How Powerful the Brakes Really are...
Discussion in 'Gen 3 Prius Main Forum' started by hockeydad, Feb 16, 2010.
  1. hockeydad
    hockeydad New Member
    298
    23
    zip
    ...and the Lexus owner himself said he "had no brakes". I'm not sure how one can separate out "brake damage" that resulted from the brakes being applied, to "brake damage" from a car fire? That said, I'm not believing anything NHTSA has to say at this point. They've had way too many inconsistencies in prior findings, or no findings in some instances, to give me much faith that they know what they're doing.
    But sure, if the owner pumped the brakes many times, while trying to stop a high speed run away vehicle, you will get some brake fade damage that results because of excessive frictional heat build-up. Remember, it's all about the heat build-up time that causes the heat related fading damage to the pads. If one applies the brakes in a steady and continuous fashion, the car will come to a stop in a matter of a few seconds and there is not enough time for fading to occur. However, if one pumps the brakes on and off for long periods of time, the heat-build up can cause fading. The pumping action does not allow the brakes enough time to cool, and the brake pad temperature continues to rise as the entire process continues. The sooner, the quicker you bring the car to a stop, the chances are that brake fade will not come into play.
    Simplistically - Conservation of energy applies, so the car's kinetic energy is converted into heat (primarily) when braking. Since this is a dynamic system, that is, the velocity is decreasing as you apply the brakes, the total amount of heat that is generated in the braking process is the integral (or summation) of the kinetic energy at any given instanace, over the entire interval of time taken to bring the car to a stop. So, the upshot of this is - the quicker the rate of decerlation, the less total heat that is generated. The easist way to visualize is make a graph. On the vertical axis is KE. On the horizontal axis is time. At zero time you have an initial value for the cars KE. As you apply the brakes, the KE drops and eventually goes to zero as the velocity goes to zero. For the sake of discussion, say the decrease in the KE is linear with time...draw a line that goes from some initial KE to zero in 10 seconds (for example). Now do the same thing, but lets assume the car takes longer to stop, say, 20 seconds. Draw that line. The total amount of heat generated from converting kinetic to thermal energy (heat) is the total area under each curve. You now should be able to visualize that the longer it takes, the more heat build-up you have. While the relationship between heat and the temperature rise at the pads is a complicated formula, suffice it to say that the temperature rise scales with the amount of heat generated. The hotter the pads become, their coeficient of friction is reduced...which, turn, then takes it longer to stop, and thus generating more heat, which raises the temperature even more...and so on.
    But my point still remains - Had the brakes been working properly on this Lexus (I don't know that they were?), and had the owner firmly and continually applied the brakes...the car would have stopped. I have zero doubt about that. None. However, you are free to believe what you want. My main point with this thread was to inform some people on this site to the FACT that the brakes are the most powerful system on your car (the caveat is - when working properly).
    I guess Prius owners should feel a bit better that we have a "B" setting for the transmission, and is used to help "brake" the car when going down a long inclines, and will minimize the use of your brake pads, and thus avoid the possibility of brake fade caused by excessive frictional heat build-up THAT CAN OCCUR over long decents if one continually applies the brakes.
  2. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Its worth noting that in the C&D test they brought the Camry from 120 down to 10 mph with WOT. 85 should be no problem. Even in the CR report, they got the car down to 10mph on the second 60mph run. Hopefully by the time you are down to 10mph your brain starts working again and you can shift to neutral and/or power off.
    FWIW I have also run the full throttle brake test on the Prius Gen 2. A while back I was having some brake drag/grind, and thought I might need to "clean" the rotors. I ran several downhill WOT runs from 45-50 down to zero with WOT in fairly quick succession (maybe 1-2 minutes between to get back tot he top of the hill), and never noticed any brake fade. I also ran several extended runs using WOT and just enough brake pressure to maintain 20mph for 2-3 minutes at a time. I left the experience thoroughly impressed by the braking system on the Prius, and well convinced that the brakes in the Prius are much stronger than the engine.
  3. hockeydad
    298
    23
    zip
    Highly recommend that everyone try this when conditions allow. Not to get over confident by performing such experiements, but everyone should know what their car is capable of doing when all systems are working as designed.
    If I were to try this on any of my vehicles, and could not bring it to a dead stop...it would be in the shop the next day, as it would indicate to me the brakes need some attention.
  4. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    I think it's absolutely HILARIOUS that Toyota's having braking/unintended acceleration/sticky gas pedal problems and that has started this silly debate in the first place. At the end of the day, the automobile has been around for approx 125 years. If an auto company drops the ball and jeopardizes the safety of it's consumers, then all finger pointing needs to be directed at the faulty manufacturer. In this case, it's Toyota. Sorry, but I just don't see the point in debating whether or not the braking system will over-power/override the engine. Neither side of this debate will change the fact that Toyota (and ALL automobile manufacturers) are responsible for producing a safe and reliable product. Note that I'm not slamming Toyota. I love my Prius; I've owned Toyotas for the past 14 years and I fully understand that things happen. But c'mon. Let's not try to downplay what's really going on here.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    So what do you think is going on here?
    Tom
  6. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    Ha! You're funny!!
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'll agree that the manufacturer has a responsibility to produce a functioning vehicle. What I feel is being overlooked is the DRIVER's responsibility to know how to properly operate the vehicle. In this particular case the car was a loaner provided to someone who IMO was unfamiliar with its operation. While the driver was providing the drama the front seat passenger placed the 911 call.
    The fact is that for a few dollars anyone can get a driver license which legally qualifies them to drive any car. This doesn't mean they are capable of driving a specific car.
    Somewhat off topic, has anyone who has experienced "brake problems" taken the vehicle to a state inspection station to have the brakes tested? If so, have any cars failed?
  8. hockeydad
    298
    23
    zip
    "Silly debate"? "Hilarious"? LMAO. Go contribute to such threads as, "what color Prius should I buy?" Or any number of other truely "silly" threads. After all, if you find it so "silly", then don't read. Simple concept.
    The discussion has zero to do with blame, or Toyota. Many brands, many makes of automobiles have had reports of unintended acceleration through the years....so this is not unique to toyota, by any means. It's meant to be educational. You would be surprised that most Americans have no idea how to bring their car to a hault in the event of unintended acceleration - no matter who made the car. I aksed 5 co-workers (all male and all college educated) whether they thought their brakes would stop their cars (non-Toyota's) in the event of an open throttle. Only one got the answer right. Americans are simply uninformed when it comes to cars.
    Clearly, you missed the entire point of this thread. :noidea:
  9. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    Seriously? Get over yourself.
    2 people like this.
  10. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    I think the point here is that absent a physical problem with the brakes, putting your foot on the brake is going to negate "unintended acceleration." And as with the Audi's in the 80s some of us believe these folks unfortunately hit the wrong pedal. Or their mechanic messed up, or they never worried about their brakes. Or they were following too closely anyway.
    While auto manufacturers need to produce a functioning product, the idea that they should achieve 100% reliability no matter who drives them and how and how far they drive them under any and all circumstances is just silly. Metal fails. Brake pads wear out. Systems fail (how many times have you seen the blue screen of death? windows users only).
  11. hockeydad
    298
    23
    zip
    Really, that's all you got? Very informative. ;)
    But pretty much as I thought - you got nothing worth saying.
    As I said, don't read and move on to other things less "silly"...whatever those might be? I don't know...mmm...maybe you can answer some more "car wash questions". Now that's pretty serious stuff. LMAO.
  12. azgringo
    azgringo New Member
    109
    24
    Phoenix, AZ
    Ha! I totally agree that there are a lot of silly questions on this board. Gotta go. Someone just posted a question on what kind of air freshner improves mpg's. That's where I'll be!
  13. fuzzy1
    10,694
    If you:
    (1) cannot get a basic fact right -- the 'has no brakes' comment came from a passenger, not the driver of the loaner car, and was made in an emergency situation with no time to give a complete description;
    (2) refuse to read the NTHSA preliminary site report which very clearly explains how brake heat damage was separated from car fire damage (hint #1: one of the wheel/brake assemblies was not attached to the car fire);
    (3) decline to address the concerns from prior discussions on this subject brought up before you joined this forum,
    Then I have nothing to discuss with you about this issue.
    But I'm not concerned about my Prius. It is a different animal that the Lexus ES-350.
  14. hockeydad
    298
    23
    zip
    Still does not change the fact that someone in the vehicle said, "have no brakes". The 911 call lasted for approximately 1 minute. IMO, that's adequate time to convey detailed information.
    But the fact still remains - Even if the brakes had only been partially working, he should have been able to slow the vehicle to some degree. From all accounts that I have read, the vehicle NEVER slowed, but continued to accelerate. Now that sure seems consistent with the statement, 'have no brakes", now doesn't it? :rolleyes:
    Anything else?
    Who said I didn't read it? Nice assumption, but again, wrong.
    It said the rotors from the torn off section look "similar" to those that were in the fire. Note, in making a comparison, he did not say anything about the pads, or the rest of the brake system. He only said, "other rotors (ie those that went through the fire) on the vehicle exhibited similar conditions (to those in the torn out section)". I did not read in this report where he made a similar statement regarding the pads and the rest of the braking system. try reading carefiully before acussing me of anything...JA. :mad:
    All this aside, I have already conceded that the brake pads can, and will over-heat and ultimately fade, if one brakes hard, lets up, brakes hard and continues this process for some extended period. The brakes do not have enough time to cool in this mode. Read my post about energy and heating, and you might learn something.
    So what's your point?
    "Concerns brought up before I joined this forum"? Wth. Are you serious. :confused:
    What other concerns might those be? If you think I read every thread on this site, every post, you are a bigger JA than I thought. Get real, my man. :flame:
    This thread, which I started, has to do with the brakes being more powerful than the engine. They are. This is FACT. Not in dispute. But, if the brakes have been compromised in some way, then yes, they will not be as affectinve in stopping the car. In addition, and as I already mentioned multiple times - If one pumps the brakes while trying to stop a run away car, you face the real possibility that the brake pads will over-heat and fade, and will not be able to stop the car. This is not in dispute.
    But in the final analysis, since this person was not able to even SLOW the vehicle down (it contiunued to accelerate), it's very clear to this engineer that there was something seriously wrong with his brakes...or something else (unexplained) was happening. Even faded pads will slow the vehicle down to some degree...they may not be able to stop it completely, but the speed will decrease.
    That works for me! Really, please don't read. :D
    ...and who said that it wasn't? :eek:
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    as long as you are not going downhill, you would be right. the San Diego accident that got the media's attention does not seem to understand the effects of gravity as the accident happened while descending a pretty steep hill.
    the only thing most people got out of it, was
    Toyota
    runaway car
    trained police officer driving
    death.
  16. hockeydad
    298
    23
    zip
    The brakes aside, I'm still amazed that a state trooper, or an individual who should have good familiarity with cars, and someone trained in dealing with panic/pressure situations....did not know how to:
    (1) turn the vehicle off
    and/ or
    (2) put the car in neutral
    I realize we all react differently, but IMO, if there was enough time to make a 911 call, and stay on the line for nearly a minute, there should have been enough time for someone with his training and skills, to have found a solution. :confused: If this had happened to my mother, my dad...yeah, I can understand they would not know how to handle the situation. This entire thing puzzels me. There are a number of inconsitencies that make me wonder...
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    agree with you 100% hockey. i for the life of me dont understand why he did not think of something either. i am guessing that had he been alone, he probably would have brought the vehicle to a stop.
    with family in the car probably all screaming at him, that probably affected his brain. another thought that maybe he was too busy attempting to control the car to take either hand off the wheel. obviously a mistake and with the time frames involved, its all very puzzling
  18. hockeydad
    298
    23
    zip
    Now I'm curious, so I went to Google Maps/Strret View to get a better feel for the topography where this incident happened. Unless I am at the wrong location, the terrain near Hwy 125 (turns into Hwy 52?) & Mission Gorge Rd in Santee, Ca is graded, to be sure, but not what i would call very steep (at least from the pictures I see). Further, along his route, there were a number of gradual embankments that he could have turned up and let gravity slow/stop him.
    This whole thing smacks of a primetime TV investigation, like 48 Hours. Anybody from SD Union report whether this guy had enemies, or was having marital problems, etc? Hey, I'm not a conspiracy guy, but this sort of stuff does happen...:confused: Not saying the Lexus didn't have problems...but there's just a lot of inconsistencies here. Too many systems all would have had to fail for a trained highway patrol officer not to have been able to stop, or at least slow the vehicle down....had he wanted to and the systems had not already been compromised by a 3rd party.
    I'm just sayin' it's all rather odd.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i am going by memory so i could be wrong. but i do remember that the car rolled into the bay after the crash and i find it unlikely that its flat since hills abound there.
    **edit**
    ok, looked at map, reread story. the map show extensive hills, changes in elevation, etc. its not close to the bay so my memory is flawed. but the freeway basically skirts the side of a 400 ft hill and elevation markers are not labeled but the freeway seems to run at about the 400 ft level dipping above and below that level down to 200 ft. . unable to pinpoint exact accident scene but there is a rise of unspecified height less than a mile from the accident scene at "sweetwater County Summit Site" which most likely affected the speed of the vehicle.
    http://www.nbcsandiego.com/news/local-beat/CHP-Officer-Family-Killed-in-Crash-56629472.html
    but assuming wreck happened on left turn before the 54 freeway, the elevation looks as if it could have gone from around 200 feet to 100 feet in a pretty short distance making what could be a 10% grade. more than enough to kill apparently
  20. hockeydad
    298
    23
    zip
    It's not flat. But the street view images I saw showed that is wasn't that steep, either. i'm guessing, maybe a 5-10% grade? Bay in Santee? I'm from SD, and no bay around there. From the street view of Google earth, I say no water/ponds, either...but then again, I wasn't looking for any water. According to the police report, the car caught on fire, so it couldn't have rolled into water. The car was pretty burnt up.
    Anyway, not an investigator, but do enjoy a good mystery.
