How to add NAV destinations ?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Don_23805, Dec 8, 2025.
  1. Don_23805
    Don_23805 Junior Member
    VA
    2023 Prius Prime
    Brand New 2026 PHEV owner . . .
    Want to add new destinations to nav. Found Search and find that voice recognitions works well. When I find a hit, I see only a few choiceslike GO, and Favorites. Nothing like Add To Destinations. So I've been choosing Favorites. But suddenly it tells me I've reached the limit on the number of alowed favorites. How else do I add destinations? Is there also a way to alphabetize them? Or search them? I'm taking them from my iPhone address book, which fortunately has contacts whom I only call, not visit. TIA Don
  2. broderp
    broderp Junior Member
    38
    OH
    2024 Prius
    Limited AWD-e
    Hi Don_23805,
    I'm sort of in the same boat as you. I have been doing it the same way as you, but luckily I have not come up against the limitation you did. (I don't go many places regularly) Did you find a solution?
    The app (if you use it) is very limiting, but it does have a section where you can see destinations that you marked as favorites as well as "Recents" that can be sent to the car. It does not appear to have the limitations of favorites, but it takes several steps. Not super elegant, but it works for me. It would be nice if Toyota added this as well as removed any limitations to favorites.
    Cheers
  3. Don_23805
    VA
    2023 Prius Prime
  4. notspam3
    notspam3 Member
    118
    65
    Toronto
    2024 Prius Prime
    XSE Premium
    I'm not using the car nav enough to be sure, doesn't carplay use the apple maps for favourites? All the favourites I've added on my mac show up on my phone and on carplay.
  5. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    Doing it in the Toyota app is the easiest way I have found. You might be able to do it on the Toyota audio media unit but I remember it being easiest on the phone as well as more robust with options(eg I believe you can give the favorites names in the app). Haven't used it in a couple months so that is all from memory.
