How often should I "really" change the oil?
Discussion in 'Prius c Main Forum' started by arcarter, Feb 7, 2020.
  1. arcarter
    arcarter New Member
    Tuscaloosa Alabama
    2016 Prius c
    When I first changed the oil after 7k miles it was still clear and clean looking. I was thinking about pushing it every 10k from now on. Is this wise?
    When do you change the oil on your models?
  2. ChapmanF
    18,947
    The warranty and maintenance guide gives us two different guidelines, depending on the conditions we drive in.
    My driving falls in the shorter trips / sometimes cold weather category with the 5000 mile guideline, so that's when I tend to change it. In my car, it is usually noticeably dark by then.
    dig4dirt likes this.
  3. John in Vermont
    John in Vermont Junior Member
    50
    Rochester, Vermont
    2018 Prius c
    You don't change the oil because it looks dirty. You change the oil because it no longer protects the engine. Oil breaks down chemically and you can't see that. That "clean" oil is no longer lubricating as well and is no longer protecting the engines internal surfaces from corrosion. I don't understand the logic of saving a hundred dollars a year on a $20,000 + vehicle. Why not run the tires until they are bald and the plies are showing, that would easily save you a hundred dollars a year. Brakes are grinding? - ignore it for six months that'll save a hundred or more.
    WilDavis, edthefox5 and mikey_t like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Times are achangin'
    Many new vehicles are 10k intervals........
    Some oil products are good/guaranteed for 15-20k miles. Off the top of my head...the newish Mobil 1 extended performance
    Of course, this does not mean a person no longer needs to consistently check oil levels....
  5. Leadfoot J. McCoalroller
    8,264
    7,768
    Pennsylvania
    2018 Prius c
    10k is fine, though as @ChapmanF notes short trips combined with cold weather are a factor.
    Short runs without a complete warm-up cycle will allow water to accumulate in the oil sump. A hot extended run has the tendency to boil out any accumulated water. But if it's just 3 miles west in the morning and 3 miles east in the evening, you'll never get it hot enough to get this benefit. In that situation continue changing at 5k.
    Factor this in and decide for yourself, and don't forget dipstick vigilance.
    WilDavis, mikey_t, Merkey and 2 others like this.
  6. John in Vermont
    50
    Rochester, Vermont
    2018 Prius c
    The question asked about stretching the oil change interval based only on the oil's color. I said this wasn't a rational way to judge the condition of the oil. If the oil's manufacturer says the oil is good for ten thousand miles then longer intervals are justified.
  7. bisco
    52,761
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The debate is never ending.
    When I was young, first at car owning age, everyone used Dino-Oils and the accepted recommendation was every 3000 miles.
    Now with higher quality synthetics and synthetic blends, that interval has been pushed out to various points.
    My opinion with any and all vehicles however is to just follow the manufacturers recommendation.
    In this case?
    The OP is looking at extending the interval from 7K to 10K.
    My feeling, opinion is...why?
    IMO new vehicles are really amazingly maintenance free.
    For much of a vehicles early life, it's tire rotations and oil changes.
    And also IMO Oil Changes are relatively cheap. Whether you do them yourself or have someone else do it.
    So for 3000 miles difference? Why risk it? Why not error on the side of an oil change being a little early as opposed to being a little late?
    Lukey51 and mikey_t like this.
  9. Mendel Leisk
    42,249
    I find that hard to believe: did you pour some of the drained oil into a clean jar or something? If you try that I think you'll find it dark as ink, even after just 4000~5000 miles. That's not to say it's not still good, but just sayin'. Sure the dipstick film still looks pretty clear, but try the jar test.
    Well that is the Toyota USA recommended interval. That said, I like the Canadian 3rd gen interval: 6 months or 8000 kms (5000 miles). For 2nd gen Prius Toyota USA recommended that too. Forr son's CX-5 Mazda Canada recommends that interval. It seems a common stance by the manufacturers, maybe playing it a bit safe.
    #9 Mendel Leisk, Feb 8, 2020
    Lukey51 likes this.
  10. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    Pay for a Used Oil Analysis and get the data needed to objectively answer your question. You might be surprised with the results or it might confirm the direction you are intending to go. Either way, it’ll help shape your choice.
    iPhone ?
    Lukey51 and roadrunner like this.
  11. Lukey51
    Lukey51 Active Member
    204
    108
    TN
    The oil was changed just before I acquired my '12 Prius C and it was so clean that it was hard to see where it was on the dipstick. About 700 miles later it's getting darker.
    I plan to change my oil and filter at least once a year, maybe twice.
    I have Castrol Edge 0w20 going into it in April. I only drive the car 4 to 5k miles a year.
    If I was driving it 20k miles a year I'd change the oil 2x a year for sure.
    10k mile oil change intervals should be fine as long as you run full synthetic.
    I wouldn't try that with conventional oil.
  12. John in Vermont
    50
    Rochester, Vermont
    2018 Prius c
    My one year old, so nearly new, Prius C calls for 5,000 mile changes. So the times aren't changing for the Prius, and that's what the question was about.
    edthefox5 likes this.
  13. Mendel Leisk
    42,249
    Regardless of what the companies say, you can stick to or shorten the interval; it's your car.
  14. arcarter
    arcarter New Member
    Tuscaloosa Alabama
    2016 Prius c
    I believe it is because 90% of my drive time is on the interstate cruising at 70 mph, which puts less wear on the engine then stop and go. At least this was my experience in previous cars that I have driven, hybrids should be different since the engine shuts off during city stops.
    From my previous experience the oil will look dirty around 5-6k miles even if it is on interstate driving. This might be because I rarely drive newer vehicles though until now.
  15. bisco
    52,761
    interesting. i wonder why c gets 5k, and all other prius 10
  16. Mendel Leisk
    42,249
    Prius c has second gen engine if I'm not mistaken, and second gen oil change was 5K??
    That your new ride? :whistle:
    bisco and mikey_t like this.
  17. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    John in Vermont....
    Open your horizons.....Oil change intervals are also directly related to the oil quality.
    You could do an oil change using oil purchased at the local Quicky Fill gas station for 2 bucks a quart. Would you still do it every 5k miles?
    You can put in the Toyota recommended oil and do it at the Toyota recommended intervals.
    You can also go to the opposite end of the spectrum with something like the extended performance M1 and extend the OCI even further.
  18. arcarter
    arcarter New Member
    Tuscaloosa Alabama
    2016 Prius c
    it is a 2016 prius c
  19. Mendel Leisk
    42,249
    Yeah, I think Prius c has a 1.5 liter engine, essentially the same engine that's in second gen Prius?
    mikey_t likes this.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I agree with Vermont put the best oil you can buy in the car and replace it once a year.
    I use Redline oil which is one of the best oils on the market and one of the few products on the market that you will actually feel and hear a difference
    In the engine.
    I also would not run the 20 weight oil they recommend by using Redline oil
    There 30 weight is essentially a 40 weight oil which will help with oil loss and it had a zddp package also. 20 weight oil is for mileage but that makes that motor really noisey. Noise is wear. I see no mileage hit with Redline. 5-30 and engine is much quieter.
    Buy 4 quarts of 5-30 Redline oil at Jeggs free ship and and see if you don’t agree.
    I think your motor takes 3.6 quarts with new dry filter.
