How often should I change transmission fluid of my 2020 Prius AWD XLE?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tianen Chen, May 1, 2022.
  1. Mendel Leisk
    41,413
    Considering appearance alone, my experience, and I’m “paraphrasing” the miles, but it’s roughly thus:
    First (DIY) change at 10k miles: drained fluid is noticeably darker.
    Second change at 25k miles: drained fluid is only slightly darker.
    Third change at 45k miles: drained fluid is near-indistinguishable from new fluid. Resolve to not do any more changes for a LONG time.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
    From my chats with some seasoned mechanics, changing out transmission fluid too much can be harmful to them. All of them said two things....do it at every 5 or 6 years (50,000 miles) and don't skip. (None suggest doing a break in service, like some do with new engines, I change my oil in new cars at 1,000 miles)
    If you've gone over 10-years or 100,000 miles without changing it, or bought a used car that hasn't had it serviced, they said changing it can do more harm than good from what they've seen.
    My daughter bought a used 2012 Toyota Sienna van a couple of years ago and didn't have maintenance records. It had 144,000 miles. I checked her transmission fluid and it was dark, but I couldn't smell that burnt smell they can have so I hope and pray the previous owner(s) had done at least one service on it and I went ahead and changed it out. So far, it's been running great so that's a relief.
