How the Toyota New Global Architecture Will Impact Mass-Car Building
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, May 29, 2015.
  1. Tideland Prius
    16,081
    Read more:
    Stevevee and walter Lee like this.
    49,080
    this is a massive undertaking.
  3. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    71 million cars built worldwide in 2014
  4. orenji
    orenji Senior Member
    5,884
    3,486
    Great Minds, building grest cars! The future looks very bright!
  5. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    I like that Toyota is still relying on people which can work faster in some instances than the robots can. Whereas everywhere else you seem to be hearing that robots are taking all the jobs away.
    That said, I hope the new cars coming out and using the TNGA method makes them more fun to drive in addition to being reliable.
    austingreen likes this.
  6. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Heard that cause the high center of gravity drive of gen 3 Prius while feeling all the contour of the road gets old.
  7. walter Lee
    1,126
    376
    Maryland
    TNGA's flexible custom order assembly reduces the economy of scale to one - but how much customization is allowed isn't detailed. Customized(personalized) panels/fenders could make special edition body work easier to do. Carbon fiber panels could lower the vehicle's curb weight. Key standardized interior parts means it will be easier to find parts and to repair - but there isn't much detail on how much sharing will be done. is the customization only cosmetic or does customization allow for Interchangable functional assemblies - that alter a vehicle's performance or functionality? TNGA has five standard driver-height/ground heights/ground clearance setting. Keeping humans in the assembly line assures that quality is monitored each step of the way. While answering a few questions -this story triggers additional and more interesting questions about TNGA.
    #7 walter Lee, Jun 1, 2015
  8. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Quite revolutionary.
  9. Mendel Leisk
    38,332
    A tough nut to crack just makes me all the more determined, but: you've stumped me, lol.
    garglo and bisco like this.
  10. bisco
    49,080
    me too.:confused:
  11. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Hat's off to Toyota for shaving fractions of a second from repetitive assembly processes. I'm hoping this new approach will helping areas like paint surface quality. In my observations Toyota paint has slightly more visible "orange-peal" than some other companies, but also slightly less than the companies. The consistency of surface from vehicle to vehicle is outstanding. I just hope they will increase the surface smoothness so it matches the best available. I don't think it's a cost issue (maybe a time issue which could equal cost) but I would rate BMW's paint surface as lower quality than Toyota's, whereas Chevrolet's paint surface varies from outstanding to poor.
    Can't wait to check out the Gen4 Prius when it arrives.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I looked closely at a new Ford hybrid the other day because the paint color was so pretty and was amazed to find it was already peeling.merged.I'm skeptical of whether TNGA will save Toyota from the avalanche of recalls hammering the industry. For one, part of the recall saga is political; and second, Toyota cannot avoid part sharing with component suppliers.
    #12 SageBrush, Jun 15, 2015
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    If I'm reading the article correctly I feel this is more of a philosophical reawakening than an actual tangible change in how they plan to build automobiles.
    Of course Toyota will want to continually improve, that is the goal, but towards that end Toyota will not be able to abandon modern production machines and standards. Robots will still build Toyota's.
    In many ways I feel Toyota in becoming the world largest automaker, is still trying to learn themselves what that means to themselves. And it does mean something is lost....in the connection and individual craftsmanship that the original human worker based assembly lines might of offered. Recognizing this and the possible failures that come from massive growth, and reaching back, I think is wise.
    The interchangeability among their platforms? I think that is inevitable and already exists to varying extent. As the worlds largest automaker, Toyota has to produce cars in a Largest Automaker manner, they have no choice. As a global leader, whatever they do, becomes the global architecture by default. Is it reinvention or inevitable evolution?
    The debatable statement is whether Toyota workers are forgetting how to build cars, or as The World Largest automaker, has how Toyota builds cars simply and inevitably evolved to something quite a bit different from it's roots?
    Kudo's to Toyota for realizing there is value in looking back...even as they move forward.
  14. bisco
    49,080
    won't it reduce costs, allowing them to be more competitive?
  15. Tideland Prius
    16,081
    TNGA will not protect them from the avalanche of recalls, in fact, it will compound that fact if something happens. Why do recalls appear to be getting larger and larger in terms of volume and vehicles affected? It's because more and more parts are being shared across multiple models. This is the risk manufacturers take. The cost reduction of using common parts will outweigh the potential for a recalled part.
    TNGA will allow Toyota to significantly reduce the number of different commonly used parts. Instead of 15 or 20 different types of driver's airbag based on vehicle size, steering wheel size, driver's seat position to the wheel etc etc, it can reduce that down to 5 major airbag setups. (e.g. kei-car, small car/sports car, medium & large car, SUV/truck and minivan/MPV). They do that by designing cars around the chassis and the position of the driver and occupants in the vehicle.
  16. bisco
    49,080
    sounds like a lot more complaints about generic styling coming with it.
  17. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    and blinding
  18. bisco
    49,080
    is that a walleye? they need to hire an italian designer.
    HaroldW likes this.
  19. cyclopathic
    3,292
    547
    2014 Prius c
    or german.
    or just hire one, period.
    When I saw pics I thought: "oh man.. it is really ugly but maybe it looks better in real life." Then I saw one in dealership. It doesn't; it looks even worse - pictures do not give it justice.
    HaroldW and SAronian like this.
  20. bisco
    49,080
    oh yes they do.:eek:mergedi'm starting to think, 'just leave the gen III alone. okay, maybe kill the flying bridge.
    #20 bisco, Jun 15, 2015
