How To: Change License Plate Bulbs (Video)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by usbseawolf2000, Oct 30, 2008.
  1. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    I tried it, got the panel off; broke a clip and then couldn't get the bulbs out I tried twisting with all my might and in fear of breaking one I gave up…
  2. JC91006
    16,769
    8,567
    Use a small pair of pliers (not pointy ones) and try it again. Just wiggle it a bit while turning (left) to remove. The Blue clips don't break, you just have to remove it from the car hatch and put it back on the plastic cover. Just use a flat head screw driver to pry it out. There should be 11 of them.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I have long skinny fingers. I warpped my index finger around and got good leverage.
  4. SunDevilDrake
    SunDevilDrake Junior Member
    58
    Gilbert, Arizona
    The hardest part of this job was removing the bulbs. It took some force to turn them so they can be pulled out. I had a panel removal set helping me remove the panel. Worth every $6 for the set. Saves me on scratches and dents to the interior, especially when removing radio and console trim.
  5. Sean Dunn
    Sean Dunn New Member
    Phoenix AZ
    I spent sixty minutes trying to remove light bulb housing by hand with no avail. Then, I used a socket wrench, applied some pressure, and it came right out.
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Wow, it has been almost 8 years I made the video.
    The bulb came out easy for me. I have sort of a Hitchhiker's thumb and was able to warp my index finger around and lock it in with my thumb and turn the bulb with pretty good leverage.
  7. SunDevilDrake
    58
    Gilbert, Arizona
    Thinking about this after my job was done, wearing a nitrile glove would give the extra grip needed to make the job even easier.
  8. HughJazscheens
    HughJazscheens Junior Member
    eBay. $2 for 10 lamps. Takes six weeks for them to arrive from China. Replace all the marker lamps in your car. Get some different types; the tallest ones won't fit in some smaller housings. Look for packages that have 5 or 10 bulbs in a single transaction. Almost all of them are "Buy it Now" so cut to the chase. Search for 'led 12 volt 192' and watch the Feedback ratings. If you spend more than $10 total you're doing something wrong.
  9. Landon51
    Landon51 Member
    190
    63
    US
  10. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Too bad that the music is SO annoying and very distracting to an otherwise useful video.
  11. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    This video is better:
