How to Break-In EV cars?
Discussion in 'Prime Main Forum (2017-2022)' started by Skapruisprime, Feb 12, 2018.
  1. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    Since the PP mostly run on Electric, has anyone thought about driving in HV mode for few hundred miles just to break-in the engine?
  2. Mark57
    2,945
    2,740
    OK
    Absolutely. There are several discussion threads about this over the last 11 months or so.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Assuming that the engineering theory is the same as the PIP.......it should force you to burn the gas in the tank over time.....which should be more than sufficient.
    Modern car engines haven't needed a "real" break-in for a LONG time now.
    priuscatprimeguy likes this.
  4. Jeff Cohen
    Jeff Cohen Junior Member
    Dallas, TX
    2003 Prius
    As I recall there was some mention of a break-in procedure in the Prime manual. Can’t recall the details right now. Sorry.
  5. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    Prodigyplace likes this.
  6. bisco
    52,786
    perfect.
  7. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Given how the Prius engine works, I suspect constant speed is not an issue...
  8. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Some Prime users have gone several miles in EV only (way over the 124 miles that the PIP recycles at) without ever having ICE kick in.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Does it matter if you do the "break-in" right away or over several years? I would think probably not. I would say "it's an appliance, just drive it".
    priuscatprimeguy and padroo like this.
  10. Mendel Leisk
    42,274
    There are two things that need "break in": the engine and the brakes. Post number 5 lists shows the Owner's Manual break in period for both, but doesn't spell out which is which, though it's fairly obvious. Considering a plug-in prius where the engine is off a lot, I would just extend the engine break in period accordingly.
  11. Sam Spade
    2,036
    1,024
    2017 Prius c
    So ????
    I wasn't trying to say that it would be identical.......because it is a different vehicle.
    What I WAS trying to say is: It is unlikely that the car is engineered to allow you to drive it on EV only FOREVER. Eventually the gas engine will run, whether you want it to or not.
  12. priuscatprimeguy
    2,730
    2,640
    apparently you have evidence that it will?
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    Pointless argument ignored.
  14. priuscatprimeguy
    2,730
    2,640
    actually there probably is no maintenance interval requiring ICE to kick in due to the fact Toyota has this mandatory fuel usage after one year to avoid stale gas from damaging the engine. So there's that. :D
  15. pwlcheng
    pwlcheng Junior Member
    Tampa, FL
    Are you okay? Seems you are not in a good mood.
    Mark57 and priuscatprimeguy like this.
  16. Skapruisprime
    122
    49
    MA
    I was thinking...EV or not, there still an I4 engine in the bay so it has to be broken in
    Well Im going to drive in HV mode for few hundred miles just so I can sleep better at night :)
    priuscatprimeguy and bisco like this.
  17. bisco
    52,786
    that sounds like a plan.(y)
  18. priuscatprimeguy
    2,730
    2,640
  19. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    I think the bigger problem was breaking the driver in.
    Trollbait and priuscatprimeguy like this.
  20. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Seems like those are good driving habits anytime not just during the first 600 miles.
