How to change a wiper switch?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by egg_salad, Dec 11, 2017.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    It appears that the ultra-base G2 without rear wiper uses the same wiper switch as a Camry of the same year.
    As I have eliminated the rear wiper, I'd like to swap in the Camry switch.
    Anybody have any clues how to swap the switch?
    Thanks.
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Can post a picture?
    You mean the switch attached to the motor of the wiper, or?
    Dxta
  3. egg_salad
    545
    426
    Las Vegas, NV
    Oh, I'm sorry. I meant the switch on the steering column! The one from the Camry eliminates the rear wiper function, because Camrys are sedans.
  4. MickyMatter
    MickyMatter Active Member
    260
    166
    Germany
    There are a lot of steps to do.
    Have a look in the attachments.
    If you want details for the steps referring to other chapters of the manual (the blue text), I can offer them, too. Just let me know! Screenshot_2017-12-11-12-04-32.jpg Screenshot_2017-12-11-12-04-40.jpg
  5. egg_salad
    545
    426
    Las Vegas, NV
    Wow. Of all the cars I've owned (and that's a lot!) this is the first that makes you pull the bag and wheel to change a wiper switch. Ugh.
    But thanks for the info!
  6. ChapmanF
    15,887
    If you look hard enough, you might find a way without wheel removal. I had my light and wiper switches off (Gen 3) and I did it by removing the wheel as instructed, and a whole assembly with both switches came off, but if I remember right, it looked as if each switch could also be removed from that assembly. I make no guarantees, but there might be a way.
    -Chap
