How to Activate your Complimentary ChargePoint Card (P.S. it has a limited life span)
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Dec 1, 2016.
Thread Status:
Not open for further replies.
  1. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    I couldn't figure out how to unlock the charging station with the app so I ended up scanning the card.
    I realized this as I was monitoring the app. So, I navigated through and clicked "Stop Charging" before getting to my car and moving it.
  2. john1701a
    john1701a Prius Guru
    12,816
    5,302
    58
    Not if you stop the session.
    There's an option on the app for that.
    #82 john1701a, May 2, 2017
  3. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    Thanks, I will give that a try, i know there is a stop charging option ... i was also under the impression you're getting charged (money) while plugged in, drawing amps or not ...
  4. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    @john1701a - I did not know you could stop the session remotely. Will try that also - thanks!
  5. joachimz
    451
    612
    17
    SoCal
    The operator of the ChargePoint I use at work has disabled that function, saying something like the ev community is growing ... basically encouraging people to vacate spaces after charging. That is fine for me, in my case the walk and return into my office is less than 15min so a welcome break
  6. CharlesH
    2,796
    1,163
    Roseville, CA
    The owner can also charge purely by kwh if they want. For example, Disneyland has 70 charging ports in its public parking structure. They charge $0.35/kwh. You are not expected to move your car when charging completes (I asked). My total charge was $2.25 for the 8 hours I was there.
  7. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I have seen $2/hour for ChargePoint quoted somewhere, although here in Austin TX, you can sign up for a program for "all you can eat" charging, so to speak, for $55/year (within the Austin area).
    Either way though, this strikes me as is a good reason to use two P.Prime features:
    * Auto-lock and -unlock of the charger from the charge port, so that it will unlock the charger from the port when charging completes, and
    * Push notifications (or Email) when charging completes.
    I'm not sure, but I think the former is not available on the P.Prime Plus, and the latter is only available on the Advanced trim level.
    iPhone ? Pro
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,034
    Westminster, Colorado
    And only if you download, install and sign up for Entune, and sign up for Safety Connect (free for three years, $140 a year after that).
    As an Advanced owner, I have done neither.
  9. mr88cet
    2,313
    1,335
    Austin, TX
    I'll see in 3 years (or 3 years and however many months if my P.Prime Advanced doesn't make it 5/15 as projected!), but I suspect I will accept the Safety Connect subscription cost. That, even if only for the remote climate feature: Hit the air conditioner when we line-up at the grocery checkout line, when I finish my weekend rows out on the lake, and many other such circumstances. I'll have to see how reliable and effective that feature turns out to be, though.
    iPhone ? Pro
  10. john1701a
    12,816
    5,302
    58
    It's really handy. 3 years free is nice.
    You get stats too... like what your actual MPG is, not 199.9
    HPrimeAdvanced and mr88cet like this.
  11. Lee Jay
    5,850
    4,034
    I haven't been able to find a real use for it. I use remote AC from my key-fob, and it works fine. I don't need stats from Entune as I keep track of my own, none of the Entune applications do anything useful as far as I can tell, and I'd never in a million years pay for Safety Connect after it expires so I don't want to get used to it.
  12. mr88cet
    2,313
    1,335
    Austin, TX
    That, I gather, since the Eco Dashboard Smutphone (haha) app does show full, unsaturated MPG values (I think I recall somebody else saying that earlier)?
    iPhone ? Pro
  13. mr88cet
    2,313
    1,335
    Austin, TX
    You have to get pretty close to the car to use the AC button on the key FOB, correct?
    iPhone ? Pro
    HPrimeAdvanced likes this.
  14. Lee Jay
    5,850
    4,034
    Probably, but I haven't tried it from more than about 100 feet. My bedroom is directly over my garage so I can activate it from my bedroom and hear the beep of it starting, and I can activate it from inside my office building when the car is in the parking lot outside.
  15. john1701a
    12,816
    5,302
    58
    Correct, so no chance of A/C prepping the car if there's a walk to it, like in a parking lot or ramp.
    Unscheduled remote heater use would be impossible to.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    I suspect I would want to use it much more often than that, at least in the 2-3 months out of the year here where the highs are over 100! However, I'm glad that works for you.
    iPhone ? Pro
  17. Lee Jay
    5,850
    4,034
    I would never use it for hot days. It's very, very inefficient to use A/C to bring an internal temperature of 160 degrees + down to reasonable. Instead I open all four windows and drive that way for the first 3-5 minutes or so, and then use the AC after that. It's faster and far more energy efficient.
  18. john1701a
    12,816
    5,302
    58
    Keeping the already cooled car from getting hot is a different matter... like when plugged in while grocery shopping.
  19. mr88cet
    2,313
    1,335
    Austin, TX
    I certainly don't disagree with that, but that would be after sweating myself up a swimming pool! :) I'll take every chance I can get cut that time down, efficient or not.
    In most cases, hopefully, I'll be plugged in.
    The other reason, however, is cooling down the seat material. For whatever reason, the Advanced trim level does not offer cloth seats, so I expect them to come out flaming hot in the summer, and I'll need pre-climate to cool them down.
    Easier to keep clean, though...
    iPhone ? Pro
  20. Matthew NY
    Matthew NY New Member
    Croton-on-Hudson, NY
    Thank you! just got my prime last friday, and now I have $100 to use. I had already signed up with chargepoint, so the vin as promo code worked fine.
Thread Status:
