How to block your grill
Discussion in 'Gen 2 Prius Accessories & Modifications' started by acausedelle, Jan 18, 2013.
  1. acausedelle
    acausedelle Hypermiling Through Campus
    Green Lake, Wisconsin
    Hey guys, I've been lurking on this site a lot, and I've come across a lot of cool modifications. This one seems to be the most relevant to where I live, and I want to go through with blocking my grill for the remainder of the winter, since I just bought my prius and am averaging 44 mpg, and I want to get better gas mileage.
    I'm probably going to use the pipe insulation, because it seems like the easiest form of doing it. People on here have asked this question many times, but I don't know the size of the pipe insulation to get. I was looking at this thread:
    Please explain HOW to block the grill | PriusChat
    But it's on a generation 3 prius. Is the sizing any different for the generation 2 prius? I'm going to block the upper grill and about half of the bottom grill since I don't have a scangauge (although I may buy one), and then take it out when spring rolls around. What's the best way to block half of it? Would blocking half of it be the top half? The passenger side? If anyone could help me, it would be appreciated!
  2. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I used the 3/8" pipe insulation, bought it from ACO for $1.19 for a 6 foot or so section.
    I halfed the pipe insulation. Then I stuck those in the grille.
    On my own preference, I left the drivers side of the grill open about 6" just go get some air in there. You dont have to do this, though. Some leave it completely blocked.
    Once you get the pipe insulation and cut it, you'll see exactly 2 ways it can fit. I took the half piece and folded it, then wedged it between the slats. Some dont fold it and just push it in the slat.
    52,393
    i used 1/2" on my gen II. cut it to length and slid the split over the horizontzl fin, 1/2 above and 1/2 below. also have to make verticle slices for the verticle fins.
    Daves09prius likes this.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I used the same size as biscotti but I squeezed 1 whole piece into each slot.
  5. acausedelle
    Thanks guys, I cut the tubing into 6 inch pieces and put it in there. I tested it out around town using pulse and glide (even though I'm very new to it), and averaged ~60 mpg. Very impressed since it's winter. My design could use some work and I may redo it. Thanks for your help guys!
  6. PriusGuy32
    1,417
    514
    Cool! It does make a big difference, I noticed right away with my mpg's. The only problem I had was if I go on a highway trip longer than 1 hour in duration, my ICE was getting too hot (204f) with the lower grille 90% blocked and the top 100% - even though I was leaving the drivers side of the grill unblocked 6". I took one whole piece out of the middle of the lower grille to allow for more air to pass through the radiator and as soon as I did my ICE temps dropped to 185f.
    Oh, nobody else has mentioned it yet but a Scangauge II or the Torque app on your smart phone coupled with a bluetooth OBD2 connector are GREAT ways to monitor your Prius and to squeeze the most mpgs out of it.
    ProZach likes this.
  7. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    When you are grille blocking how hot do you have your heat running? I usually set my temperature to 76 to 78 to pull some heat out of the ICE.
  8. PriusGuy32
    1,417
    514
    I generally put my heat on "AUTO" and turn the A/C off. When the car is fully warmed up I set the heat to like 70-71-72 usually.
  9. Daves09prius
    680
    161
    Gettysburg, PA
    I'm just thinking if you're worried about grille blocking and the ICE overheating, you can turn your heat up inside the cabin to pull some of the excess heat out of the ICE. Remember there is essentially two radiators in the car, one is at the front of the engine compartment used for engine cooling, the second one is smaller and used for heating the air going to the cabin. That’s why when a car begins to overheat you can cool the engine down by turning the heat on full blast.
    I have a long commute going to work so I run my heat continuously at 76 degrees or higher when driving those long distances. It's nice to have heat during the super cold winter mornings.
