How to change Air filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrrame, Oct 21, 2018.
  1. mrrame
    mrrame New Member
    US
    Hope this helps someone here, you can save some $$$ at dealer service center.
    srl99 likes this.
    52,768
    are you driving an '07, while advising on gen 3? or do you have another prius?
  3. mrrame
    mrrame New Member
    US
    i have a 2011, i posted the links in gen 2 and some one pointed it out.
    52,768
    you can change your vehicle if you want to.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Lesser pleats ahh!!!
  6. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    mrrame, I found the video quite helpful. '14 PiP. I'm not sure if you cover it in the video, or if it's specific to this PiP, there are "nubs" on the sides of the glove box which hold it in, even after you remove the damper arm. Not a big deal, I think someone could have more elegantly convinced the glove box to descend. Your info on airflow was helpful. I bought a replacement filter on AMZN, some Chinese brand which is (trying to) convincing me it's such high quality. Very easy to replace this filter w/o tools. Also, great looking pooch!
  7. Mendel Leisk
    42,253
    I find if I pull the glove box up and off the (open-ended) hinges at the bottom, then I seem to be able to get the whole thing off those "nubs" easier, can rotate the whole glove box a to be a bit diagonal in the opening, and then sneak it out with just a slight amount of pushing in the side walls.
