How often should i run the gas engine
Discussion in 'Prime Main Forum (2017-2022)' started by MarkP., Jun 8, 2020.
  1. MarkP.
    MarkP. New Member
    Henderson
    2018 Prius Prime
    I have only seen one post on this question and not a lot of responses, i might have missed other posts. This is my first post here on Prius Chat.
    I have a 2018 Prius Prime that I have owned for about 27 months. I live in the southern Nevada. Only info I can find in the owners manual on gas usage is that 5 1/2 gallons of gas should be added a year. Not seeing anything about how often to run the gas engine.
    I work from home and am almost retired, my wife is retired so the car is only used for pleasure. This is our only car. We drive an average of about 600 miles a month but almost every day we take a drive. Our driving routine usually take us no more than 5-10 miles from home. Last few months our usage has been about half of normal and less often.
    First year anniversary owning the car i added 5.75 gallons, at about 16 months we took a 3600 mile road trip. Trip meter showed 62.5 miles per gallon for the road trip. Last time i filled up was on Aug 17, 2019. Tank still looks to be about 7/8 full.
    At times I could easily go several months between using gas. When I first got the car, if I did not use gas one month I would make sure I flipped the switch and used gas for a trip or two in the next month. Lately I have started using gas a little more often, but we are hardly ever more than 10 minutes away from home so not much gas is used. Our most usual trips contains local driving then I jump on the freeway for several miles and back off again. Today we took a different drive and was low on charge and the gas engine ran for about 6 highway miles.
    I asked several service guys at the Toyota dealer on running the gas engine, asked them how often and how long the drive should be and received various answers. I have had zero issues with the car so far, I just want to make sure I do not do permanent damage to the car by not running the gas engine enough.
    Questions for the group are:
    1) How often should I run the gas engine.
    2) When I do use the gas engine, should i make sure the trip is a certain length, i.e. x miles of highway driving, etc.
    Thanks in advance for any responses.
    Mark
  2. Washingtonian
    Washingtonian Senior Member
    716
    617
    Mark - There are two things to keep in mind. First, gasoline has a definite shelf life. After a few months, maybe three to six, particularly if has ethanol added, it becomes stale and may also have taken in some water from condensation. It is a good idea to use the gas before that happens. Second, it doesn't help an engine for it to sit unused for six months to a year or longer. If you had a classic car in your garage, you would make sure to start it and run it long enough for it to lubricate the moving parts and drive off the condensation in the oil at least every 3 months or so. If it had sat a year or longer you would turn it over with the coil disconnected to makes sure oil pressure was up before starting it. That said, no one can give you a definite answer on how often to run the engine or how long to run it. Some might suggest you keep a minimal amount of gas in the tank so you can get slightly better mileage from the lower weight of the car. Some might tell you to only charge the traction battery just before you plan to use the car. My suggestion is to just drive and enjoy it.
    Tips and bisco like this.
    49,492
    different engine, but mine exercises every 124 miles if i don't use it. i just let it finish its warm up before shutting down.
    normally, i would only keep a couple gallons in it, because i don't drive beyond ev range all the much, but i put 8 gallons in just before the lockdown, and now i'm gonna have to burnit off needlessly by 9/15.
    if i had a prime, i would just use the minimum amout of fuel the manual recommends, and not worry about the engine.
    seeing that toyota ditched the automatic 124 mile exercise, they must feel it is unnecessary. and using the minimum amount of fuel every 6 months is sufficient engine run time.
    i might run it out on the highway for 10 miles or so every 6 months, if it wasn't getting any high speed usage, but that might just be old fashioned thinking.
  4. fuzzy1
    10,170
    That is a old-era answer for unsealed and vented gas tanks, as was the norm on cars more than a generation ago, and still is the norm for common gasoline powered appliances around the home and yard.
    But modern evaporative emission control requirements (EPA) have lead to much better sealing in all recent cars (U.S.-market), so gas in them lasts much longer. And the PHEVs have stepped up their game to a level higher than regular gassers, so they can go longer still without problems from evaporation, oxidation, or moisture accumulation. If you follow the Toyota Owner's Manual, you will be fine. GM programs it in to their PHEVs, so it is taken care of automatically.
    Here are some of my past replies on this topic:
    Concerned over gas going bad | PriusChat
    Breaking the fill-up habit | Page 2 | PriusChat
    Further back, I posted a calculation of how much moisture could come in with the make-up air as the fuel level drops. That amount is far less than what E10 is able to handle when acting as a gas line drier / de-icer, something people used to deal with by adding HEET. It takes additional air circulation, exchange with the outside atmosphere, to bring in enough moisture to be a problem. The Prime's well sealed tank should be safe from this for a fairly long time.
    #4 fuzzy1, Jun 8, 2020
  5. Mendel Leisk
    38,727
    Just a seat-of-pants thought: have a "hybrid day" at least once a week, and aim to go through a tank of gas at least tri-monthly.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You need to run it often enough and long enough to use 5 1/2 gallons a year........minimum.
    Personally, I would try to do that about every 3 months and run it down past 3/4 empty before filling.
    That would end up being about 10 gallons every 6 months.
    The engine needs to run long enough to thoroughly warm up. 5 miles minimum....maybe.
    There is no need to be obsessive about NOT using gas.
    With the price where it is now, the cost difference probably isn't that much.
    How do you account for the fact that some components of a modern gasoline mixture will deteriorate over time even if stored in a perfect vacuum ?
    And if it picks up contaminants before entering your tank, that can happen even faster ?
    How about quoting some actual authoritative sources instead of opinions from an Internet forum ??
    #6 sam spade 2, Jun 8, 2020
  7. Tideland Prius
    16,155
    The manual states to add a total of 20L (5 1/4 gal) within a 12-month period and given that Toyota is a conservative company, I'd imagine that would be ok. The Prime does have a pressurized fuel tank (part of the zero evaporative emissions package) so gas probably can stay "fresh" longer than in a regular car.
    I did an experiment last year and went 76 days without the engine coming on. It ended because I went on a road trip. I was seeing if Toyota has a built-in engine run time counter but it never came on on its own accord.
    If you wish, you could run it in hybrid mode for an entire month every year or for two months out of the year if it helps alleviate your concern.
    I would try to vary the rpms when you're running so a highway run may not necessarily be a good thing (even though it will get the temperature up to operating temperature sooner).. maybe combine a highway run to get it up to operating temperature with a city drive to help vary the rpm.
  8. fuzzy1
    10,170
    Why do you assume that Toyota didn't account for this?
    BTW, in a perfect vacuum, evaporation not only continues, but is accelerated. Evaporation is one of the problems that changes the gasoline.
    How about you reading the sources I have previously posted? The relevant section of the Prime's Owner's Manual is just one of the items I have quoted or linked.
  9. sam spade 2
    7,035
    2,788
    2017 Prius c
    If it is an enclosed space, that only happens for a few seconds.......until the space becomes saturated with the vapor.
    Anyway......like with a lot of other things, I think it is better to err on the safe side.
    Change the oil a little more often than recommended.
    Get new tires before the wear bars start to show.
    Put in some fresh gas before you think it really needs it.
    To each his own.
    walterm and Tideland Prius like this.
  10. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    And I've seen references before when this quesiton has been raised that the car has enough smarts to run the gas engine when it's determined that it's gone long enough without running it/using up some gas. Exactly how long that is I don't know.
  11. MarkP.
    MarkP. New Member
    Henderson
    2018 Prius Prime
    Thanks for some replies.
    I failed to mention that one Toyota service guy mentioned that he would run the gas engine weekly, another wasn't sure but would use the gas engine more than i was doing. So this left me confused and not really trusting their replies.
    Replies to my questions were mostly about avoiding stale gas in the tank. Are there other concerns of components not being used often enough that warrant using the gas engine from time to time even when not needed?
  12. bisco
    49,492
    you're asking for more opinions. no one at the toyota dealerships or here at priuschat knows anything about the prime engine running requirements.
    the engineers who designed it do, and everything you need to know is in the o/m. or not.
    benagi likes this.
  13. Okie from Muskogee
    Okie from Muskogee New Member
    Edmond, Oklahoma
    2022 Prius Prime
    I've found the engine coming on even in EV mode when it's really cold, even with more than adequate juice in the battery and air conditioning off. That said, I personally put about 3 miles on the hybrid in my commute daily even though I could do the whole drive on battery. I figure the EV is less efficient at highway speed so the 3 or so miles of my round trip commute I'm on freeway I use hybrid. Rest of the time (surface streets 50 mph limit) I do EV. That uses a couple gallons of gas a month while doing 90+% electric. That's just what I do.
  14. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    ^ Well even with plenty of EV miles left the ICE comes on at 84 MPH and above, if you floor it (sometimes depending on speed) and often when you use the A/C or defroster, you can hear it kick on especially when it’s recently been started.
  15. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    @markp
    Don't worry about it ! If you decide to take a drive just to use up gas in the tank, that is OK.
    Many of us Prime owners and @bisco with his PiP only put a few gals in the tank when refueling, if we're not using the gas engine very much for months at a time.
    I use non ethanol gas too, since every time I put ethanol gas in the tank I can smell (what smells to me like home heating oil ) from the gas station pumps (all year). Some gas stations around these parts have a stronger home heating oil kind of smell than others, but they all seem to have it, except the stations that only sell non ethanol gas. ( sorry for the run on, just one of my pet peves about gas).
    If it were my Prime, I'd just wait, or go for a leisurely drive to use an 1/8 of a tank, might take 200 miles where you're from. Than just keep the tank at 3/8 to a 1/2 and you'll be able to add more gas anytime you want.
    And it doesn't have to be 5 gals of gas every time you gas up, especially if you're using non-ethanol. Than run the gas engine whenever you want, without worrying about how often you need to run it. The only time I'd run the engine when the Prime didn't start if automatically, is before changing the oil, or to check it if I noticed something unusual happening while driving ie: messages on the MID (Multi Informational Display) screen.
    #15 vvillovv, Feb 10, 2022
  16. sam spade 2
    7,035
    2,788
    2017 Prius c
    Think DIESEL fuel.
    Often stations or individual islands that have a nozzle for E0, do NOT have one for diesel.
    Just a tiny bit of spilled diesel will smell for a LONG time.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    964
    631
    Monument, Colorado USA
    I don't have a Prime but very interested in how y'all manage the gas possibly going stale and also ensuring the engine gets sufficiently used.
    I've had a 4X4 Tundra for years and for maintenance is important because we have stuff that can go months and months (even years) without use, so we're told to engage our 4x4 system (4-high and 4-low) at least once a month for at least 10-minutes to get all the transaxles and differentials moving and parts freshly lubricated. I do mine the first day of every month on either gravel or icy roads or in a straight line. (You don't want to engage 4x4 on a dry road while turning...can break stuff.)
    Gas in a gascan can go stale, even though it's not getting any outside air, and a gas stabilizer additive can help but I'd be worried about the stabilizer doing something to my sensitive injectors and other engine parts.
    Maybe only keeping a couple gallons of fuel in her and ensuring you drive enough monthly to burn it off which would, also, help keep the engine lubricated sufficiently.
    drash likes this.
  18. fuzzy1
    10,170
    So far, I don't recall anyone here getting in trouble yet from following the Owner's Manual. And some do use hardly any gasoline in a full year. From the 2022 Prime Owner's Manual:
    The whole PHEV industry designed their sealed tanks to keep fuel good for a year (though original PiP Owner's Manual called for just 6 months):
    Autoblog: How desiging the Chevy Volt's sealed gas tank brought automakers, CARB together
    "... but now we've got the scoop on the gas tank used to keep liquid fuel in the Volt from evaporating or going stale for up to a year."
    mikey_t, jerrymildred and ColoradoBoo like this.
  19. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    For a while, when Gen 4 and Prime were new, there were several threads about people getting gas splashed back on them from the anti-vapor collar on pump nozzles hitting the switch that told the car you had closed the fuel door. (Later models put a guard over the button.) That would close the valve that seals these tanks and the only place then for the gas to go was on your pants and shoes. (So much for evaporation prevention!!!) These tanks are very well sealed and I, too, have never heard of gas going bad in one of them. Aside from vacation trips, I fuel my Prime with ethanol gas about every three months. Last time, I went four months and 3,500+ miles and still had a quarter tank left.
    mikey_t and fuzzy1 like this.
  20. Tideland Prius
    16,155
    I refuelled last month, after nearly 10 months (prior to that, it was half a tank at 12 months but only because it was a year old. I still haven't seen the warning messaging from the car).
    jerrymildred, vvillovv and fuzzy1 like this.
