How screwed am I
Discussion in 'Gen 2 Prius Main Forum' started by Tomfool, Apr 23, 2019.
  1. Try and fix it
    84.6%
  2. Get a new car
    15.4%
  1. Tomfool
    Tomfool New Member
    Portland
    As the title reads? 20190423_175401.jpg 20190423_163434.jpg 20190423_135753.jpg 20190423_135758.jpg
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    With only 108k on the clock, that car has a LOT of life remaining in it.
    My general thought is that anyone who keeps an OBD2 reader in the car is most likely capable of repairing their own HV battery with just a bit of guidance..
    The other 2 codes are being misread by your generic code reader
    1121 and 1150 are codes for the hot water storage tank system
    This is why it's extremely important to use a reader capable of interpreting hybrid info. You could go on a horrible goose chase.
    Take a look at this thread, it shows the same lights for the HV battery issue.
    Just Another HV Battery Thread and Experiments | PriusChat
    Can we add another option to your survey? Option 3 could be "Buy a new car and give old junker 2006 Prius to TMR-JWAP" (y)(y)(y)(y)
    #2 TMR-JWAP, Apr 23, 2019
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    If you are mechanically inclined and want to keep your Prius alive, I’d repair it;).
    But if you want to use this as an opportunity to move on, that’s another option:).
    Only you can answer how badly you either want to repair or replace your Prius. Good luck and keep us posted (y).
  4. Tomfool
    Tomfool New Member
    Portland
    Iam pretty familiar with working on cars, I have all the necessary tools, but testing and replacing battery cells/modules seems a little out of my league. Looking at new hv batteries are around 2k which is more than the car is worth. Do you know specifically what the other codes are? P1150 seemed to be air fuel sensor? P1121 was coolant control valve?
  5. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    1121 is the Coolant Control Flow valve position sensor circuit stuck.
    1150 is Coolant Path clog for coolant storage tank
    Both of these together typically mean the valve that controls flow from the tank is stuck/failed. No big deal.
    Your reader is mislabeling the codes, except for the P0A80, that is correct, That one means replace the HV battery
    #5 TMR-JWAP, Apr 23, 2019
    Skibob and Raytheeagle like this.
  6. Tomfool
    Tomfool New Member
    Portland
    Will these cars operate with a bad hv battery? Is the little 12v enough to keep everything operating? I assume gas mileage and power drop considerably
  7. Tomfool
    Tomfool New Member
    Portland
  8. msg7086
    msg7086 Member
    39
    38
    North Jersey
    The transmission is attached to the electric motor / battery, so if your battery is dying, I assume you'll be grounded very soon.
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    The 12v system is used to power up all the electronic systems, lights, ecu's etc. It's kind of like turning on your computer before you can actually use it.
    The HV battery is like the hard drive. The car will be severely handicapped with the HV battery out of commission. If this was the first time you've had that HV code, you're likely in the early stages of battery failure. Many times, an owner can keep a code reader available for resetting the codes and it will allow you to keep using the car (carefully), but the code will start occurring more and more often, eventually leading to the car going into limp mode. Also potentially creating additional damage to the battery. At some point down the road, the car will no longer go 'ready'. Some people have gone many months doing this. It's easy to say what's the right or wrong thing to do, but everyone's situation is different and there's a LOT of gray area in the world..
  10. Prodigyplace
    12,711
    11,848
    Central Virginia
    You can get a kit of new cells for 1600 delivered which basically gives the car a new battery they are so,d by @2k1Toaster here and the link is in my signature.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The short sensible answer is NO.
    See the link in my signature to see what I did when my 06 HV battery died years ago.
    Skibob likes this.
  12. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    You do have a decision to make but consider this. 108k is low miles for a 2006 Prius. If the only expensive problem you're having with the car at 108k miles is the 12 year old hybrid battery pack the odds are very high at that mileage you're not facing much in the way of anything else majorly expensive failing on the car in the near future. A new battery pack will give you another 10-12 years for that $2,000. Are you realistically going to find another car that will give you the proven dependability and economy of what you have sitting in your driveway right now for under $4,000 (2006 Prius value + cost of hybrid battery pack)? Remember, too, that your Prius will fetch an even lower price because it IS having a battery issue. Any prospective buyer (or dealer on trade-in) is going to want allowances knowing THEY will have to replace the pack.
    #12 srellim234, Apr 24, 2019
    don_chuwish, WilDavis, Skibob and 2 others like this.
  13. Tomfool
    Tomfool New Member
    Portland
    Wow great community here! Thanks for all the advice! I think I have decided to fix the car and swap out the battery, are there any threads on here showing a good walk through?
    On a side note are these cars known for burning oil?
    srellim234 and Raytheeagle like this.
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    AltraStache and Raytheeagle like this.
  15. Prodigyplace
    12,711
    11,848
    Central Virginia
    Here is the new battery kit. @2k1Toaster is very responsive to questions or concerns.
    New Prius Battery Kit (GEN2, 2004-2009) - New Prius Batteries LLC
    AltraStache and Skibob like this.
  16. msg7086
    msg7086 Member
    39
    38
    North Jersey
    I had my car fixed using the above mentioned battery kit. Protect yourself from high voltage, and it's a 3-5 hours assemble work.
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Yes;).
    Best way to avoid running out is to check the dipstick frequently :).
    Skibob likes this.
  18. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Not screwed at all cause it's the most overrated repair in the history of cars.
    My Prius mechanic will rebuild the bad cells for $400.
    Or it takes about 40 minutes to remove battery and 40 minutes to install a different battery. So you get a used one on car-part.com for around $500 and pay an hour or 2 of labor.
    If you are in love with the car and are 100% certain you'll have it in the year 2030 then you may want to get brand new OEM. It's about $1700 for part and anyone that charges over $300 to put in is ripping you off....so brand new about $2000.
    AltraStache and strawbrad like this.
  19. MilkyWay
    823
    359
    23
    MI
    You can clear the code and it will drive fine. I actually drove about 7k miles just by deleting the code (didn't come back for months!).
    But if you plan on rebuilding the battery it isn't healthy to do this.
    With the code on --- it will eventually lack power....with code off for whatever reason it drives like nothing is wrong with the car lol.
  20. Prodigyplace
    12,711
    11,848
    Central Virginia
    That is only recommended if you get a battery pack from a low mile junker. Otherwise you are just putting in an old, repaired battery pack, hoping somebody spent the care & time to do it properly.
