
    Portland, OR
    I’m still going to say that I think 5,000 is the right interval. Toyota used to specify 5K until they included scheduled maintenance and they still specify 5K intervals under higher stress conditions. That’s why the Canadian interval is still 5K.
    Toyota doesn’t care what happens to your engine after warranty/extended warranty. We know these engines develop head gasket and piston ring issues. I don’t think the 10K interval is a good choice for longevity.
  20. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    15k intervals on mine since I got it at 42k. Oil analysis comes back amazing. One size does not fit all. It's just not as simple as that.
    5k-10k is a good cya for Yota to cover the averages between dead beat owners, varied driving/operating conditions and warranty concerns. Lowest common denominator and all that, not necessarily what is required for long engine life in all cases.
