how to change key fob battery?
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Dec 10, 2022.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    We are getting a key fob battery low message. How do I replace it?
  2. burebista
    burebista Active Member
    189
    130
    Romania
    52,742
    good time to test your mechanical keys as well
  4. Mendel Leisk
    42,223
    I was a little surprised at how exposed the electronics were, when you access the battery.
    The tip of the mechanical key can serve as a screwdriver blade to pry open the case, in a pinch.
  5. CR94
    CR94 Senior Member
    2,813
    1,235
    Northwestern S.C.
    Try reading your owner's manual?
    One detail they overlook: When you pry the halves of the case apart, the electronics tend to stick to the wrong half of the case. I solved that with baby powder to keep it from sticking the next time.
    itengineer likes this.
