How screwed am I? Battery issue.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2Fats, Jun 13, 2021.
Tags:
  1. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    The lowest clutch setting on most screwdriver guns is equal to the torque for the terminals, but make sure to check... Or another way to do it is one clutch setting lower than what it took to unbolt the terminals. Also make sure to double-check with hand torquing each terminal a tiny bit when you're done because there's so many connections you have to make that it's easy to forget one...
    2Fats likes this.
  2. 2Fats
    2Fats Member
    101
    61
    Missouri
    I looked up the Inch/Ounce models. I'm not sure those would be in the budget, or I'm missing something? The only thing I've found so far for torque specs is this post.
    Do these seem correct? I can handle foot pounds. :)
  3. Prodigyplace
    12,720
    11,850
    Central Virginia
    Ok I meant inch-pounds. All the experts here emphasize that for a reason. It is important.
    2Fats likes this.
  4. 2Fats
    2Fats Member
    101
    61
    Missouri
    My new modules will be here Next Tuesday or so. :)
    My new drill driver will be here Wednesday. I think I've managed to get all the tools I need since I decided I wouldn't need any in the truck, and left my tools at home. (new company policy, we can't do any mechanical work on our own trucks now.)
    I'll go over to the motel, and use their cart to move things between the car and the room, and make a workbench using the computer desk.
    I can't wait to get all this done. :)
  5. 2Fats
    2Fats Member
    101
    61
    Missouri
    It poured rain on my day off (Google pics of Detroit flooded for more info) and I didn't think it would be wise to take things apart. I put it off until next week, but I think I've got everthing I may need except for something to clean possible corrosion off of the terminal bolts.
    Valiant V and Prodigyplace like this.
  6. Prodigyplace
    12,720
    11,850
    Central Virginia
    Perhaps a side order of lifeboats are needed :eek::oops:
    2Fats likes this.
  7. 2Fats
    2Fats Member
    101
    61
    Missouri
    OK. I got the new modules put in. It wasn't too difficult except whoever put it all together last time used all the torque on the bolts holding the seats and battery pack in place... and I came out with a few extra bolts. I've got the last few panels in place loosely, as I need to get some clips when I get home.
    I also skipped putting in the sensor wires somehow and had to go back through and retorque everything after I got them in place. My fan was also suspiciously clean, dusty, but really clean for its age.
    The car seems happy with the new setup.
    Thank you all for the help. It was really awesome. I got pointed right towards what I needed and got the problem solved efficiently and effectively.
    Valiant V likes this.
  8. PriusCamper
    13,468
    5,438
    A couple months ago I helped a friend find an 06 for ridiculously cheap and when I was fixing it up I got excited when I realized the torque on the rear seat back bolts were too high because it was a sign someone had pulled the battery pack. And sure enough, my buddy won the lottery and had a nearly brand new battery pack in his car.
    2Fats likes this.
  9. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Nice to hear a success story!
    Hope you'll tell us how it's performing now with a new pack!
    2Fats likes this.
  10. 2Fats
    2Fats Member
    101
    61
    Missouri
    A year and a half in and it's still running great. I still get great mileage, and haven't had any issues with the batteries.
  11. bisco
    52,878
    congrats!
    you're lucky you got one. everyone is on backorder, and toaster for about 9 months.
    you should post your success in one of his threads
