How Powerful the Brakes Really are...
Discussion in 'Gen 3 Prius Main Forum' started by hockeydad, Feb 16, 2010.
  1. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Times have changed. I learned what to do when the brakes didn't stop your vehicle in 9th grade, even before having it reinforced in drivers training.
  2. hockeydad
    hockeydad New Member
    298
    23
    zip
    I'm sure the 3 owners, who all died while trying to stop their 2005 Camry's, will be glad to know this is "old news" and you learned how to stop your vehicle in "9th grade". That's great to know. :rolleyes: Oh wait, they're dead.
    News Flash: Not "old news" to many folk. :eek:
  3. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    The point was that it should be "old news."
    From a comment on a Reuters news story in the Detroit Free Press about Ms. Alberto's fatal accident in her 2005 Camry in 2008:
    Feb 12, 2010 9:02pm EST
    I can sympathize with the family’s loss, but only to a degree. When operating a motor vehicle you are the “pilot in command.” Driver licensing standards have become way too lax. If you cannot safely react to common failures to systems such as a stuck accelerator, brake failure, engine cut out, power assist to steering or brakes, etc. you quite simply should not qualify for an operator’s license. PERIOD.
    foureyedbuzzard
  4. hockeydad
    298
    23
    zip
    That may be true, and I'm not going to disagree that current testing to get a driver's license is woefully inadequate. But my point is - That's not the way it is NOW. :eek:
    IMO, many Americans have little clue on how to handle their cars in an emergency situation. I've taken 3 different "high performance" driving programs/schools on test tracks, and each time, I still learn something new about handling my car. I would recommend that everyone take at least one driving program that last for 2-3 days, and goes through everything from skid pad testing to high speed (ie 60-70 mph/highway speed) manuvering. Well worth the money, IMO.
  5. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    My point. I think it should be required that we have "continuing education" as you have had.
  6. justaguy
    justaguy New Member
    136
    california
    Like every body else, I don't think we'd be using that full/maximum pressure dead stop unless we have to. I'm talking about the way the brakes feel without having to step on the brakes on maximum pressure. Those tests are not efficient to measure the safety of other important aspects. Such as the recall of the brakes had to do with the brakes failing when it hit a speed bump. And it definitely does not measure the quality, response, and feel of the brakes at normal use which imo does not compare to audi, bmw, land rover, mercedez.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Thinking that Japanese brakes are not as good as European brakes in terms of feel/response is a perfectly valid opinion but has little to do with the topic of this thread, which is primarily concerned with stopping power.
  8. hockeydad
    298
    23
    zip
    :confused:
    But that's what this thread is about.
    That's what stopping distance is an indication of....how quickly (or distance) can you stop the car in an emergency situation, by hammering the brakes.
    Again, :confused: :confused:
    We're talking about brakes under emergency situations. What are you talking about? Could care less about the "feel", which, by the way, is purely subjective. About the only other brake characteristic that is important to me (in an emergency), is the brakes immunity to fading.
    Again, you are going off topic. This has NOTHING to do with this thread.
  9. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Why are you so hung up on this? Is the passenger a trained observer to react in an emergency??? To give detailed info that 'you' will accept???
    That statement by her is most appropriate when a car is supposed to be breaking and slowing down, yet it was accelerating. And, it could also mean that the brake wasn't effective.
    Why not ask that passenger? Oh, I think they all died:eek:
    then you make a dumb statement about the investigation. They must have a bunch of tenderfoots working there, right??? I guess you would say the same if an air safety board's finding didn't agree with yours???
    Amazing.
  10. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Obviously you think a bit highly of European cars. They have worse brakes then Japnese cars unless you go to the high end carbon brakes on Porche etc. Otherwise most BMW, Mercedes cars have very cheap brakes and they don't last twice as long as normal Japanese build brakes(brake pads).
  11. hockeydad
    298
    23
    zip
    Not "hung up" at all about this statement.
    No, I don't expect the passenger to have assessed the situation correctly - after all, they weren't driving. But, I'm SURE the passenger was simply relaying what the driver, who was trained, said. I think it's very reasonable to assume the passenger was simply relaying what the driver told her. Would you not agree?
    I think it's VERY clear (did you read all the posts in this thread - or are you simply cherry-picking?) that the brakes were not effective. That's a no brainer. But my point was - any car, with brakes that are even remotely working correctly, will bring the speed down to well below 100 mph. This is fact.
    Ergo, my comments about this mystery being more than just about an accelerating car...why couldn't the brakes slow the car down? Were both the accelerator control AND the brakes a problem?
    What statement are you referring to? I'd be happy to respond to your comment, if I knew what it was that you found so "dumb"? Please ellaborate.
  12. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    I am sure the Prius brakes are powerful enough. We should have some one test it out the stopping power from different speeds.
  13. hockeydad
    298
    23
    zip
    I've taken my Prius up to highway speeds and slammed on the brakes while (also) holding down the accelerator. The car quickly dropped speed, and once reachiong about 20 mph, I let up on both the accelerator and brakes. No idea how the Prius would do at 100mph+, fully loaded while driving down an incline (like the Lexus)...but I am, confident that even if i couldn't bring it to a complete stop, I would be able to bring it down to a speed that I could perform a "controlled" low speed crash...if it ever came to that.
  14. fuzzy1
    10,687
    It is encouraging to see that you have dropped the "you will come to a stop" [emphasis added] claim in the OP that is disputed by a number of other sources, some of which you dismissed out of hand.
    Federal standards require light vehicle brakes to meet certain stopping distance standards under a variety of impairments and faults. Unfortunately, it appears that while in gear, the only throttle condition specified is "closed", not "wide open".
    I haven't yet located any similar standards for power steering performance.
  15. hockeydad
    298
    23
    zip
    That's just wonderful that you find it "encouraging". LOL. :rolleyes: But quite frankly, this is a huge waste of my time. Most people on this site are only interested in what color, or what price.
    Not what i'm interested in, and don't plan to post much anymore. There are other forums where the posters really appreciate and want to learn about their cars...this is not such a site.
    Besides, I think (??) I have a buyer for my G3. Althought if i do sell, it might be fun to troll here. But it will be under a new screen name. LOL.
    Bye.
  16. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Oh hockeydad...I've been where you are here on this forum many times. PriusChat is different than other Automotive forums...there is an astonishing level of arrogance here and an utter refusal to accept that someone else may know more about a specific topic than someone else. It really is incredible...and very frustrating when you know that the people arguing with you are just so completely wrong...as many are here. You've handled yourself well lol
  17. hockeydad
    298
    23
    zip
    I think the stats of this web site speak volumes. Approximately 58,800 registered on the Prius site...yet, based on a quick count, fewer than 1% are active. Actually, closer to 0.2% of the members bother to post with any regularity. Mmmm...I wonder why? A staggeringly low volume for any chat site that I've ever visited. But whatever works for you and friends.
    That said, I took a deposit for the sale of my G3 at lunch, so you can now make that 0.1999% :rolleyes:
    It's been real. Over and OUT. :rockon:
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Probably because most of them get tired of reading drama, of which you have been a major participant in creating. :)
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    You mean like hockeydad's thinking that he knows better about how Toyota should handle the PR matter surrounding the recalls than Toyota and his refusal to listen to other posters like fuzzy1 who are more familiar with the various PR pitfalls.
    Congratulations on moving to a more "hot" car (as in sans SR). You're the first person I've ever heard of who've unloaded a car because of a disgust with how a manufacturer is handling the PR matter. Good luck with whatever you drive now.
  20. SW03ES
    2,480
    176
    Gaithersburg, MD
    Just wanted to be sure since tone is hard to convey on the internet...you do know I'm on your side...right?
    To be fair, PriusChat is a VERY active forum. I have been moderating car forums for a long time and those percentages are very typical. You're always going to have a very small percentage who are "regulars" and high posters...and that percentage is actually unusually high here at PriusChat.
    Actually I didn't mean anything about any of that. Hockeydad unquestionably showed that he has a good understanding about the physics and practice of precision driving and he's found an utter refusal to give him any deference for that knowledge and experience at all. I've had similar training and I can tell you...he knows what he's talking about.
    His decision to sell his Prius (which was crazy stupid IMHO) doesn't have any bearing on whether or not he is correct that the braking system on a car is the most powerful system on the car. It is.
