How Powerful the Brakes Really are...
Discussion in 'Gen 3 Prius Main Forum' started by hockeydad, Feb 16, 2010.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The report doesn't say anything about the exit speed before going airborne, does it? They should in theory be able to calculate this speed using the distance from the second impact slope to the third impact site. If it was still 100 mph (or slower) at the time of the second impact, then it's indicative of the brakes partially working acting to slow down the vehicle. If it was much faster as the accelerating Lexus was capable of on a 5-10% grade, then it had "no brakes."
    I'm also at loss as to why a trained CHP veteran was unable to stop the vehicle.
  2. hockeydad
    hockeydad New Member
    298
    23
    zip
    There are MANY reports that have the speed of the Lexus at, or near 100mph. Whether this was from doing the physics, or whether it was from the 911 call (where the caller himself said they were travelling at 100mph), I have no idea. The report estimates, at impact, the Lexus was going about 100mph. If there was any partial braking, it was minimal, at best.
    I find it odd that there is no mention in the report that any of the airbags in the 2009 Lexus deployed....YET...the report does specifically mention the seat belts were buckled and in tact. Why no mention of any airbag deployment? An oversight in this report?
  3. alexfair
    alexfair New Member
    Dallas
    The fact isn't wether or not your brakes can stop your car during constant accerlation and what knowledge the average driver has of the condition of his brakes (pads, rotors and age of brake fluids) BEST practice is to go in to netural or turn off your car and stick to what you KNOW will WORK period!
    Why argue so much... too much negative karma
  4. hockeydad
    298
    23
    zip
    See, that's where you're wrong. Read up a number of posts the recommendations from Consumer Report. This thing has gotten so much press and concern from driver's, they've come out with their own recommendations (steps) to stop a run-away car. Good for them. As they mention, in many cars, if you turn you car off while accelerating, you could lose both steering and braking. This is absolutley the LAST thing you want to do. :eek: As far as I know, the driver of the Lexus did turn off the engine (but was still accelerating because he was going downhill). Maybe his brakes weren't working as effectively because he turned off the power? Furthermore, putting the car in to neutral will do nothing to slow the vehicle when going down a steep hill (as seem to be the case with this Lexus).
    But I would ask you the following - Why is any of this not worthy of discussion? Are you more concerned with talking about what color of prius to buy? Would that be better "karma"?
    Finally, the vast majority of drivers have absolutley no idea what works best for them, or even the best way to stop a run away car? You certainly didn't know, if you think turning off the engine is a good idea. It might work for some cars....but for many other's, a very bad idea. In almost every case, a person's knee-jerk reaction will be to slam on the brakes. And 99.999% of the time, those brakes will stop a run-away car. I would add - keep your foot on the brakes, and don't pump them, as that will do nothing to cool the pads, and could result in excessive heat build-up and ultimate fading of the pads. But I'm sure you know all this...so i guess I'm wasting my time? :rolleyes:
    You might not like the "negative karma"...but actually, I believe the discussion is a useful one to have. If the negative karma bothers you, why are you reading? There's no shortage of fluff, or "good karma" thereads on this site, that quite frankly, I find to be mind-numbing. Read those, instead.
  5. alexfair
    alexfair New Member
    Dallas
    lol
  6. hockeydad
    298
    23
    zip
    Exactly. :cool: I sense bad "karma". LMAO. :D
    But back on topic, C&D gives the best advice...and for those that think (??) they know it all, then advise they skip this link:
    How To Deal With Unintended Acceleration - Tech Dept. - Auto Reviews - Car and Driver
    C&D Summary of Steps:
    (1) Hit the Brakes
    " Certainly the most natural reaction to a stuck-throttle emergency is to stomp on the brake pedal, possibly with both feet. And despite dramatic horsepower increases since C/D’s 1987 unintended-acceleration test of an Audi 5000, brakes by and large can still overpower and rein in an engine roaring under full throttle.
    Camry: From 100 mph, the stopping-distance differential was 88 feet—noticeable to be sure, but the car still slowed enthusiastically enough to impart a feeling of confidence.
    We included the powerful Roush Mustang to test—in the extreme—the theory that “brakes are stronger than the engine.†From 70 mph, the Roush’s brakes were still resolutely king even though a pinned throttle added 80 feet to its stopping distance. However, from 100 mph, it wasn’t clear from behind the wheel that the Mustang was going to stop. But after 903 feet—almost three times longer than normal—the 540-hp supercharged Roush finally did succumb, chugging to a stop in a puff of brake smoke."
    (2) Shift to Neutral -
    "This is your best option in an emergency. Neither the Camry’s nor the Infiniti’s automatic transmission showed any hesitancy to shift into neutral or park when accelerating at full tilt. (Automatics have a piece of hardware called a park pawl, which prevents the transmission from actually engaging park and locking the wheels at speed—it creates a disturbing grinding sound, but the car essentially coasts freely.)"
    NOTE: Will not stop acceleration down an incline, and with some older transmissions it may be difficult, or even impossible to go from "D" to "N" while moving.
    (3) Turn it Off -
    "Switching off the ignition is a sure way to silence an engine, but it’s probably the least desirable action because it will also make the car more difficult to maneuver. It causes a loss of power-steering assist, plus it will cut off vacuum boost for the brakes.The new wrinkle here: the keyless, push-button start-and-stop systems in many vehicles. Owners need to be aware that these systems require a long press of the button to shut off power when the car is moving (3.3 seconds for the Camry)"
  7. fuzzy1
    10,707
    My Garmin topo map is showing these elevations:
    Intersection of 125 & Mission Gorge: 325 feet
    1 mile before intersection: 500 feet
    2 miles before intersection: 790 feet
    Beware that Garmin is interpolating/estimating elevations from nearby contour lines, so my 5 foot rounding is probably optimistic. And I'm also using straight line distances, while the road's curved path is slightly longer.
  8. fuzzy1
    10,707
    I must disagree, from first-hand experience, and many posters in previous threads had similar observations. The risk of shutting the car off is the possibility of missing the accessory position and locking the steering wheel. Short of that, the only thing lost is power assist, not the basic steering and braking functions themselves.
    At highway speed, no car I've ever owned needed the power assist for steering. When my old cars stalled, as two did frequently, steering was stiff only at slow parking lot and residential street speeds where lethality is very low. I had no trouble at highway speed. Smaller people in today's giant rigs will have a different threshold of what is 'easy'.
    On cars with vacuum-assist power brakes, when the engine is stuck WOT, the vacuum source is essentially gone, so turning the engine off changes little. The power assist is coming only from vacuum stored in the booster, which is usually lasts only a few pedal applications. I've encountered this on four different cars (two frequent stallers, one power booster failure, one unrelated) and while braking required much more pedal force, I didn't feel endangered. But as a nearly 200 pound driver (then, not now) accustomed to some non-power-brake machinery, my brake feet were very strong.
    I regard this as a 'choose your evil' decision. In my first-hand experience with Sudden Unintended Acceleration, pumping the 'brake'once was part of what saved me. It proved that the real problem was 'pedal misapplication'. Had I keep my foot on the 'brake', and not had a clutch to push, the car would have rammed into a solid object before having time to shift to neutral.
    But pumping the brakes consumes precious brake boost. Once that is gone, you're on purely manual brakes. Stomp really hard.
  9. hockeydad
    298
    23
    zip
    Disagree all you want, but C&D is correct. It's fact that some cars, if you turn the power off, you lose either, or both power steering and brake boost.
    To be clear, C & D is writting to all cars. Not just the Camry. With some cars, what they say applies, and to others, it will not. The statement "It COULD lose power steering, etc...." applies. But I doubt the average driver has any idea whether it applies to them, or not.
    What amazes me is that many folks on this cite take a general statement and assume it applies to all cars, all the time. Please. If it doesn't apply to your car, then fine.
    Ever own a 1986 (or 1984?) Subaru wagon with wide snow tires? I did...and you needed it...BIGTIME! Lost complete power on the highway years ago...I struggled to just get it over to the shoulder. Can't imagine that a smaller person, a frail person,. or many woman would have done?
    Whatever works for you, go with it. But the fact remains, if you continually "pump the brakes" down a long incline, or over a long period of time with heavy application...most brake pads will fade. You can believe what you want, but I know this to be true from first hand experience, and through various performance driving schools i have attended.
    If you want to elliminate (or greatly minimize) the risk of fading, put in ceramics. I use them on my Jag and I get no sense of fading after heavy, heavy use on the track.
    On this we agree.
  10. hockeydad
    298
    23
    zip
    So, a 465 foot drop in approximately 2 miles (straight line) representd about a 2.5 degree grade. Not steep.
    I was thinking about this last night...If, as the report said, he was going about 100 mph at impact...and let's say his terminal velocity along the road was somewhere between 130mph-140mph (at some point does the rev limit kick in?). I still have a hard time rationalizing that if his brakes were functioning even partially, he couldn't drop his speed by more than 30-40 mph? Even with faded brakes, I would still have expected to bring it well below 100mph...maybe not be able to fully stop the vehicle, but at least something much less than 100mph. I'd also like to know (since it was not mentioned in the report) - did any of the air bags go off at impact? If not, why not?
  11. a1a1a1
    a1a1a1 Member
    144
    So Cal
    Wrong. The driver was a safety expert with the California Highway Patrol (CHP). It's very unlikely he didn't know how to drive right. I trust his training more than I trust Toyota's revisionistic communications.
  12. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Try a 1990 Cadillac Sedan DeVille when the serpentine belt breaks (thanks, alternator)... I got it to a gas station a couple of miles into town, but my parking wasn't pretty.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Despite all evidence to the contrary.
    Look at how many airplane crashes are caused by pilot error, even with trained, professional pilots. People are fallible, especially in high stress situations. Stopping an unfamiliar runaway rental car with screaming family members in back is probably not one of the situations for which he trained.
    Tom
  14. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    The preliminary NHTSA report talks about the floor mat that was supposed to be in a Lexus SUV. It talks about how it was out of place. There was an article in the San Diego newspaper talking about how the dealer had already been told the floor mat was causing unintended acceleration. And if the floor mat was causing problems with the accelerator pedal, it was probably causing problems with the brake pedal. Sounds to me like the dealer is going to be a part of that lawsuit.
    Has anyone heard if there is a final report on this incident? Or what the "black box" revealed?
    CHP officers never have accidents? I agree that they are well-trained, but I suspect it happens. Especially driving downhill in an unfamiliar vehicle with a floor mat that isn't supposed to be there.
  15. a1a1a1
    a1a1a1 Member
    144
    So Cal
    The whole basis of this post is flawed. Braking efficiency is greatest when the brakes are pumped, and that is exactly what anti-lock systems do automatically for the driver. So press your pedal hard and you are relying on the car to do the rest.
    Now, why does pumping work better (anti-lock -- just press hard and solid its automatic)? (1) It prevents wheel lockup and sliding. (2) It allows pockets of super-heated air to dissipate from the rotors. Heat is the biggest enemy of braking performance. You can not press the pedal nowadays to avoid pumping. Period.
    I wouldn't also recommend testing this yourself to stress out your brakes under full throttle. You might end up with a warped rotor that vibrates every time you stop or a glazed, heat-damaged rotor that makes a loud whining noise. The test could impact the integrity of brake components (metal or pads) by heat damage, thereby reducing long-term braking efficiency.
    Why did the Lexus situation spiral out of control? There could have been many causes. Maybe the brakes were partially used until they lost efficiency due to heat and didn't work right anymore. Maybe the whole drive-time computer crashed. Maybe it was the floor mats and a concurrant brake issue. I don't think anyone really knows what happened.
  16. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Amen.
  17. hockeydad
    298
    23
    zip
    Which post are your referring to as being flawed?
    Anti-lock braking systems are exactly what they say they are...they are a brake system that prevents wheel lock-up (ie, "anti-lock") by modulating the brake pressure/force. The modulation is done in a fraction of a second. That said, at speeds in excess of 100 mph+, it's not clear the wheels were ever at a point of locking-up.
    While anti-lock brakes will bring you to a stop in SLIGHTLY shorter distances than the same car without anti-lock brakes (not always, though), the primary benefit of anti-lock brakes is - you can still steer the car. In cars without this system, once the wheels lock up, you can't steer and are at the mercy of where your momentum will take you. :eek:
    From every report that I've read, it would appear that one (or all) came into play: (1) Complete brake failure, (2) Inadequate braking pressure (possibly due to loss of power, pressure leak, etc?), and/ or (3) severely faded/distorted brake pads/rotors.
    #3 could, would result from extended use (time wise) of the brakes while trying to stop a car speeding at over 100mph. Brake fade would be greatly exasserbated if the driver manually pumped the brakes - this extends the total braking time, and allows for more heat built up, and temperature rise to occur.
    STRONGLY disagree. I do it periodically, and have had zero issues. Do I accelerate up to 100 mph, keep my foot on the gas while applying full brake pressure until it comes to a complete stop? No, I do not. But I will routinely test the brakes under the following conditions, with NO ill-effects: Find a straight section of road, with no traffic. While going 50 or 60 mph....slam on the brakes to similate a panic stop. In the instances I do not have my foot on the gas (also), I will bring the car to a full stop. In cases where I do have my foot on the brake, I usually release once I'm down to about 20mph. For me, it gives me a bench mark on my brakes. i know what they can do, and know what they should be capable of. I'll do this once ever 6 months. I check my brakes regularly, and performing such tests will not warp your rotors or melt your pads. If they do, you have other issues that need to be looked at. Not speculation. I know for fact because I continually check my brakes. I've done this with all my cars: Honda, BMW, Saab, Jag and now Prius. Geez.
    But to be clear, I'm not here to tell anyone what to do. I'm on this site to learn, and (hopefully) inform. There's an aweful lot of mis-information floating around, and if i can help to contribute to debunking some of it, then I feel I've been of some help. But I will say this - If people actually tested their cars more, and knew what they can do under extreme situations, I suspect we'd have fewer fatalities. Pilots and race car drivers have to do it all the time - test (or simulate) actual emergency situations. That way, when/if the real thing comes up, they have a better chance in taking the right action. But I suspect this is the wrong crowd to be talking to about this, as Prius owners aren't excatly known for their driving prowness. :rolleyes:
    That's why there is an investigation. But until the investigation is complted/released, it's Toyota who is taking the heat.
    Based on what I know, the unintended acceleration aspect of this clearly points back to toyota. But why this driver could not even slow the vehicle to below 100mph, raises a number of flags for me. IMO, multiple systems would have had to simultaneously fail. The other possibility is driver error. I do believe that had he been pumping his brakes going down this 2 mile incline at speeds of over 100mph, could very well have warped the rotors and melted the brake pads...thus contributing to his inability to bring the vehicle down to a safe speed. It is also quite possible that this being a rental car, the braking system (mainly pads and rotors, but also fluid) was not properly maintained....which then points back to the rental company/dealer...and NOT Toyota.
    Two problems in this mystery: (1) What caused the unintended acceleration and (2) Why couldn't the driver (even) bring the vehicle down to a safe speed, let alone stop the car? If I had to guess, #1 is Toyota's fault, but #2 is either, or both the driver and/or dealer's fault. I guess when this goes to court, blame will be assessed, and we'll know as much as can be inferred from the physics and forensics.
  18. fuzzy1
    10,707
    Now you've qualified your statement to mean steering and brake boost, to which I agree. Your earlier statement had no such qualifier.
    I can't believe consumer items are sufficiently reliable that a design where loss of engine power, brake vacuum, or PS belt causes loss of basic steering and brake function would be permitted on the road. If NHTSA wouldn't take such rigs off the roads, the product liability lawyers would.
    I still have a 1997 Subaru wagon, which is heavier. I have played with hypermiling FAS just enough to know what it feels at highway speed with engine off. Steering did not scare me at all.
    Small people driving full size trucks and SUVs will have a different threshold of what is acceptable. Personally, I had too much early experience with stalling engines to ever own a vehicle that I couldn't steer or brake with engine off.
  19. hockeydad
    298
    23
    zip
    OK, sorry for the confusion.
    I don't know which models, or even which years this would apply...but would suspect it applies to older models. But the fact still remains there are cars on the road where you would lose either, or both power steering and vacuum boost if the power is turned off. But even if you still had some steering and some braking action...if you're in a situation like this Lexus owner was, clearly, you need all the braking and all the steering you can get. The very last thing you want to compromise, when trying to control the vehicle, is the steering and braking. That's my point, and was also C&D's point.
    That's one thing I still need to test with my Prius - turn off the engine while driving to see how it feels and handles. I've done the panic stop, and I'm very comfortable/satisfied with how the brakes bring the car to a stop. Will the stopping distance be longer (how much) if I turn the engine off?
  20. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yeah, I read that the previous renter of the car informed the dealer of this (the day it happened) but was able to stop the unintended acceleration by first pulling the floor mat out from under him. It's possible that the brakes were worn down over time from previous renters (and who knows how many it happened to but didn't report?) from attempting to stop the car and by the time the fatal accident happened, he had "no brakes."
