How to Change Front Map Lights.
Discussion in 'Gen 4 Prius Accessories and Modifications' started by eight08customs, Jan 27, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    I'm not sure why one would take that gray cover off for if you're only replacing the bulb. When I did it I just remove the clear cover
    Dragon Rider and krmcg like this.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    Where did you get the "dome light" bulb?
    glennonrp likes this.
  3. DGuy21
    DGuy21 Member
    Lansing, MI
    Three Touring
    These look pretty sweet - I know what I am doing next weekend.... :)
  4. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    From Amazon.
    "JDM ASTAR Super Bright AX-2835 Chipsets Error Free 1.25 inches DE3175 DE3021 DE3022 3175 LED Interior Map Dome Lights, Xenon White"
    That's the product I used. I would link it but Tapatalk doesn't let me create hyperlinks.
    krmcg likes this.
  5. krmcg
    2,592
    2,393
    Whittier, CA
    Thanks! In two days...
  6. bowerda47
    bowerda47 Member
    34
    65
    Michigan
    Three Touring
    Okay all. I see the pics of the map led bulb swap. Makes me not even want to try it. I'll break a bezel or lens and have to replace it. So, Question, does any one have detailed pics of procedures for changing the lower door courtesy lights, the lights for the visor mirrors, and the cargo hatch light. All pics immensely appreciated and will be studied thoroughly to aid in relieving the I'm gonna break it syndrome. LOL
    Dragon Rider likes this.
  7. krmcg
    2,592
    2,393
    Whittier, CA
    The door courtesy lights were incredibly simple. I just "popped" them off from one end with a plastic pry bar and swapped the bulbs. Then "popped" the assemblies back in. Same for the rear light assembly. The only reason that the map light assembly was harder is the size and the more substantial grip that the four large "holders" have.
  8. gr8mpg
    gr8mpg Junior Member
    23
    17
    Chicago
    2024 Prius
    Did you pry the assembly out from the side facing the windshield first? I am having a hard time prying it out without fear of breaking or denting the headliner.
  9. krmcg
    2,592
    2,393
    Whittier, CA
    Just pry from the edge or corner furthest back to get some purchase and pull straight down. The "keepers" will release with enough pressure.
  10. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    EDIT: Oops...this was supposed to be a reply to bowerda47's request for photos.
    This is my LH door courtesy/puddle light.
    Pry tool to release from door panel.
    The locking clip is forward end of the light assembly
    Slide the light holder out of the lens (to the right in this photo), Remove the "hood" from the bulb end of the holder to remove and replace the bulb.
    #30 Weasle543, May 10, 2016
    krmcg likes this.
  11. gr8mpg
    23
    17
    Chicago
    2024 Prius
    This method did not work as described for me. I tried to pry and pull down the entire map light assembly from my Prius Three ATP with sunroof, but the 4 mount points held firm in the steel, and only the bezel came out, fracturing two of the clips closest to the windshield in the process. The frame and two map light lenses remained attached to the assembly in the roof. At that point, I was able to pry off the two lenses and replace the bulbs, being careful not to lose the bulb twist base into the headliner. Everything went back together and held firm, despite the two cracked clips, and the white LEDs look great. Not sure why Toyota made these bulbs to be so difficult to replace!
  12. krmcg
    2,592
    2,393
    Whittier, CA
    Sorry that you had issues, I guess I was just lucky. Replaced all the lights without issue...
  13. roger kim
    roger kim Junior Member
    Fountain Valley, CA
    what did you use to take clear plastic off?
    how long did it take you?
  14. gr8mpg
    23
    17
    Chicago
    2024 Prius
    I used small, plastic automotive pry bars. It took about 15 minutes total. I don't see how the clear plastic lenses can be removed without first removing the grey bezel as the tabs for the clear plastic lenses are secured beneath the grey bezel. The easiest way, is to pull the 4 retainers with the entire assembly, and then change the bulbs, but that did not happen for me. The bezel separated from the rest of the assembly. Please keep in mind that the assembly on the model with moonroof is different than the non-moonroof models. Just be careful, and one way or another, you will succeed.
  15. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    Search Amazon for auto trim tool.
    Can usually find them at most auto parts stores too....Autozone, Advanced Auto, O'Reilly's.
    I picked up a set at Harbor Freight a few years ago.
  16. Weasle543
    Weasle543 Member
    55
    38
    Ohio
  17. ML Newbie
    ML Newbie New Member
    Albuquerque, NM
    Four Touring
    Wow, I don't want to discourage anyone but this was a pretty tough mod so I'll be sure to put your patience on. I am definitely a patient person and almost gave up on this but I got lucky and finally got the clear part off which detached the grey plastic part for me and all without any breakage on the tabs. I only used a credit card, small Swiss Army knife screwdriver and microfibre cloths to hold open the areas I had already propped open with the credit card. I started at the center of the clear area (frosted lens) and worked towards the windshield. The toughest and scariest part were definitely the tabs closest to the map light button but I pushed inward with the screwdriver covered in cloth. Once that gave everything was free and disengaged the gray area. The bulbs were hard to pull out! Straight out no twist in case anyone was wondering. Reassembly was 2 seconds. Hope this helps someone perform this or have the courage to do so.
  18. Prius_noob18888
    Prius_noob18888 Junior Member
    44
    39
    Singapore
    Anyone have the pics to upload again?
    It seems the pics from TS are no longer there
  19. thunderstruck
    thunderstruck Active Member
    154
    151
    Port Charlotte, FL
    2022 Prius
    What's the Amazon part number?
    #39 thunderstruck, Jun 27, 2016
  20. Patrick Conner
    Patrick Conner New Member
    Muncie, Indiana
    OK, I got bulbs (LED's) from Amazon (Yorkim) and I replaced my doors and the back cargo and the mirror lights on both sides.. I to have to find one for the back dome light since it was different the the rest.. BUT I AM SO AFRAID TO TRY THE MAPLIGHT MASSIVE AREA.. I don't see any pictures of what mine looks like.. 2016 Prius Two (no sun roof) and I don't know how to get it off since it is an entire plastic shield over everything. Can anyone please put up new pictures of the process and where to start and what to do please.. Thanks everyone.. just had it 7 days now lol..
    #40 Patrick Conner, Jul 7, 2016
    Fobbers likes this.
